29564 Discussions
FOR$IOS_NO_SUCDEV and FOR$IOS_FILNAMSPE
Ilie__Daniel
Hello All,
Could you possibly tell me when I would get the following errors while calling an OPEN statement?
42
severe (42): No such device
FOR$IOS_NO_SUCDEV. A pathname included an invalid or unknown device name when an OPEN operation was attempted.
43
severe (43): File name specification error
FOR$IOS_FILNAMSPE. A pathname or file name given to an OPEN or INQUIRE statement was not acceptable to the Intel® Fortran RTL I/O system.
Thank you for your help.
Daniel.
Kevin_D_Intel
I've inquired w/Development.
Steve_Lionel
You have a file specification not acceptable to Windows (The Fortran I/O system really doesn't care.) How about you show us what filespec you're passing to OPEN, and perhaps also print it with Z format so we can see if there are invalid characters within.
Ilie__Daniel
Steve,
Unfortunately, the file that caused this issue was deleted by a different process.
We have tried many times to recreate the issue, but we have been unlucky so far.
If I manage to reproduce it, I will let you know.
Daniel.
Steve_Lionel
The issue pertains to the string passed as FILE= in the OPEN, not the actual file. I suggest adding some logging output when the OPEN fails.
Kevin_D_Intel
Development offered:
Try to open some incorrect device. e.g. “/dev/log”
$ cat f.f90
    open(1, file='/dev/log')
    end
$ ifort f.f90 && ./a.out
forrtl: No such device or address
forrtl: severe (42): no such device, unit 1, file /dev/log
This specify that file name is incorrect. Example is filename of zero length:
$cat f.f90
    open(1, file="")
    end
forrtl: severe (43): file name specification error, unit 1, file "Unknown"
Ilie__Daniel
Steve and Kevin - Thank you.
I have already added logging if this happens again.
