FORTRAN 2020 VISUAL STUDIO 2019
El_Zorro_Oro
"Upgraded" to Visual Studio 2019 and Intel Fortran 2020; replaced VS 2015 and Intel Fortran 2016. I noticed that Fortran did not show up as language in the templates - so compiled as a console app.
Using default setup the compile time for a small Fortran program was 9 minutes rather than a one or two seconds on the previous version - there must be something wrong, but I have no idea what.  Same issue with X86 or x64 target. Debug configuration.
The Fortran code is attached - it links OK and runs correctly; just compile time is not acceptable.
The build log is also attached, many new options that I do not recogonize.
System and application follow:
Compiling with Intel(R) Visual Fortran Compiler 19.1.3.311 [IA-32]...
parallel_studio_xe_2020_update4_professional_edition
OS Name  Microsoft Windows 10 Enterprise
Version  10.0.18363 Build 18363
Processor  Intel(R) Xeon(R) CPU E3-1535M v6 @ 3.10GHz, 3096 Mhz, 4 Core(s), 8 Logical Processor(s)
Installed Physical Memory (RAM)  32.0 GB
Microsoft Visual Studio Professional 2019 Version 16.0.22
Microsoft .Net Framework Version 4.8.03752
------------- Build Log -----------------------
ifort /nologo /debug:full /Od /warn:interfaces /module:"Debug\\" /object:"Debug\\" /Fd"Debug\vc160.pdb" /traceback /check:bounds /check:stack /libs:dll /threads /dbglibs /c /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio\2019\Professional\VC\Tools\MSVC\14.20.27508\bin\HostX86\x86" /Qm32 "C:\Users\xxxxxxxxx\!_Working\FORTRAN APPS\UPSAMLE_.for"
UPSAMPLE_V2020 - 0 error(s), 0 warning(s)
Labels (3)
JohnNichols
Valued Contributor III
I just checked my install, VS 2019 Preview, Fortran shows up and the speed is fine, I suggest a reinstall and make sure you pick up all the necessary boxes on the install.
JohnNichols
JohnNichols
16.11 is the latest one - I would update.
El_Zorro_Oro
Thank you for your reply.  I am in a big company so not so easy but will try to update.
El_Zorro_Oro
Thank you for your reply.  I did a repair and got no improvement.  So I will have to get IT to reinstall - big companies do not us worker bees have much control .
JohnNichols
The gods gave us the central limit theorem, but it is IT that gives us the uniform distribution with a = b for everyone.   IT likes to keep to itself infinite power.  Thus proving that infinity times 0 is 1.
Good luck.
