29376 Discussions
Floating invalid when "dble"ing a real function
abenson
I just switched from v9.1 of ifort to v10 (specifically 10.0.025) and found that a code that has, for a long time, run just fine when compiled with v9.1 crashed when compiled with v10. I was getting a floating invalid error in a simple line which summed various quantities. The line in question was:
mcold_tot=mcold_tot+dble(Galaxy_Cold_Mass(This_Galaxy))
where Galaxy_Cold_Mass() is a real function which simply sums a couple of the elements of the derived type variable This_Galaxy.
If I switch (in this line and similar lines) to doing:
Cold_Mass=Galaxy_Cold_Mass(This_Galaxy)
mcold_tot=mcold_tot+dble(Cold_Mass)
where Cold_Mass is a real, then it works just fine again.
My question is, is putting a real valued function inside of a dble() invalid Fortran, or could this be a bug in the compiler?
I can post more information if needed.
Thanks for any help you can offer!
-Andrew
Intel Fortran Compiler for applications running on Intel 64, Version 10.0 Build 20070613 Package ID: l_fc_c_10.0.025
Copyright (C) 1985-2007 Intel Corporation. All rights reserved.
x86_64 GNU/Linux
Kernel: 2.6.9-55.ELsmp
Red Hat Enterprise Linux 4
gcc version 3.4.6 20060404 (Red Hat 3.4.6-8)
No, that's a valid use. What is the declaration of Galaxy_Cold_Mass in the caller and in the routine itself?
abenson
Galaxy_Cold_Mass() is as follows:
pure real function Galaxy_Cold_Mass(This_Galaxy)
!% Return the total cold mass of the specified galaxy.
implicit none
type (Galaxy), pointer :: This_Galaxy
Galaxy_Cold_Mass=This_Galaxy%mcold+This_Galaxy%mcold_ongoing_bursts
end function Galaxy_Cold_Mass
It's defined within a module, so is made available to the caller via a "use" statement.
Thanks!
-Andrew.
In that case, please submit an issue to Intel Premier Support and attach a complete test case.
abenson
OK - if I can find a self-contained test case that reproduces this I'll submit an issue.
Andrew.
