Fortan Graphic Effects question
postaquestion
Ihave a FORTRAN-based Windows XP application which runs nicely. It is generate by the Compac Visual Fortran compiler. Link here.
This applic. is a double-buffered OpenGL applic. where I do some Win32 GDI based drawings on top of the rendered OpenGl picture. (Highlighting closest entity etc.)
I am now moving over to Windows Vista and Your Fortran 10.1 compiler. It runs nively except some nasty graphical effects appearing when the program does Win 32 GDI drawing operation on top of an OpenGL picture. The applic. seem to render a "bounding box" around the current GDI operation taken probaply taken from some other bit planes.
My applic. is a full Windows applic. starting from a WinMain and a MainWndProc- routines.
It seems to be some basic difference in Vista compared to XP how the bit planes are used in such an applic.
Please, give me a hint what to do and I will be very grateful!
What happens when you run the CVF-built application on Vista? Which OpenGL interface are you using, the CVF-supplied DFOPNGL or f90GL (or something else)? I have a hard time thinking of a way that this is related to which compiler you use.
bo_torstenfelt
Hi
I am using the default CVF-supplied DFOPNGL interface. call fgl... and so on. Actually, you are right both my old and the new compiler and linker generates and .exe file which on a VISTA machine will course this non-smooth cooperation between OpenGL rendered images and Win32 GDI graphics on top.
My hope was that this was something wellknown and simple to cure!??
Bosse T.
It's not known to me. You might go searching in OpenGL newsgroups to see if you can find some mention, though I don't know what terms you'd search for. If you post anywhere, don't mention Fortran - just talk about the APIs you use. (For the OpenGL routines, leave off the initial "f".)
bo_torstenfelt
Hi Steve,
My graphical problem is solved. It was due to VISTA aero and its use of the bit-planes. It can be cured by adding "PFD_SUPPORT_GDI" in the SetDCPixelFormat routine. In this case the window which hosts the application willswitch over to theVISTA basic mode automatically.
Now I have a second very basic problem which seems to appear stocastically. During the linking phase i sometimes receive the
fatal error LNK2023: bad DLL or entry point 'msobj80.dll'
most often in debug mode. Ienclose some info. concerningwhat is installed onmy machine.
Best regards
Bosse
Microsoft Visual Studio 2005
Version 8.0.50727.867 (vsvista.050727-8600)
Microsoft .NET Framework
Version 2.0.50727
Installed Edition: IDE Standard
Intel Fortran Compiler Integration
Intel Fortran Compiler Integration for Microsoft Visual Studio 2005, 10.1.3885.2005, Copyright (C) 2002-2007 Intel Corporation
Microsoft Visual Studio 2005 Premier Partner Edition - ENU Service Pack 1 (KB926601)
This service pack is for Microsoft Visual Studio 2005 Premier Partner Edition - ENU.
If you later install a more recent service pack, this service pack will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/926601
Update for Microsoft Visual Studio 2005 Premier Partner Edition - ENU (KB932232)
This Update is for Microsoft Visual Studio 2005 Premier Partner Edition - ENU.
If you later install a more recent service pack, this Update will be uninstalled automatically.
For more information, visit http://support.microsoft.com/kb/932232
System Information report written at: 01/29/08 17:51:36
System Name: BOTO13-2
[System Summary]
ItemValue
OS NameMicrosoft Windows Vista Business
Version6.0.6000 Build 6000
Other OS Description Not Available
OS ManufacturerMicrosoft Corporation
System NameBOTO13-2
System ManufacturerDell Inc.
System ModelPrecision WorkStation 390
System Typex64-based PC
ProcessorIntel Core2 CPU 6420 @ 2.13GHz, 2133 Mhz, 2 Core(s), 2 Logical Processor(s)
BIOS Version/DateDell Inc. 2.4.0, 2007-07-28
SMBIOS Version2.3
Windows DirectoryC:Windows
System DirectoryC:Windowssystem32
Boot DeviceDeviceHarddiskVolume2
LocaleSverige
Hardware Abstraction LayerVersion = "6.0.6000.20500"
User NameIEIoto13
Time ZoneW. Europe Standard Time
Total Physical Memory2045,04 MB
Available Physical Memory874,26 MB
Total Virtual Memory4,21 GB
Available Virtual Memory2,97 GB
Page File Space2,29 GB
Page FileC:pagefile.sys
[Hardware Resources]
[Conflicts/Sharing]
ResourceDevice
I/O Port 0x0 0000000-0x00000CF7PCI bus
I/O Port 0x00000000-0x00000CF7Direct memory access controller
I/O Port 0x000003C0-0x000003DFIntel 975X PCI Express Root Port - 277D
I/O Port 0x000003C0-0x000003DFNVIDIA Quadro FX 550
IRQ 21Intel 82801GB USB Universal Host Controller - 27C8
IRQ 21Intel 82801GB USB2 Enhanced Host Controller - 27CC
Memory Address 0xE8000000-0xEFFFFFFFIntel 975X PCI Express Root Port - 277D
Memory Address 0xE8000000-0xEFFFFFFFNVIDIA Quadro FX 550
Memory Address 0xC0000-0xEFFFFPCI bus
Memory Address 0xC0000-0xEFFFFSystem board
IRQ 16Intel 975X PCI Express Root Port - 277D
IRQ 16NVIDIA Quadro FX 550
IRQ 16High Definition Audio Controller
