Forrtl: severe (157)
Brian_Allison
am having problems with my DLL compiled with IVF 10.1.021. If I compile an EXE it works fine. If I compile a DLL with CVF, it works fine. THe problem is with the tty lines in my code. I have to comment them out in order for it to work in the IVF DLL. Here is an example of the tty code.
! Set program title.
write (tty,"(a)") ptitle(1:24)
write (output,"('1',3x,a)") ptitle
Here is what the tty =
integer, parameter :: tty=6
It does open a console window on run. Here it is at the point of crash.
Brian_Allison
A write to the screen using "write (6...." works coming from the coding in the main EXE, but fails when a "write (6...." is called from a dll, which was called within the main program or one of its subroutines. The write to a file works properly from the same dll.
Make sure that the EXE is linked to the same library type as your DLL (Either Multithreaded DLL or Multithreaded Debug DLL).
DavidWhite
Valued Contributor II
Brian,
The DLL needs to open a console window itself.
David
Brian_Allison
How do you have the dll open a console?
