29607 Discussions
File closing when DEALLOCATE HELP !!
swafortran
I Have a program that open a file ok, now I have a loop that allocate variables at the begining of a loop read a file and deallocate those varaibles at the end of the loop, it works fine for two time, at the third time that the loop is going to the file is close, and I do not close the file looks that the deallocation is closing the file.
Any Ideas ?
james1
You need to post a code sample. Otherwise a wild guess would be perhaps you are trashing a variable that contains the LUN or something of that sort.
James
