29376 Discussions
Final procedure does not work if the code contains deallocate statement never called
sugimoto605
In the following program, calling sub_ptr%new() should invoke final procedure disposes(), but it is not invoked if I comment out a deallocate statement in subroutine clear() in module m_test_sub.
module m_test
private
public::t_test
type::t_test
private
contains
final::dispose,disposes
end type t_test
contains
subroutine dispose(this)
type(t_test)::this
write (*,*) "destructor"
end subroutine dispose
subroutine disposes(this)
type(t_test)::this(:)
write (*,*) "destructor2"
end subroutine disposes
end module m_test
module m_test_sub
use m_test
private
public::t_test_sub
type::t_test_sub
type(t_test),pointer::ptrs(:) =>null()
contains
procedure::new
end type t_test_sub
contains
subroutine clear(this)
class(t_test_sub)::this
allocate(this%ptrs(0:5))
! deallocate(this%ptrs) ! <----------------------------- STRANGE STATEMENT HERE
end subroutine clear
subroutine new(this)
write (*,*) "Start test"
write (*,*) "End of test"
end subroutine new
end module m_test_sub
program MyApplication
use m_test_sub
type(t_test_sub)::sub_ptr
call sub_ptr%new()
write (*,*) "---end---"
end program MyApplication
**** RESULT (with deallocate comment out) ****
Start test
destructor2
End of test
---end---
**** RESULT (with deallocate statement in CLEAR() ) ****
Start test
End of test
---end---
I dont understand why the result depends on the code which is never called.... Compiler version is 12.1(x86_64)
Also I found that subroutine new() comes eariler in m_test_sub, that is,
end type t_test_sub
contains
end subroutine new
The final procedure is invoked even if I include deallocate() statement in subroutine clear():
Start test
destructor2
End of test
---end---
So the result also depend on which comes eariler, clear() and new().
