29648 Discussions
Fatal compiler error with class() pointers
bdforbes
I am getting the message
fortcom: Fatal: There has been an internal compiler error (C0000005).
when I compile some code containing procedure pointers to functions returning class() pointers. I am using IVF Compiler XE 12.0.1.127, IA-32. Here is a code snippet that produces the behaviour:
[fortran]module polytest
    type base
        integer(4)::d
    end type base
    interface
        pure function ptr_func()
            import base
            class(base),pointer::ptr_func
        end function
    end interface
    procedure(ptr_func),pointer::p
    contains
        pure function get_ptr()
            class(base),pointer::get_ptr
            allocate(get_ptr)
        end function get_ptr
        subroutine test()
            p => get_ptr
        end subroutine test
end module polytest[/fortran]
If I comment out the line p=>get_ptr, it compiles fine. I can fix the problem by using type() pointers instead of class() pointers, but I need polymorphism. Any advice on how to proceed?
Thanks - I can reproduce the problem and will forward it to development. Issue ID is DPD200171895. If I can find a workaround I will let you know.
This has been fixed for a future release - sorry, no workaround at this time.
bdforbes
Thanks. I'm happy with tweaking the compilation of the single relevant source file to get it to work. It does not affect the rest of the program.