IRQ 16Intel 82801G (ICH7 Family) PCI Express Root Port - 27D0
IRQ 16Intel 82801GR/GH/GHM (ICH7 Family) PCI Express Root Port - 27E0
Memory Address 0xF0000-0xFFFFFPCI bus
Memory Address 0xF0000-0xFFFFFSystem board
Memory Address 0xA0000-0xBFFFFPCI bus
Memory Address 0xA0000-0xBFFFFIntel 975X PCI Express Root Port - 277D
Memory Address 0xA0000-0xBFFFFNVIDIA Quadro FX 550
I/O Port 0x000003B0-0x000003BBIntel 975X PCI Express Root Port - 277D
I/O Port 0x000003B0-0x000003BBNVIDIA Quadro FX 550
Memory Address 0xF8000000-0xFEAFFFFFIntel 975X PCI Express Root Port - 277D
Memory Address 0xF8000000-0xFEAFFFFFNVIDIA Quadro FX 550
Memory Address 0xFF980800-0xFF980BFFPCI bus
Memory Address 0xFF980800-0xFF980BFFIntel 82801GB USB2 Enhanced Host Controller - 27CC
[DMA]
ResourceDeviceStatus
Channel 4Direct memory access controllerOK
Channel 2Standard floppy disk controllerOK
[Forced Hardware]
DevicePNP Device ID
[I/O]
0x00000000-0x00000CF7PCI busOK
0x00000000-0x00000CF7Direct memory access controllerOK
0x00000D00-0x0000FFFFPCI busOK
0x000003B0-0x000003BBIntel 975X PCI Express Root Port - 277DOK
0x000003B0-0x000003BBNVIDIA Quadro FX 550OK
0x000003C0-0x000003DFIntel 975X PCI Express Root Port - 277DOK
0x000003C0-0x000003DFNVIDIA Quadro FX 550OK
0x0000FF80-0x0000FF9FIntel 82801GB USB Universal Host Controller - 27C8OK
0x0000FF60-0x0000FF7FIntel 82801GB USB Universal Host Controller - 27C9OK
0x0000FF40-0x0000FF5FIntel 82801GB USB Universal Host Controller - 27CAOK
0x0000FF20-0x0000FF3FIntel 82801GB USB Universal Host Controller - 27CBOK
0x00000060-0x00000060System boardOK
0x00000064-0x00000064System boardOK
0x00000062-0x00000063System boardOK
0x00000065-0x0000006FSystem boardOK
0x000000E0-0x000000EFSystem boardOK
0x00000800-0x00000 85FSystem boardOK
0x00000C00-0x00000C7FSystem boardOK
0x00000860-0x000008FFSystem boardOK
0x00000080-0x0000009FDirect memory access controllerOK
0x000000C0-0x000000DFDirect memory access controllerOK
0x000000F0-0x000000FFNumeric data processorOK
0x00000020-0x0000003FProgrammable interrupt controllerOK
0x000000A0-0x000000BFProgrammable interrupt controllerOK
0x000004D0-0x000004D1Programmable interrupt controllerOK
0x00000061-0x00000061System speakerOK
0x00000070-0x0000007FSystem CMOS/real time clockOK
0x00000040-0x0000005FSystem timerOK
0x000003F0-0x000003F5Standard floppy disk controllerOK
0x000003F7-0x000003F7Standard floppy disk controllerOK
0x00000378-0x0000037FECP Printer Port (LPT1)OK
0x00000778-0x0000077FECP Printer Port (LPT1)OK
0x000003F8-0x000003FFCommunications Port (COM1)OK
0x0000FFA0-0x0000FFAFIntel 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DFOK
0x000001F0-0x000001F7IDE ChannelOK
0x000003F6-0x000003F6IDE ChannelOK
0x0000FE00-0x0000FE07Standard AHCI 1.0 Serial ATA ControllerOK
0x0000FE10-0x0000FE13Standard AHCI 1.0 Serial ATA ControllerOK
0x0000FE20-0x0000FE27Standard AHCI 1.0 Serial ATA ControllerOK
0x0000FE30-0x0000FE33Standard AHCI 1.0 Serial ATA ControllerOK
0x0000FEC0-0x0000FECFStandard AHCI 1.0 Serial ATA ControllerOK
0x0000ECE0-0x0000ECFFIntel 82801G (ICH7 Family) SMBus Controller - 27DAOK
[IRQs]
IRQ 80Microsoft ACPI-Compliant SystemOK
IRQ 81Microsoft ACPI-Compliant SystemOK
IRQ 82Microsoft ACPI-Compliant SystemOK
IRQ 83Microsoft ACPI-Compliant SystemOK
IRQ 84Microsoft ACPI-Compliant SystemOK
IRQ 85Microsoft ACPI-Compliant SystemOK
IRQ 86Microsoft ACPI-Compliant SystemOK
IRQ 87Microsoft ACPI-Compliant SystemOK
IRQ 88Microsoft ACPI-Compliant SystemOK
IRQ 89Microsoft ACPI-Compliant SystemOK
IRQ 90Microsoft ACPI-Compliant SystemOK
IRQ 91Microsoft ACPI-Compliant SystemOK
IRQ 92Microsoft ACPI-Compliant SystemOK
IRQ 93Microsoft ACPI-Compliant SystemOK
IRQ 94Microsoft ACPI-Compliant SystemOK
IRQ 95Microsoft ACPI-Compliant SystemOK
IRQ 96Microsoft ACPI-Compliant SystemOK
IRQ 97Microsoft ACPI-Compliant SystemOK
IRQ 98Microsoft ACPI-Compliant SystemOK
IRQ 99Microsoft ACPI-Compliant SystemOK
IRQ 100Microsoft ACPI-Compliant SystemOK
IRQ 101Microsoft ACPI-Compliant SystemOK
IRQ 102Microsoft ACPI-Compliant SystemOK
IRQ 103Microsoft ACPI-Compliant SystemOK
IRQ 104Microsoft ACPI-Compliant SystemOK
IRQ 105M icrosoft ACPI-Compliant SystemOK
IRQ 106Microsoft ACPI-Compliant SystemOK
IRQ 107Microsoft ACPI-Compliant SystemOK
IRQ 108Microsoft ACPI-Compliant SystemOK
IRQ 109Microsoft ACPI-Compliant SystemOK
IRQ 110Microsoft ACPI-Compliant SystemOK
IRQ 111Microsoft ACPI-Compliant SystemOK
IRQ 112Microsoft ACPI-Compliant SystemOK
IRQ 113Microsoft ACPI-Compliant SystemOK
IRQ 114Microsoft ACPI-Compliant SystemOK
IRQ 115Microsoft ACPI-Compliant SystemOK
IRQ 116Microsoft ACPI-Compliant SystemOK
IRQ 117Microsoft ACPI-Compliant SystemOK
IRQ 118Microsoft ACPI-Compliant SystemOK
IRQ 119Microsoft ACPI-Compliant SystemOK
IRQ 120Microsoft ACPI-Compliant SystemOK
IRQ 121Microsoft ACPI-Compliant SystemOK
IRQ 122Microsoft ACPI-Compliant SystemOK
IRQ 123Microsoft ACPI-Compliant SystemOK
IRQ 124Microsoft ACPI-Compliant SystemOK
IRQ 125Microsoft ACPI-Compliant SystemOK
