I am trying to compile a project written in CVF with the IFC trial version. I have one problem so far, in my code I use TR15581 arrays (allocatable derived types), which I know are not f95, so I isolated them using #ifdef. For example:
program ifl_toy
TYPE test
#ifdef CVF
INTEGER, ALLOCATABLE, DIMENSION(:) :: A
#else
INTEGER, POINTER, DIMENSION(:) :: A
#endif
END TYPE test
print *, 'hello world'
end program ifl_toy
but while I can get this to compile using the command
ifl ifltoy.f90 /Qfpp2
how would I pass in an fpp command to the compilation (which I need to do in the real project). Say I _want_ to define CVF in the above sample, from the docs, I would guess that I would issue
ifl ifltoy.f90 /Qfpp2 /Qoption,fpp,CVF
but this fails. How would I achieve it?
Many thanks,
matt.
program ifl_toy
TYPE test
#ifdef CVF
#else
#endif
END TYPE test
end program ifl_toy
Many thanks,
matt.
If I understand what you want, /DCVF would seem to be the proper approach.
Steve
Steve
Perfect.
Thanks, again, Steve.
BTW, IMHO the VF compiler options are MUCH clearer than the IFC options.
Matt.
Matt.
