- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
We are considering an upgrade from Intel Visual Fortran Compiler 10.1.021 to the newest version of the compiler (Fortran Composer XE 2011). Our code is a mixture of "old"- and "new"-style fortran. Will this compiler-upgrade result in any known issues with respect to the "old" part of the code? is the new compiler fully backward compatible with respect to legacy features?
Regards, Arild
Regards, Arild
1 Lösung
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I have many projects with legacy/new/clean/messy code and i had held off updating to XE until first go-round of updates/fixes.
I just updated to Intel Visual Fortran Composer XE for Windows Version 2011 (Update 1) 01 Dec 2010
I'verecompiled a couple of very large projects withno issues.
XE actually caught 2 previously undetected errors, which i fixed, and everything is running great.
So i'd expect you will have a minimum of upgrade issues with Update 1 of XE 2011.
brian
Link kopiert
8 Antworten
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
As far as I can tell, you should have no worries.
Linda
Linda
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
That will depends on whether the old part is just "old" or "bad old" -- the latter signifying that dubious practices and non-standard language features were used: for example, Hollerith initialization of real and complex variables.
Recent versions of the Intel compiler are more successful at trapping bugs in code both at compile time and run time, as you can see from posts from users complaining that their code used to work fine with older versions of the compiler but now causes run-time errors. I belong to the camp that views better error-checking as a positive thing that provides an opportunity to fix bugs that would otherwise stay hidden. But then, you may have other viewpoints.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
brian
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I agree with the observations made here. I have a lot of rather recent software (Fortran 95 and Fortran 2003) but also a lot of "old" software that torturesmy eyes iftake a look at it. Compilation with Intel for this old code went well, although a lot of warning messages are generated. Most of these warningsindicate obsolecent features or are ofminor importance.Only a few asks for repair. As an example: an uninitialised variable. But there are more!
In conclusion: no seriousproblem!!
Robert
Robert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
You'll only get warnings of obsolescent features if you ask for standards checking. But it is true that many people find that the Intel compiler finds problems in their code that their previous compiler didn't.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Steve, it is not completely clear to me how to interpret your comment. Do you mean that the new Intel compiler (v12/Composer XE) finds problems that the previous Intel compiler did not find (i.e. v 11 and lower). Or does "previous compiler" refer to non-Intel compilers. My question was about issues when upgrading from Intel compiler v10 to v12.
Regards, Arild
Regards, Arild
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Steve will answer in due course, certainly.
In my experience, both. That is, for source code with violations of the standard or other bugs, the current Intel compiler is more likely to emit compile time or run time error messages than the older versions of the Intel compiler and a few (certainly not all) non Intel compilers.
For clean source code, any bug-free standards-aware compiler should give zero error messages.
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Yes, I meant both. We continually improve the error detection capability of the Intel compiler. Some other compilers are better than us at finding errors, some not. If you have "old code", it is highly liklely it was first developed using a compiler with lesser error detection capabilities - Intel or otherwise. A loit of "dusty deck" code plays fast-and-loose with the argument matching rules of the language, depending on the fact that most of the compilers of the day did not catch such errors.
Antworten
Themen-Optionen
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
