I'm writing a Fortran DLL that has to bread by several tools, including Excel, so I'm writing an Excel extension (.xla).
Until now, I am able to correctly work with 32bit version of Excel but now I would like to write something compatible with both versions of Excel.
This is a working 32bit example (FORTRAN):
module my_module
contains
subroutine div_num(A,B,C,ierr,errstring)! bind(c, name='div_num')
!! ** Division of two numbers: C = A/B **
!!INPUT : A, B
!!OUTPUT: C
!DEC$ ATTRIBUTES DLLEXPORT, STDCALL, REFERENCE, ALIAS:"div_num" :: div_num
implicit none
real*8 , intent(in) :: A !! First number
real*8 , intent(in) :: B !! Second number
real*8 , intent(out) :: C !! Result
logical , intent(out) :: ierr !! Logical stating if there is an error
character(256) , intent(out) :: errstring !! String containing the error
!DEC$ ATTRIBUTES REFERENCE :: A,B,C,ierr,errstring
if (B .EQ. 0.0d0) then
ierr = .TRUE.
else
ierr = .FALSE.
endif
if (ierr) then
C = -1.0d6
errstring = "Error: you can't divide by zero!"
return
else
C = A/B
errstring = ""
endif
end subroutine div_num
end module my_module
VBA :
Option Explicit
Option Base 1
' Common declarations
Dim ierr As Boolean
Dim errstring As String * 256
' Lettura dll
#If Win64 Then
Declare PtrSafe Sub div_num Lib "S:\Winchler_Lorenzo\testDLL_x64_Debug.dll" (A As Double, B As Double, C As Double, ierr As Boolean, ByVal errstring As String)
#Else
Declare Sub div_num Lib "S:\Winchler_Lorenzo\testDLL_Win32_Debug.dll" (A As Double, B As Double, C As Double, ierr As Boolean, ByVal errstring As String)
#End If
Public Function VBA_div(x1 As Double, x2 As Double) As Double
' Division of two numbers
' INPUTS:
' - x1: first number
' - x2: second number
' OUTPUTS:
' - VBA_div: division between the numbers
' declarations
Dim xOUT As Double
Call div_num(x1, x2, xOUT, ierr, errstring)
VBA_div = xOUT
End Function
The only modification I made inside VBA is the "PtrSafe" declaration, but it's not working inside 64bit Excel. Obviously I am pointing at the right dll, differently for the 32-64bit case.
The documentation provides the example only for 32bit case, and I don't know what I have to change to make the dll work inside 64bit Excel.
Thank you for your help
Lorenzo
I have struggled with using Fortran DLLs in 64-bit Office too. I have a few comments that may help based on my experience but not a complete solution. I am hoping this will be resolved although it is really a Microsoft Office problem as well.
Comments:
1. Microsoft recommends using 32-bit Office unless the memory requirements exceed 2 GB (more than enough for many applications).
2. Microsoft also cautions that VBA code that contains the Declare Sub or Declare Function may not work with 64-bit across the board without error. Hence, stick to 32-bit. This tells me that have identified some problems too.
3. You may have to include some new declarations such as LongLong, LongPtr and PtrSafe for certain data types. I am not sure how they map to Fortran data types.
4. The API function CopyMemory has trouble in 64-bit with variables passed through the DLL. This appears to be a problem faced by many developers for DLLs created in other languages as well (C,C++).
5. For 64-bit, I build the IVF dll in Release x64 configuration with /iface:cvf option and libs:static. In fact, even in 32-bit, only that configuration works in all cases.
6. I have trouble with the VBA directives #Win64 etc. in 64-bit. The interpreter does not allow declaring a sub without PtrSafe even for the 32-bit case. In particular, the Microsoft recommended method in the following pseudocode results in errors.
#if Vba7 then ' Code is running in the new VBA7 editor #if Win64 then ' Code is running in 64-bit version of Microsoft Office #else ' Code is running in 32-bit version of Microsoft Office #end if #else ' Code is running in VBA version 6 or earlier #end if #If Vba7 Then Declare PtrSafe Sub ... #Else Declare Sub ... #EndIf
Comments:
avinashs wrote:I have struggled with using Fortran DLLs in 64-bit Office too. I have a few comments that may help based on my experience but not a complete solution. I am hoping this will be resolved although it is really a Microsoft Office problem as well.
Comments:
6. I have trouble with the VBA directives #Win64 etc. in 64-bit. The interpreter does not allow declaring a sub without PtrSafe even for the 32-bit case. In particular, the Microsoft recommended method in the following pseudocode results in errors.#if Vba7 then ' Code is running in the new VBA7 editor #if Win64 then ' Code is running in 64-bit version of Microsoft Office #else ' Code is running in 32-bit version of Microsoft Office #end if #else ' Code is running in VBA version 6 or earlier #end if #If Vba7 Then Declare PtrSafe Sub ... #Else Declare Sub ... #EndIf
Thank you for your comments!
Compiling the dll with "/iface:cvf" and "/libs:static" as you suggested me, works like a charm!!!
Regarding the Long/LongPtr: this modification is needed only if your argument is returning a pointer or a location. If it's "just" an integer value, you can leave "Long".
Thank you so much
Lorenzo
