29390 Discussions
Failure in Fortran Open for Binary Files
gerd-paul_hoffmannt-
Open statements in Fortran applications are compiled correctly but leads in execution to an unrecoverable failure.
ArturGuzik
Valued Contributor I
A bit more info is required, I'm afraid. What's the error message?
A.
Les_Neilson
Valued Contributor II
Are the files you are reading created on a different system ?
Example code together with the error message(s) would also help.
Les
jparsly1
As others as said, we'd need to see more to be much help. The following are just guesses:
If you are opening binary direct access files, check your record lengths. The default for CVF/IVF is to measure
in WORDS instead of BYTES. This behavior is changeable through compiler options.
If you are reading binary files created on other systems (or even with different compilers on the same system),
there can be all sorts of problems. Some of these (like "endianness") can be addressed with options in the
OPEN statements. On the other hard, if the files are unformatted (and not direct access), there's no standard
layout for this type of file, and you may find it difficult to read files created with another compiler or on a different
operating system.
In any case, add some more specific info on what is going wrong, and we may be able to point you in the
right direction.
