Fail to find old 11.1.046 version
jansson
I try to locate version 11.1.046 of the Windows fortran compiler.
Im interested in ia32 + Intel64 version.
I can only find CESR, 048 , update 3 4 5 to download
The reason we want to try this very version is we see problems with 48, and 51, 54, 60.
And ia32 of 046 solves all of them, now I want to compile intel64.
Magnus
We removed 046 (and earlier updates) as they had installation problems on Windows 7. If you have a specific need for one of those versions, please file a request with Intel Premier Support.
Have you reported these problems? What are the report numbers if you have them?
jansson
There is two problems we want to avoid.
One is described at the other end of the link below; it shows with 11.1.51 and above.
http://software.intel.com/en-us/forums/showthread.php?t=70111
And then linking our program do not work in 11.1.048 on Intel64; seems to be a end less loop consuming ruffly 1MB/s. This might also be a problem for 046 I guess...
A third problem might be that I run 64bit Windows 7, but at least I got access to VS2005 on 32bit XP.
If I found a fix for the ...70111 issue I would be very happy. :)
Magnus
I posted a reply in 70111 asking for a test case. If you can provide us a ZIP of a project that fails to build, that would be useful too.
