Font filenames and fontnames
steve_konarski
I am trying to obtain the font filename from within a Fortran visual program source code. I have found a roundabout way from the following site
http://www.codeproject.com/KB/GDI/fontfile.aspx
where a simple program is available to be downloaded and seems to work well , the source code is also given but does not seem to be complete.
Is it possible to use RegOpenKeyEx and RegQueryValueex functions to obtain thefont file name from the registry values on
HKEY_LOCAL_MACHINE/ Software / Microsoft / Windows NT / Fonts
I have read betwen the lines and assume you need the two functions
RET= RegOpenKeyEx( HKEY_LOCAL_MACHINE, FontName, 0, KEY_ALL_ACCESS,phkey)
RET = RegQueryValueex(HKEY_LOCAL_MACHINE, Fontname, NULL , &type, Fontfilename ,datasize)
regards Steve Konarski
steve_konarski
I supply the Fontname i.e. "Arial Italic" and require the font file name i.e ARIALI.ttf
Les_Neilson
Valued Contributor II
Well it's a bit more work than that.
In RegOpenKey you need tospecifythe registry key you want to open,
sowhere you have "fontname" you need
"SOFTWAREMicrosoftWindows NTCurrentVersionFonts"
(or whatever it is on your system, and it should be NULL terminated.)
This will return a handle in phkey.
Then you use the "handle" in thecall toRegQueryValueEx(phkey, ....
passing the name of the font you want (again null terminated)
and it will return the name of the file.
See the MSDN documentation
Les
I looked at the various font functions and could not see a supported interface for this, so what you're proposing may break in the future.
The QuickWinPoker sample provided with IVF contains registry calls so you can see how it is done. Some of the arguments may require that you pass LOC(arg) and any strings you get back will be NUL-terminated.
steve_konarski
thanks Les I got further
i have the code
USE DFWIN
USE DFLIB
IMPLICIT NONE
character*90 data1,strFont,typeface
integer ret,ret1,type1,phkey
strFont = "SoftwareMicrosoftWindows NTCurrentVersionFonts"
strfont(55:55)=char(0)
ret= RegOpenKeyex(HKEY_LOCAL_MACHINE, strfont, 0, KEY_ALL_ACCESS, LOC(phkey))
typeface="Arial"
typeface(6:6)=char(0)
ret1= RegQueryVAlueEx(phkey, typeface, NULL, LOC(type1), LOC(data1), LOC(datasize))
print * data1
stop
end
_________________________________
ret has a value of 0 from RegOpenKeyex so presume ok, ret1 has value of 2, phkep and type1 have values of 3916
I am expecting ARIAL.TTY in data1
anthonyrichards
New Contributor III
Please find the attached program, which, when set up as a console application, produces the output shown below and
in the JPG file. Hope this helps. Note that I am using Windows XP and the registry key used below shows font names as containing the '(TrueType)' string, so the first example fails to find a key value 'Arial Italic' because that string is not present in the font name.
Hello World
Registry subkey for fonts =SoftwareMicrosoftWindows NTCurrentVersionFonts
Font name =Arial Italic , File name =
Font name =Arial Italic (TrueType) , File name =ARIALI.TTF
Font name =Arial Black Italic (TrueType) , File name =ARBLI___.TTF
Font name =Arial Bold Italic (TrueType) , File name =ARIALBI.TTF
Font name =Arial Narrow Italic (TrueType) , File name =ARIALNI.TTF
Press any key to continue
Jugoslav_Dujic
But take a look at your data yourself using regedit -- alas, the value name you're after is "Arial (TrueType)" rather than plain "Arial".
There's no reliable way to do that, I'm afraid. You can assume that the string contains "(TrueType)" and append it yourself -- not too attractive. You could call RegEnumValue to get all the values from HKLM...CurrentVersionFonts, and then parse the strings and compare them with the typeface name you're after.
P.S. It's much more reliable to append char(0) like:
strFont = "SoftwareMicrosoftWindows NTCurrentVersionFonts"//char(0)
You don't need the double backlashes unless you use ""C strings, i.e. you will need them only if you write like:
"SoftwareMicrosoftWindows NTCurrentVersionFonts"C
You CAN get the full name from the font enumeration functions.(EnumFontFamiliesEx).- the name will be in the ENUMLOGFONTEX structure.
steve_konarski
Thanks Anthony - I have now incorporated the relavent parts of your code into my program and it works well - I missed the (True Type) from the font name , and Ihad double slashes inthe reg key location, and your help got me to where i wanted
Just one more hurdle to get over - and that is
SUBKEY="SoftwareMicrosoftWindows NTCurrentVersionFonts"//CHAR(0)
which I dont think will work on Vista or some widows versions
IS there a function available to fortran which would give the correct windows version - I think the SUBKEY for each would still have to be hard coded into the fortran source code for each version but that is a minor inconvenience
thanks again Steve Konarski
steve_konarski
Thanks jugoslav thats a great help its confusing at times to get the structure correct
Jugoslav_Dujic
See GetVersion(Ex) API -- it returns the Windows version information.
There's also the Platform sample in ifort 10.1.
