Format for real number
Ferdinando_Alde
Hi all. In the last versions of the Fortran compiler I got a strange result. Using the output format 'F0.4' with a real number = 0.0 the last 3 release generate different results: version 11.1.067 0.0000 version 12.0.0.030 0.0000 version 12.0.2.055 .0000 Where is gone the trailing zero in the last release? I had the same result in VS2008 and VS2010.
You mean the leading zero, right? The new behavior is consistent with the standard, which says, "On output, with I, B, O, Z, F, and G editing, the specified value of the field width w may be zero. In such cases, the processor selects the smallest positive actual field width that does not result in a field filled with asterisks."
Since the leading zero in this case is "optional", the standard requires that it be omitted. I believe that there was an interpretation request regarding this.
Ferdinando_Alde
Yes, it is.
Thanks Steve.
There is an option to generate the leading zero?
No, sorry, there isn't.
DavidWhite
Valued Contributor II
You can use the 1P edit descriptor, with care!
For F formating, this changes the value, but not for G formatting, so something like
1PG10.4 ensures you get the leading zero without changing the output value.
regards,
David