IRQ 126Microsoft ACPI-Compliant SystemOK
IRQ 127Microsoft ACPI-Compliant SystemOK
IRQ 128Microsoft ACPI-Compliant SystemOK
IRQ 129Microsoft ACPI-Compliant SystemOK
IRQ 130Microsoft ACPI-Compliant SystemOK
IRQ 131Microsoft ACPI-Compliant SystemOK
IRQ 132Microsoft ACPI-Compliant SystemOK
IRQ 133Microsoft ACPI-Compliant SystemOK
IRQ 134Microsoft ACPI-Compliant SystemOK
IRQ 135Microsoft ACPI-Compliant SystemOK
IRQ 136Microsoft ACPI-Compliant SystemOK
IRQ 137Microsoft ACPI-Compliant SystemOK
IRQ 138Microsoft ACPI-Compliant SystemOK
IRQ 139Microsoft ACPI-Compliant SystemOK
IRQ 140Microsoft ACPI-Compliant SystemOK
IRQ 141Microsoft ACPI-Compliant SystemOK
IRQ 142Microsoft ACPI-Compliant SystemOK
IRQ 143Microsoft ACPI-Compliant SystemOK
IRQ 144Microsoft ACPI-Compliant SystemOK
IRQ 145Microsoft ACPI-Compliant SystemOK
IRQ 146Microsoft ACPI-Compliant SystemOK
IRQ 147Microsoft ACPI-Compliant SystemOK
IRQ 148Microsoft ACPI-Compliant SystemOK
IRQ 149Microsoft ACPI-Compliant SystemOK
IRQ 150Microsoft ACPI-Compliant SystemOK
IRQ 151Microsoft ACPI-Compliant SystemOK
IRQ 152Microsoft ACPI-Compliant SystemOK
IRQ 153Microsoft ACPI-Compliant SystemOK
IRQ 154Microsoft ACPI-Compliant SystemOK
IRQ 155Microsoft ACPI-Compliant SystemOK
IRQ 156Microsoft ACPI-Compliant SystemOK
IRQ 157Microsoft ACPI-Compliant SystemOK
IRQ 158Microsoft ACPI-Compliant SystemOK
IRQ 159Microsoft ACPI-Compliant SystemOK
IRQ 160Microsoft ACPI-Compliant SystemOK
IRQ 161Microsoft ACPI-Compliant Syst emOK
IRQ 162Microsoft ACPI-Compliant SystemOK
IRQ 163Microsoft ACPI-Compliant SystemOK
IRQ 164Microsoft ACPI-Compliant SystemOK
IRQ 165Microsoft ACPI-Compliant SystemOK
IRQ 166Microsoft ACPI-Compliant SystemOK
IRQ 167Microsoft ACPI-Compliant SystemOK
IRQ 168Microsoft ACPI-Compliant SystemOK
IRQ 169Microsoft ACPI-Compliant SystemOK
IRQ 170Microsoft ACPI-Compliant SystemOK
IRQ 171Microsoft ACPI-Compliant SystemOK
IRQ 172Microsoft ACPI-Compliant SystemOK
IRQ 173Microsoft ACPI-Compliant SystemOK
IRQ 174Microsoft ACPI-Compliant SystemOK
IRQ 175Microsoft ACPI-Compliant SystemOK
IRQ 176Microsoft ACPI-Compliant SystemOK
IRQ 177Microsoft ACPI-Compliant SystemOK
IRQ 178Microsoft ACPI-Compliant SystemOK
IRQ 179Microsoft ACPI-Compliant SystemOK
IRQ 180Microsoft ACPI-Compliant SystemOK
IRQ 181Microsoft ACPI-Compliant SystemOK
IRQ 182Microsoft ACPI-Compliant SystemOK
IRQ 183Microsoft ACPI-Compliant SystemOK
IRQ 184Microsoft ACPI-Compliant SystemOK
IRQ 185Microsoft ACPI-Compliant SystemOK
IRQ 186Microsoft ACPI-Compliant SystemOK
IRQ 187Microsoft ACPI-Compliant SystemOK
IRQ 188Microsoft ACPI-Compliant SystemOK
IRQ 189Microsoft ACPI-Compliant SystemOK
IRQ 190Microsoft ACPI-Compliant SystemOK
IRQ 16Intel 975X PCI Express Root Port - 277DOK
IRQ 16NVIDIA Quadro FX 550OK
IRQ 16High Definition Audio ControllerOK
IRQ 16Intel 82801G (ICH7 Family) PCI Express Root Port - 27D0OK
IRQ 16Intel 82801GR/GH/GHM (ICH7 Family) PCI Express Root Port - 27E0OK
IRQ 17Intel 82801GR/GH/GHM (ICH7 Family) PCI Express Root Port - 27E2OK
IRQ 4294967294Broadcom NetXtreme 57xx Gigabit ControllerOK
IRQ 21Intel 82801GB USB Universal Host Controller - 27C8OK
IRQ 21Intel 82801GB USB2 Enhanced Host Controller - 27CCOK
IRQ 22Intel 82801GB USB Universal Host Controller - 27C9OK
IRQ 18Intel 82801GB USB Universal Host Controller - 27CAOK
IRQ 23Intel 82801GB USB Universal Host Controller - 27CBOK
IRQ 13Numeric data processorOK
IRQ 8System CMOS/real time clockOK
IRQ 0System timerOK
IRQ 6Standard floppy disk controllerOK
IRQ 4Communications Port (COM1)OK
IRQ 14IDE ChannelOK
IRQ 20Standard AHCI 1.0 Serial ATA ControllerOK
IRQ 10Intel 82801G (ICH7 Family) SMBus Controller - 27DAOK
[Memory]
0xA0000-0xBFFFFPCI busOK
0xA0000-0xBFFFFIntel 975X PCI Express Root Port - 277DOK
0xA0000-0xBFFFFNVIDIA Quadro FX 550OK
0xC0000-0xEFFFF& nbsp;PCI busOK
0xC0000-0xEFFFFSystem boardOK
0xF0000-0xFFFFFPCI busOK
0xF0000-0xFFFFFSystem boardOK
0xF4000000-0xFEC00000PCI busOK
0x80000000-0xEFFFFFFFPCI busOK
0xFF980800-0xFF980BFFPCI busOK
0xFF980800-0xFF980BFFIntel 82801GB USB2 Enhanced Host Controller - 27CCOK
0xFF97C000-0xFF97FFFFPCI busOK
0xFED20000-0xFED9FFFFPCI busOK
0xF8000000-0xFEAFFFFFIntel 975X PCI Express Root Port - 277DOK
0xF8000000-0xFEAFFFFFNVIDIA Quadro FX 550OK
0xE8000000-0xEFFFFFFFIntel 975X PCI Express Root Port - 277DOK
0xE8000000-0xEFFFFFFFNVIDIA Quadro FX 550OK
0xFD000000-0xFDFFFFFFNVIDIA Quadro FX 550OK
0xFEBFC000-0xFEBFFFFFHigh Definition Audio ControllerOK
0xF7F00000-0xF7FFFFFFIntel 82801G (ICH7 Family) PCI Express Root Port - 27D0OK
0xF7E00000-0xF7EFFFFFIntel 82801GR/GH/GHM (ICH7 Family) PCI Express Root Port - 27E2OK
0xF7EF0000-0xF7EFFFFFBroadcom NetXtreme 57xx Gigabit ControllerOK
0xFF97FC00-0xFF97FFFFStandard AHCI 1.0 Serial ATA ControllerOK
0x0000-0x9FFFFSystem boardOK
0x100000-0xFFFFFFSystem boardOK
0x1000000-0x7FE0ABFFSystem boardOK
0xFEC00000-0xFECFFFFFSystem boardOK
0xFEE00000-0xFEEFFFFFSystem boardOK
0xFFB00000-0xFFBFFFFFSystem boardOK
0xFFC00000-0xFFFFFFFFSystem boardOK
0xF0000000-0xF3FFFFFFMotherboard resourcesOK
