FORTRAN for Win32
BroSte
What is the last version of OneAPI which must be used to generate x86 Fortran code?
I installed the version 2025.3 and it seems to only consider 64 bits compiler.
Andrew_Smith
Valued Contributor I
Intel dropped support for 32 bit in 2023 with the move to replace ifort with the ifx compiler. You might be able to get hold of an earlier download that includes 32 bit if you pay for support.
Andrew_Smith
BroSte
Thank you, Andrew.
Finally, I returned to version 2023.1.
JohnNichols
Honored Contributor I
The two versions will safely co-exist. If you use VS 2026 or 22 it allows you to pick the compiler.
henry_collins
From oneAPI 2024 onward, Intel dropped the IA-32 (x86 32-bit) Fortran compiler support only x86-64 is available now. The last releases that still included 32-bit Fortran were in the oneAPI 2023 line on Windows. If you specifically need Win32 output, you’ll have to stick with oneAPI 2023 classic Intel Fortran (ifort) or an older standalone Intel Parallel Studio build, 2025.3 won’t do it.
BroSte
Thank you, Henry.
Finally, I safely returned to version 2023.1 I was previously using.
MarcGrodent
New Contributor II
In fact, the latest version of the Intel oneAPI toolkit to include the ifort compiler is 2024.2.0 (ifort 2021.13.0):
https://community.intel.com/t5/Intel-Fortran-Compiler/Last-build-for-ifort-and-plans-for-removing-ifort-from-packages/td-p/1615558
BroSte
Thank you, Marc,
