Fixed Form Line Length
steve_konarski
In  VS2008 ,if you set the Fixed Form Line Length to 72 , the text after  column 72  would show in  green and  if you set the Fixed Form Line Length to 132 , the text after  132  would show in green.
In VS2012 text goes green after column 72 BUT the Fixed Form Line Length=132 set in the property pages ( Fortran Tab - Language) is observed - is there any way to get VS2012 to work as VS2008 did and show green text after column 132  ?
 Steve
Simply close and reopen the file, or exit VS and restart. It will pick up the setting. This is no change from earlier VS versions.
steve_konarski
Hi Steve that did not work - could it be I imported the project from VS2008 and some incompatibility ?
I don't know. Zip up the project and attach it here - I'll take a look.
steve_konarski
Hi Steve I have tried an existing project and the .FOR files behave as they should when extending to 132 line lengths - the green text starts at 132 position . My project is huge and it is not possible to sent it - however I can live with the situation
 steve
You should be able to just send me the .vfproj project file and one source file that shows the problem.
steve_konarski
Hi Steve - find enclosed the two files requested - the WRITE statement in the subroutine shows the problem - and also the "!" comment problem
I'm not seeing a problem.
steve_konarski
I will try and look into this further - and will download the service pack you emnetioned to sort out the "!" comment problem - If i start a new project i do not get the problem
steve
steve_konarski
When I loaded the vfproj independantly from the full project - I do not get the 72 position problem
steve
steve_konarski
steve
steve_konarski
Using just the vfproj file in visual studio  the green chars start at position 132- I then open visual studio and added the sln file and the green chars started at line 72 - here is the sln file
 steve
The .sln file just lists projects - it can't have any effect on this issue. I note that the source file you provided was not part of the project you supplied, so I wonder if there's an issue with how the project is set up.
steve_konarski
 I will look into it - when i just load te vfproj file all is well , when i add the .sln the green text starts after character 72
Meanwhile I have atached a zip file of the project - hope you can work from this
steve
I can open that (once I fix up the path to the source file), but the long line displays correctly for me in VS2012.
steve_konarski
Arghh thanks for the replies Steve I can live with it but hopefully sort of solution to the problem will turn up
 best regards
 Steve