0xFEDA0000-0xFEDACFFFMotherboard resourcesOK
0xFED00000-0xFED003FFHigh precision event timerOK
[Components]
[Multimedia]
[Audio Codecs]
CODECManufacturerDescriptionStatusFileVersionSizeCreation Date
c:windowssystem32msadp32.acmMicrosoft CorporationOKC:Windowssystem32MSADP32.ACM6.0.6000.1638622,00 KB (22528 bytes)2006-11-02 10:53
c:windowssystem32msgsm32.acmMicrosoft CorporationOKC:Windowssystem32MSGSM32.ACM6.0.6000.1638628,00 KB (28672 bytes)2006-11-02 10:53
c:windowssystem32imaadp32.acmMicrosoft CorporationOKC:Windowssystem32IMAADP32.ACM6.0.6000.1638621,00 KB (21504 bytes)2006-11-02 10:53
c:windowssystem32msg711.acmMicrosoft CorporationOKC:Windowssystem32MSG711.ACM6.0.6000.1638614,00 KB (14336 bytes)2006-11-02 10:53
c:windowssystem32l3codeca.acmFraunhofer Institut Integrierte Schaltungen IISFraunhofer IIS MPEG Layer-3 CodecOKC:Windowssystem32L3CODECA.ACM1.9.0.40170,50 KB (72192 bytes)2006-11-02 16:02
[Video Codecs]
c:windowssystem32iyuv_32.dllMicrosoft CorporationOKC:Windowssystem32IYUV_32.DLL6.0.6000.1638652,50 KB (53760 bytes)2006-11-02 10:43
c:windowssystem32msyuv.dllMicrosoft CorporationOKC:Windowssystem32MSYUV.DLL6.0.6000.1638624,50 KB (25088 bytes)2006-11-02 10:43
c:windowssystem32msvidc32.dllMicrosoft CorporationOKC:Windowssystem32MSVIDC32.DLL6.0.6000.1651337,50 KB (38400 bytes)2007-11-21 16:36
c:windowssystem32msrle32.dllMicrosoft CorporationOKC:Windowssystem32MSRLE32.DLL6.0.6000.1651315,50 KB (15872 bytes)2007-11-21 16:36
c:windowssystem32 sbyuv.dllMicrosoft CorporationOKC:Windowssystem32TSBYUV.DLL6.0.6000.1638613,50 KB (13824 bytes)2006-11-02 10:43
[CD-ROM]
ItemValue
DriveE:
DescriptionCD-ROM Drive
Media LoadedNo
Media TypeUNKNOWN
NameHL-DT-ST DVD+-RW GSA-H53N ATA Device
Manufacturer(Standard CD-ROM drives)
StatusOK
Transfer Rate-1.00 kbytes/sec
SCSI Target ID0
PNP Device IDIDECDROMHL-DT-ST_DVD+-RW_GSA-H53N_______________B104____5&44E1900&0&0.0.0
Driverc:windowssystem32driverscdrom.sys (6.0.6000.16386, 78,00 KB (79872 bytes), 2006-11-02 10:38)
[Sound Device]
ItemValue
NameHigh Definition Audio Device
StatusOK
PNP Device IDHDAUDIOFUNC_01&VEN_8384&DEV_7690&SUBSYS_102801DE&REV_10224&7ADDD11&0&0001
Driverc:windowssystem32drivershdaudio.sys (6.0.5840.16387, 267,50 KB (273920 bytes), 2006-11-02 13:41)
[Display]
ItemValue
NameNVIDIA Quadro FX 550
PNP Device IDPCIVEN_10DE&DEV_014D&SUBSYS_034910DE&REV_A24&35682461&0&0008
Adapter TypeQuadro FX 550, NVIDIA compatible
Adapter DescriptionNVIDIA Quadro FX 550
Adapter RAM128,00 MB (134217728 bytes)
Installed Driversnvd3dum,nvd3dumx.dll,nvwgf2um,nvwgf2umx.dll
Driver Version7.15.11.6369
INF Fileoem1.inf (nv_NV3x section)
Color PlanesNot Available
Color Table Entries4294967296
Resolution1920 x 1200 x 59 hertz
Bits/Pixel32
Memory Address0xF8000000-0xFEAFFFFF
Memory Address0xE8000000-0xEFFFFFFF
Memory Address0xFD000000-0xFDFFFFFF
IRQ ChannelIRQ 16
I/O Port0x000003B0-0x000003BB
I/O Port0x000003C0-0x000003DF
Memory Address0xA0000-0xBFFFF
Driverc:windowssystem32drivers vlddmkm.sys (7.15.11.6369, 9,22 MB (9671840 bytes), 2007-09-12 06:28)
[Infrared]
ItemValue
[Input]
[Keyboard]
ItemValue
DescriptionUSB Human Interface Device
NameEnhanced (101- or 102-key)
Layout0000041D
PNP Device IDUSBVID_046D&PID_C517&MI_006&13E418EA&0&0000
Number of Function Keys12
Driverc:windowssystem32drivershidusb.sys (6.0.6000.16386, 15,50 KB (15&nb sp;872 bytes), 2006-11-02 10:43)
[Pointing Device]
ItemValue
Hardware TypeHID-compliant mouse
Number of Buttons0
StatusOK
PNP Device IDHIDVID_046D&PID_C517&MI_01&COL017&9D1D79&0&0000
Power Management SupportedNo
Double Click ThresholdNot Available
HandednessNot Available
Driverc:windowssystem32driversmouhid.sys (6.0.6000.16386, 19,50 KB (19968 bytes), 2006-11-02 10:37)
[Modem]
ItemValue
[Network]
[Adapter]
ItemValue
Name[00000000] WAN Miniport (L2TP)
Adapter TypeNot Available
Product TypeWAN Miniport (L2TP)
InstalledYes
PNP Device IDROOTMS_L2TPMINIPORT�000
Last Reset2008-01-29 17:32
Index0
Service NameRasl2tp
IP AddressNot Available
IP SubnetNot Available
Default IP GatewayNot Available
DHCP EnabledNo
DHCP ServerNot Available
DHCP Lease ExpiresNot Available
DHCP Lease ObtainedNot Available
MAC AddressNot Available
Driverc:windowssystem32drivers asl2tp.sys (6.0.6000.16386, 101,00 KB (103424 bytes), 2006-11-02 10:47)
Name[00000001] WAN Miniport (PPTP)
Adapter TypeWide Area Network (WAN)
Product TypeWAN Miniport (PPTP)
InstalledYes
PNP Device IDROOTMS_PPTPMINIPORT�000
Index1
Service NamePptpMiniport
DHCP EnabledNo
MAC Address50:50:54:50:30:30
Driverc:windowssystem32drivers aspptp.sys (6.0.6000.16386, 76,50 KB (78336 bytes), 2006-11-02 10:47)
Name[00000002] WAN Miniport (PPPOE)
Product TypeWAN Miniport (PPPOE)
InstalledYes
PNP Device IDROOTMS_PPPOEMINIPORT�000
Index2
Service NameRasPppoe
DHCP EnabledNo
MAC Address33:50:6F:45:30:30
Driverc:windowssystem32drivers aspppoe.sys (6.0.6000.16386, 49,00 KB (50176 bytes), 2006-11-02 10:47)
Name[00000003] WAN Miniport (IPv6)
Product TypeWAN Miniport (IPv6)
InstalledYes
