29487 Discussions
Failed to write the updated manifest ....
acar
Hi, This is an error which I've had in the past but it has recently reappeared:
general error c101008d: Failed to write the updated manifest to the resource of file "c:\\........\\program.exe".
file=mt.exe ; Access is denied.
The error doesn't seem to affect the solution executable as it still runs correctly.
The recent change I made to the solution was to delete a project.
I'd be interested in the cause of this error and how one might correct it.
ACAR.
Paul_Curtis
Valued Contributor I
Set the project's properties, under the linker entry, to omit creating a manifest.
acar
Thanks Paul, I shall do this until I have a need for manifests. It does appear, however, to be an issue with IVF that Intel might want to address?
