29419 Discussions
Fortran 2008 does not allow this statement or directive
jingang_l_
module test_align
  implicit none
  real(8) ::a(5)
  !DIR$ ATTRIBUTES ALIGN:64 :: a
end module test_align
[compiling option]:
ifort -module include -fpp -std08 -assume byterecl -traceback -O3 -xMIC-AVX512 -qopt-report=5 -qopt-report-file=stdout -o -c ./test.o
[output]:
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 17.0.2.174 Build 20170213
Compiler options: -I/soft/compilers/intel/compilers_and_libraries_2017.2.174/linux/mpi/intel64/include -I/soft/compilers/intel/compilers_and_libraries_2017.2.174/linux/mpi/intel64/include -module include -fpp -std08 -assume byterecl -traceback -O3 -xMIC-AVX512 -qopt-report=5 -qopt-report-file=stdout -c -o ./test.o
test.F90(6): warning #7025: This directive is not standard F2008.
    Report from: Interprocedural optimizations [ipo]
  WHOLE PROGRAM (SAFE) [EITHER METHOD]: false
  WHOLE PROGRAM (SEEN) [TABLE METHOD]: false
  WHOLE PROGRAM (READ) [OBJECT READER METHOD]: false
[question]:
I'm not sure whether the variable is aligned? What's the standard way to align data in F2008?
Steve_Lionel
There is no standard way to align data in Fortran. If you want to do that, you have to use directives, and therefore if you ask for standards warnings you'll get them for directives.