PNP Device IDROOTMS_NDISWANIPV6�000
Index3
Service NameNdisWan
Def ault IP GatewayNot Available
DHCP EnabledNo
Driverc:windowssystem32drivers diswan.sys (6.0.6000.16386, 137,00 KB (140288 bytes), 2006-11-02 10:47)
Name[00000004] Broadcom NetXtreme 57xx Gigabit Controller
Adapter TypeEthernet 802.3
Product TypeBroadcom NetXtreme 57xx Gigabit Controller
InstalledYes
PNP Device IDPCIVEN_14E4&DEV_167A&SUBSYS_01DE1028&REV_024&24AC2E11&0&00E5
Index4
Service Nameb57nd60a
IP Address130.236.37.234, fe80::752f:9db8:775f:bb33
IP Subnet255.255.248.0, 64
Default IP Gateway130.236.36.1
DHCP EnabledYes
DHCP Server130.236.35.24
DHCP Lease Expires2008-02-01 17:32
DHCP Lease Obtained2008-01-29 17:32
MAC Address00:1D:09:12:ED:6E
Memory Address0xF7EF0000-0xF7EFFFFF
IRQ ChannelIRQ 4294967294
Driverc:windowssystem32drivers57nd60a.sys (9.20.0.3, 191,50 KB (196096 bytes), 2006-11-02 13:40)
Name[00000005] Microsoft ISATAP Adapter
Adapter TypeTunnel
Product TypeMicrosoft ISATAP Adapter
InstalledYes
PNP Device IDROOT*ISATAP�000
Index5
Service Nametunnel
DHCP EnabledNo
Driverc:windowssystem32drivers unnel.sys (6.0.6000.16501, 27,50 KB (28160 bytes), 2007-11-21 16:38)
Name[00000006] WAN Miniport (IP)
Product TypeWAN Miniport (IP)
InstalledYes
PNP Device IDROOTMS_NDISWANIP�000
Index6
Service NameNdisWan
DHCP EnabledNo
Name[00000007] Microsoft 6to4 Adapter
Adapter TypeTunnel
Product TypeMicrosoft 6to4 Adapter
InstalledYes
PNP Device IDROOT*6TO4MP�001
Index7
Service Nametunnel
DHCP EnabledNo
DHCP L ease ExpiresNot Available
Name[00000009] RAS Async Adapter
Product TypeRAS Async Adapter
InstalledYes
PNP Device IDNot Available
Index9
Service NameAsyncMac
DHCP EnabledNo
[Protocol]
ItemValue
NameMSAFD Tcpip [TCP/IP]
Connectionless ServiceNo
Guarantees DeliveryYes
Guarantees SequencingYes
Maximum Address Size16 bytes
Maximum Message Size0 bytes
Message OrientedNo
Minimum Address Size16 bytes
Pseudo Stream OrientedNo
Supports BroadcastingNo
Supports Connect DataNo
Supports Disconnect DataNo
Supports EncryptionNo
Supports Expedited DataYes
Supports Graceful ClosingYes
Supports Guaranteed BandwidthNo
Supports MulticastingNo
NameMSAFD Tcpip [UDP/IP]
Connectionless ServiceYes
Guarantees DeliveryNo
Guarantees SequencingNo
Maximum Message Size63,99 KB (65527 bytes)
Message OrientedYes
Supports BroadcastingYes
Supports Expedited DataNo
Supports Graceful ClosingNo
Supports MulticastingYes
NameMSAFD Tcpip [TCP/IPv6]
Maximum Address Size28 bytes
Message OrientedNo
Minimum Address Size28 bytes
NameMSAFD Tcpip [UDP/IPv6]
Message OrientedYes
Supports Broadc astingYes
NameRSVP TCPv6 Service Provider
Message OrientedNo
Supports EncryptionYes
NameRSVP TCP Service Provider
Message OrientedNo
NameRSVP UDPv6 Service Provider
Message OrientedYes
NameRSVP UDP Service Provider
Message OrientedYes
[WinSock]
ItemValue
Filec:windowssyswow64wsock32.dll
Size14,50 KB (14848 bytes)
Version6.0.6000.16386
Filec:windowssystem32wsock32.dll
Size18,00 KB (18432 b ytes)
[Ports]
[Serial]
ItemValue
NameCommunications Port (COM1)
StatusOK
PNP Device IDACPIPNP05011
Maximum Input Buffer Size0
Maximum Output Buffer SizeNo
Settable Baud RateYes
Settable Data BitsYes
Settable Flow ControlYes
Settable ParityYes
Settable Parity CheckYes
Settable Stop BitsYes
Settable RLSDYes
Supports RLSDYes
Supports 16 Bit ModeNo
Supports Special CharactersNo
Baud Rate9600
Bits/Byte8
Stop Bits1
ParityNone
BusyNo
Abort Read/Write on ErrorNo
Binary Mode EnabledYes
Continue XMit on XOffNo
CTS Outflow ControlNo
Discard NULL BytesNo
DSR Outflow Control0
DSR Sensitivity0
DTR Flow Control TypeEnable
EOF Character0
Error Replace Character0
Error Replacement EnabledNo
Event Character0
Parity Check EnabledNo
RTS Flow Control TypeEnable
XOff Character19
XOffXMit Threshold512
XOn Character17
XOnXMit Threshold2048
XOnXOff InFlow Control0
XOnXOff OutFlow Control0
I/O Port0x000003F8-0x000003FF
IRQ ChannelIRQ 4
Driverc:windowssystem32driversserial.sys (6.0.6000.16386, 92,00 KB (94208 bytes), 2006-11-02 10:38)
[Parallel]
ItemValue
NameLPT1
PNP Device IDACPIPNP04014&E5ACEE3&0
I/O Port0x00000378-0x0000037F
I/O Port0x00000778-0x0000077F
Driverc:windowssystem32driversparport.sys (6.0.6000.16386, 94,50 KB (96768 bytes), 2006-11-02 10:37)
[Storage]
[Drives]
ItemValue
DriveB:
Description3 1/2 Inch Floppy Drive
DriveC:
DescriptionLocal Fixed Disk
CompressedNo
File SystemNTFS
Size87,89 GB (94371835904 bytes)
Free Space57,03 GB (61232549888 bytes)
Volume Name
Volume Serial Number8A984394
DriveE:
DescriptionCD-ROM Disc
DriveX:
DescriptionNetwork Connection
Provider Namegarpotor
DriveY:
Provider NamewebWWWrootsolid
DriveZ:
Provider Nameaxel.ad.iei.liu.seusers_a-coto13
[Disks]
ItemValue
DescriptionDisk drive
Manufacturer(Standard disk drives)
ModelSAMSUNG HD161HJ ATA Device
Bytes/Sector512
Media LoadedYes
Media TypeFixed hard disk
Partitions2
SCSI Bus0
SCSI Logical Unit0  ;
SCSI Port1
SCSI Target ID0
Sectors/Track63
Size149,01 GB (159998146560 bytes)
Total Cylinders19452
Total Sectors312496380
Total Tracks4960260
Tracks/Cylinder255
PartitionDisk #0, Partition #0
Partition Size62,72 MB (65769984 bytes)
Partition Starting Offset32256 bytes
PartitionDisk #0, Partition #1
Partition Size87,89 GB (94371840000 bytes)
Partition Starting Offset66060288 bytes
[SCSI]
ItemValue
NameMicrosoft iSCSI Initiator
StatusOK
PNP Device IDROOTISCSIPRT�000
Driverc:windowssystem32driversmsiscsi.sys (6.0.6000.16386, 194,60 KB (199272 bytes), 2006-11-02 10:40)
[IDE]
ItemValue
NameIntel 82801G (ICH7 Family) Ultra ATA Storage Controllers - 27DF
ManufacturerIntel
StatusOK
PNP Device IDPCIVEN_8086&DEV_27DF&SUBSYS_01DE1028&REV_013&172E68DD&0&F9
I/O Port0x0000FFA0-0x0000FFAF
Driverc:windowssystem32driversintelide.sys (6.0.6000.16584, 18,55 KB (19000 bytes), 2008-01-09 04:01)
NameIDE Channel
Manufacturer(Standard IDE ATA/ATAPI controllers)
StatusOK
PNP Device IDPCIIDEIDECHANNEL4&43794&0&0
I/O Port0x000001F0-0x000001F7
I/O Port0x000003F6-0x000003F6
IRQ ChannelIRQ 14
Driverc:windowssystem32driversatapi.sys (6.0.6000.16584, 22,05 KB (22584 bytes), 2008-01-09 04:01)
NameStandard AHCI 1.0 Serial ATA Controller
ManufacturerStandard AHCI 1.0 Serial ATA Controller
StatusOK
PNP Device IDPCIVEN_8086&DEV_27C1&SUBSYS_01DE1028&REV_013&172E68DD&0&FA
I/O Port0x0000FE00-0x0000FE07
I/O Port0x0000FE10-0x0000FE13
I/O Port0x0000FE20-0x0000FE27
I/O Port0x0000FE30-0x0000FE33
I/O Port0x0000FEC0-0x0000FECF
Memory Address0xFF97FC00-0xFF97FFFF
IRQ ChannelIRQ 20
Driverc:windowssystem32driversmsahci.sys (6.0.6000.16584, 26,55 KB (27192 bytes), 2008-01-09 04:01)
NameIDE Channel
StatusOK
PNP Device IDPCIIDEIDECHANNEL4&302BF1C2&0&0
NameIDE Channel
StatusOK
PNP Device IDPCIIDEIDECHANNEL4&302BF1C2&0&1
NameIDE Channel
StatusOK
PNP Device IDPCIIDEIDECHANNEL4&3 02BF1C2&0&2
NameIDE Channel
StatusOK
PNP Device IDPCIIDEIDECHANNEL4&302BF1C2&0&3
[Printing]
NameDriverPort NameServer Name
Adobe PDFAdobe PDF ConverterDocuments*.pdf
Microsoft XPS Document WriterMicrosoft XPS Document WriterXPSPort:
atlas oshiba_06TOSHIBA e-STUDIO3510cSeries PS3IP_130.236.35.177
[Problem Devices]
DevicePNP Device IDError Code
[USB]
DevicePNP Device ID
Intel 82801GB USB Universal Host Controller - 27C8PCIVEN_8086&DEV_27C8&SUBSYS_01DE1028&REV_013&172E68DD&0&E8
Intel 82801GB USB Universal Host Controller - 27C9PCIVEN_8086&DEV_27C9&SUBSYS_01DE1028&REV_013&172E68DD&0&E9
Intel 82801GB USB Universal Host Controller - 27CAPCIVEN_8086&DEV_27CA&SUBSYS_01DE1028&REV_013&172E68DD&0&EA
Intel 82801GB USB Universal Host Controller - 27CBPCIVEN_8086&DEV_27CB&SUBSYS_01DE1028&REV_013&172E68DD&0&EB
Intel 82801GB USB2 Enhanced Host Controller - 27CCPCIVEN_8086&DEV_27CC&SUBSYS_01DE1028&REV_013&172E68DD&0&EF
[Software Environment]
[System Drivers]
NameDescriptionFileTypeStartedStart ModeStateStatusError ControlAccept PauseAccept Stop
acpiMicrosoft ACPI Driverc:windowssystem32driversacpi.sysKernel DriverYesBootRunningOKCriticalNoYes
adp94xxadp94xxc:windowssystem32driversadp94xx.sysKernel DriverNoDisabledStoppedOKNormalNoNo
adpahciadpahcic:windowssystem32driversadpahci.sysKernel DriverNoDisabledStoppedOKNormalNoNo
adpu160madpu160mc:windowssystem32driversadpu160m.sysKernel DriverNoDisabledStoppedOKNormalNoNo
adpu320adpu320c:windowssystem32driversadpu320.sysKernel DriverNoDisabledStoppedOKNormalNoNo
afdAncilliary Function Driver for Winsockc:windowssystem32driversafd.sysKernel DriverYesSystemRunningOKNormalNoYes
agp440Intel AGP Bus Filterc:windowssystem32driversagp440.sysKernel DriverNoManualStoppedOKNormalNoNo
aic78xxaic78xxc:windowssystem32driversdjsvs.sysKernel DriverNoDisabledStoppedOKNormalNoNo
aliidealiidec:windowssystem32driversaliide.sysKernel DriverNoDisabledStoppedOKCriticalNoNo
amdide&n bsp;amdidec:windowssystem32driversamdide.sysKernel DriverNoDisabledStoppedOKCriticalNoNo
amdk8AMD K8 Processor Driverc:windowssystem32driversamdk8.sysKernel DriverNoDisabledStoppedOKNormalNoNo
arcarcc:windowssystem32driversarc.sysKernel DriverNoDisabledStoppedOKNormalNoNo
arcsasarcsasc:windowssystem32driversarcsas.sysKernel DriverNoDisabledStoppedOKNormalNoNo
asyncmacRAS Asynchronous Media Driverc:windowssystem32driversasyncmac.sysKernel DriverNoManualStoppedOKNormalNoNo
atapiIDE Channelc:windowssystem32driversatapi.sysKernel DriverYesBootRunningOKCriticalNoYes
b57nd60aBroadcom NetXtreme Gigabit Ethernet - NDIS 6.0c:windowssystem32drivers57nd60a.sysKernel DriverYesManualRunningOKNormalNoYes
bowserBowserc:windowssystem32driversowser.sysFile System DriverYesManualRunningOKNormalNoYes
brfiltloBrother USB Mass-Storage Lower Filter Driverc:windowssystem32driversrfiltlo.sysKernel DriverNoManualStoppedOKNormalNoNo
brfiltupBrother USB Mass-Storage Upper Filter Driverc:windowssystem32driversrfiltup.sysKernel DriverNoManualStoppedOKNormalNoNo
brseridBrother MFC Serial Port Interface Driver (WDM)c:windowssystem32driversrserid.sysKernel DriverNoDisabledStoppedOKNormalNoNo
brserwdmBrother WDM Serial driverc:windowssystem32driversrserwdm.sysKernel DriverNoDisabledStoppedOKNormalNoNo
brusbmdmBrother MFC USB Fax Only Modemc:windowssystem32driversrusbmdm.sysKernel DriverNoDisabledStoppedOKNormalNoNo
brusbserBrother MFC USB Serial WDM Driverc:windowssystem32driversrusbser.sysKernel DriverNoManualStoppedOKNormalNoNo
bthmodemBluetooth Serial Communications Driverc:windowssystem32driversthmodem.sysKernel DriverNoDisabledStoppedOKNormalNoNo
cdfsCD/DVD File System Readerc:windowssystem32driverscdfs.sysFile System DriverYesDisabledRunningOKNormalNoYes
cdromCD-ROM Driverc:windowssystem32driverscdrom.sysKernel DriverYesSystemRunningOKNormalNoYes
circlassConsumer IR Devicesc:windowssystem32driverscirclass.sysKernel DriverNoDisabledStoppedOKNormalNoNo
clfsCommon Log (CLFS)c:windowssystem32clfs.sysKernel DriverYesBootRunningOKCriticalNoYes
cmdidecmdidec:windowssystem32driverscmdide.sys&n bsp;Kernel DriverNoDisabledStoppedOKCriticalNoNo
compbattMicrosoft Composite Battery Driverc:windowssystem32driverscompbatt.sysKernel DriverNoDisabledStoppedOKCriticalNoNo
crcdiskCrcdisk Filter Driverc:windowssystem32driverscrcdisk.sysKernel DriverYesBootRunningOKNormalNoYes
cscOffline Files Driverc:windowssystem32driverscsc.sysKernel DriverYesSystemRunningOKNormalNoYes
dfscDfs Client Driverc:windowssystem32driversdfsc.sysFile System DriverYesSystemRunningOKNormalNoYes
diskDisk Driverc:windowssystem32driversdisk.sysKernel DriverYesBootRunningOKNormalNoYes
drmkaudMicrosoft Kernel DRM Audio Descramblerc:windowssystem32driversdrmkaud.sysKernel DriverNoManualStoppedOKNormalNoNo
dxgkrnlLDDM Graphics Subsystemc:windowssystem32driversdxgkrnl.sysKernel DriverYesManualRunningOKIgnoreNoYes
e1g60Intel PRO/1000 NDIS 6 Adapter Driverc:windowssystem32driverse1g6032e.sysKernel DriverNoManualStoppedOKNormalNoNo
ecacheReadyBoost Caching Driverc:windowssystem32driversecache.sysKernel DriverYesBootRunningOKCriticalNoYes
elxstorelxstorc:windowssystem32driverselxstor.sysKernel DriverNoDisabledStoppedOKNormalNoNo
fastfatFAT12/16/32 File System Driverc:windowssystem32driversfastfat.sysFile System DriverYesManualRunningOKNormalNoYes
fdcFloppy Disk Controller Driverc:windowssystem32driversfdc.sysKernel DriverYesManualRunningOKNormalNoYes
fileinfoFile Information FS MiniFilterc:windowssystem32driversfileinfo.sysFile System DriverYesBootRunningOKNormalNoYes
filetraceFileTracec:windowssystem32driversfiletrace.sysFile System DriverNoManualStoppedOKNormalNoNo
flpydiskFloppy Disk Driverc:windowssystem32driversflpydisk.sysKernel DriverYesManualRunningOKNormalNoYes
fltmgrFltMgrc:windowssystem32driversfltmgr.sysFile System DriverYesBootRunningOKCriticalNoYes
gagp30kxMicrosoft Generic AGPv3.0 Filter for K8 Processor Platformsc:windowssystem32driversgagp30kx.sysKernel DriverNoManualStoppedOKNormalNoNo
hdaudaddserviceMicrosoft 1.1 UAA Function Driver for High Definition Audio Servicec:windowssystem32drivershdaudio.sysKernel DriverYesManualRunningOKNormalNoYes
hdaudbusMicrosoft UAA Bus Driver for High Definition Audioc: windowssystem32drivershdaudbus.sysKernel DriverYesManualRunningOKNormalNoYes
hidbthMicrosoft Bluetooth HID Miniportc:windowssystem32drivershidbth.sysKernel DriverNoDisabledStoppedOKIgnoreNoNo
hidirMicrosoft Infrared HID Driverc:windowssystem32drivershidir.sysKernel DriverNoDisabledStoppedOKIgnoreNoNo
hidusbMicrosoft HID Class Driverc:windowssystem32drivershidusb.sysKernel DriverYesManualRunningOKIgnoreNoYes
hpcisssHpCISSsc:windowssystem32drivershpcisss.sysKernel DriverNoDisabledStoppedOKNormalNoNo
httpHTTPc:windowssystem32drivershttp.sysKernel DriverYesManualRunningOKNormalNoYes
i2ompi2ompc:windowssystem32driversi2omp.sysKernel DriverNoDisabledStoppedOKNormalNoNo
i8042prti8042 Keyboard and PS/2 Mouse Port Driverc:windowssystem32driversi8042prt.sysKernel DriverNoDisabledStoppedOKNormalNoNo
iastorvIntel RAID Controller Vistac:windowssystem32driversiastorv.sysKernel DriverNoDisabledStoppedOKNormalNoNo
iirspiirspc:windowssystem32driversiirsp.sysKernel DriverNoDisabledStoppedOKNormalNoNo
intelideintelidec:windowssystem32driversintelide.sysKernel DriverYesBootRunningOKCriticalNoYes
intelppmIntel Processor Driverc:windowssystem32driversintelppm.sysKernel DriverYesManualRunningOKNormalNoYes
ipfilterdriverIP Traffic Filter Driverc:windowssystem32driversipfltdrv.sysKernel DriverNoManualStoppedOKNormalNoNo
ipmidrvIPMIDRVc:windowssystem32driversipmidrv.sysKernel DriverNoManualStoppedOKNormalNoNo
ipnatIP Network Address Translatorc:windowssystem32driversipnat.sysKernel DriverNoManualStoppedOKNormalNoNo
irenumIR Bus Enumeratorc:windowssystem32driversirenum.sysKernel DriverNoManualStoppedOKIgnoreNoNo
isapnpPnP ISA/EISA Bus Driverc:windowssystem32driversisapnp.sysKernel DriverNoDisabledStoppedOKCriticalNoNo
iscsiprtiScsiPort Driverc:windowssystem32driversmsiscsi.sysKernel DriverYesManualRunningOKNormalNoYes
iteatapiITEATAPI_Service_Installc:windowssystem32driversiteatapi.sysKernel DriverNoDisabledStoppedOKNormalNoNo
iteraidITERAID_Service_Installc:windowssystem32driversiteraid.sysKernel DriverNoDisabledStoppedOKNormalNoNo
kbdclass&nb sp;Keyboard Class Driverc:windowssystem32driverskbdclass.sysKernel DriverYesSystemRunningOKNormalNoYes
kbdhidKeyboard HID Driverc:windowssystem32driverskbdhid.sysKernel DriverYesSystemRunningOKIgnoreNoYes
ksecddKSecDDc:windowssystem32driversksecdd.sysKernel DriverYesBootRunningOKCriticalNoYes
ksthunkKernel Streaming Thunksc:windowssystem32driversksthunk.sysKernel DriverYesManualRunningOKNormalNoYes
lltdioLink-Layer Topology Discovery Mapper I/O Driverc:windowssystem32driverslltdio.sysKernel DriverYesAutoRunningOKNormalNoYes
lsi_fcLSI_FCc:windowssystem32driverslsi_fc.sysKernel DriverNoDisabledStoppedOKNormalNoNo
lsi_sasLSI_SASc:windowssystem32driverslsi_sas.sysKernel DriverNoDisabledStoppedOKNormalNoNo
lsi_scsiLSI_SCSIc:windowssystem32driverslsi_scsi.sysKernel DriverNoDisabledStoppedOKNormalNoNo
luafvUAC File Virtualizationc:windowssystem32driversluafv.sysFile System DriverYesAutoRunningOKNormalNoYes
megasasmegasasc:windowssystem32driversmegasas.sysKernel DriverNoDisabledStoppedOKNormalNoNo
modemModemc:windowssystem32driversmodem.sysKernel DriverNoManualStoppedOKIgnoreNoNo
monitorMicrosoft Monitor Class Function Driver Servicec:windowssystem32driversmonitor.sysKernel DriverYesManualRunningOKNormalNoYes
mouclassMouse Class Driverc:windowssystem32driversmouclass.sysKernel DriverYesSystemRunningOKNormalNoYes
mouhidMouse HID Driverc:windowssystem32driversmouhid.sysKernel DriverYesManualRunningOKIgnoreNoYes
mountmgrMount Point Managerc:windowssystem32driversmountmgr.sysKernel DriverYesBootRunningOKCriticalNoYes
mpioMicrosoft Multi-Path Bus Driverc:windowssystem32driversmpio.sysKernel DriverNoDisabledStoppedOKNormalNoNo
mpsdrvWindows Firewall Authorization Driverc:windowssystem32driversmpsdrv.sysKernel DriverYesManualRunningOKNormalNoYes
mraid35xMraid35xc:windowssystem32driversmraid35x.sysKernel DriverNoDisabledStoppedOKNormalNoNo
mrxdavWebDav Client Redirector Driverc:windowssystem32driversmrxdav.sysFile System DriverYesManualRunningOKNormalNoYes
mrxsmbSMB MiniRedirector Wrapper and Enginec:windowssystem32driversmrxsmb.sysFile System DriverYesManual RunningOKNormalNoYes
mrxsmb10SMB 1.x MiniRedirectorc:windowssystem32driversmrxsmb10.sysFile System DriverYesManualRunningOKNormalNoYes
mrxsmb20SMB 2.0 MiniRedirectorc:windowssystem32driversmrxsmb20.sysFile System DriverYesManualRunningOKNormalNoYes
msahcimsahcic:windowssystem32driversmsahci.sysKernel DriverYesBootRunningOKCriticalNoYes
msdsmMicrosoft Multi-Path Device Specific Modulec:windowssystem32driversmsdsm.sysKernel DriverNoDisabledStoppedOKNormalNoNo
msfsMsfsc:windowssystem32driversmsfs.sysFile System DriverYesSystemRunningOKNormalNoYes
msisadrvISA/EISA Class Driverc:windowssystem32driversmsisadrv.sysKernel DriverYesBootRunningOKCriticalNoYes
mskssrvMicrosoft Streaming Service Proxyc:windowssystem32driversmskssrv.sysKernel DriverNoManualStoppedOKNormalNoNo
mspclockMicrosoft Streaming Clock Proxyc:windowssystem32driversmspclock.sysKernel DriverNoManualStoppedOKNormalNoNo
mspqmMicrosoft Streaming Quality Manager Proxyc:windowssystem32driversmspqm.sysKernel DriverNoManualStoppedOKNormalNoNo
msrpcMsRPCc:windowssystem32driversmsrpc.sysKernel DriverNoManualStoppedOKNormalNoNo
mssmbiosMicrosoft System Management BIOS Driverc:windowssystem32driversmssmbios.sysKernel DriverYesManualRunningOKNormalNoYes
msteeMicrosoft Streaming Tee/Sink-to-Sink Converterc:windowssystem32driversmstee.sysKernel DriverNoManualStoppedOKNormalNoNo
mupMupc:windowssystem32driversmup.sysFile System DriverYesBootRunningOKNormalNoYes
nativewifipNativeWiFi Filterc:windowssystem32drivers wifi.sysKernel DriverNoManualStoppedOKNormalNoNo
ndisNDIS System Driverc:windowssystem32drivers dis.sysKernel DriverYesBootRunningOKCriticalNoYes
ndistapiRemote Access NDIS TAPI Driverc:windowssystem32drivers distapi.sysKernel DriverYesManualRunningOKNormalNoYes
ndisuioNDIS Usermode I/O Protocolc:windowssystem32drivers disuio.sysKernel DriverNoManualStoppedOKNormalNoNo
ndiswanRemote Access NDIS WAN Driverc:windowssystem32drivers diswan.sysKernel DriverYes&nb
Please do not post such a large amount of text into a post. If needed, use an attachment (ZIP, preferably).
In the past, this issue with MSOBJ80.dll has been fixed by installing VS2005 SP1, but you say you already have it. Here's another solution:
A Visual Studio executable, MsPdbsrv.exe, is installed in 2 places by VisualStudio.
One of the locations is
"Program FilesCommon FilesMicrosoft SharedVSA8.0VsaEnv".
The bug is that msobj80.dll isn't installed at that location. If mspdbsrv.exe is
started from a non-VS environment, it will not find msobj80.dll when link.exe
communicates with mspdbsrv.exe.
So you could copy msobj80.dll to that directory, or make sure
"Program FilesMicrosoft Visual Studio 8Common7IDE"
is always in your path.
This error is discussed at this web link:
http://connect.microsoft.com/VisualStudio/feedback/ViewFeedback.aspx?FeedbackID=119683
You should be able to locate msobj80.dll on your system in
Please let me know if this resolves the problem.
