Fortran DLL slows down 2 times when called from Visual C++ in comparison to calling from Fortran
manh_nguyen
Hello everyone,
I have this problem, hope that you can help me out:
There is a subroutine in Fortran code that has been given to me. This Fortran code is acually a simulation model of a physical process, so there is a criteria of simulation speed. I compiled the Fortran code into a DLL file.
Then the DLL subroutine is called from a Fortran program by using Windows API functions LoadLibrary and GetprocessAdress, it gives a the speed ratio of 770 which means that it takes 1 second to simulate the physical process in 770 seconds real time
Next, i do the same thing but this time in C++, and this gives me a speed ratio of 380 which is 2 times slower than the calling from Fortran program
i have tried to get through the problem by setting the Runtime library option when compiling C++ program to  "Multithreaded DLL" which was set to the DLL but it did not resolve the problem
Anyone has any idea of what has happened with the call from C++?
Thanks for your help,
Steven_L_Intel1
Please show the Fortran and C++ code used to call the routine. In particular, knowing how the input and output arguments are declared would be useful.  Changing the runtime library option is not relevant.  My guess is that you're not calling with the same inputs.
manh_nguyen
deleted
bmchenry
New Contributor II
I have called simulation dlls from Intel Fortran AND Microsoft C++ (both 32 bit) and found no significant time difference in performance of the simulation. What i am guessing is that somehow an input parameter or an option for the simulation is different between your Fortran call and your C++ call. This would show itself in different results of the simulation between the Fortran call and the C++ call. Are the simulation results identical between the two different calls? If not, fix things so you are comparing the same simulation results across the two calls. If so, then please post up the calling routines for Fortran and C++ and it may reveal the reason for the speed degradation.
bmchenry
New Contributor II
what's up with these double postings? is it me, or the forum? sorry for the poste duple!
IanH
In the absence of compiler options to the contrary, a Fortran default logical in ifort uses four bytes.  In the absence of compile options to the contrary, a MS VC++ bool is one byte.  It is quite probable that your fortran dll goes and stomps on the C++ program's stack.  Your C++ program probably gets quite upset about this.  Depending on how the C++ or Fortran compiler feels about packing structures you may have a related problem with the inlet structure (and the outlet structure too, in a slightly different scenario).
Consider using Fortran 2003's C interoperability features to make the link between Fortran and your C++ code robust to this sort of issue.  While you are at it you can get rid of the non standard structure business (make them BIND(C) types).
manh_nguyen
lanH, I have trid to put bool variables of the C++ program into "int" which has 4bytes as "logical" type of ifort, but nothing changed
thx
mecej4
A look at your code indicates that the program executes a loop ten times, with a call to the DLL inside the loop.
If the program executes in less than, say, 0.1 second, comparisons of run-times in the C++ and Fortran versions are going to be misleading.
What is the order of magnitude of the running time?
manh_nguyen
mecej4, the running time is about 37seconds with Fortran, and about 80 seconds in C++
thx
manh_nguyen
a strange thing to me: the .exe file of ifort code has only 13k, and the one of C++ has1264k, do you think that is normal?
thx
manh_nguyen
With the simulation in Visual Fortran, i set the runtime library of the dll project to Multithreaded, the speed ratio downs to about 380 (knowing that it was about 780 when runtime library is set to Multithreaded DLLs ).
Then, with the option Multithreaded, i add to the Additional dependancies the  Libifcoremd.lib, The simulation spead ups to the the maximum (about 780)
Does this make sense to anyone?
mecej4
You have found that a compiler not so well known for optimization (dev-C) produces code that runs slower than code output by a Fortran compiler known for its optimization (Intel Fortran). The other tweaking that you did, with compiler options, different RTLs, etc., is probably not going to make much of a difference. There is always Amdahl's Law to consider in explaining how multi-threaded programs behave.
In such circumstances, one may rejoice that the Fortran program is "fast", or lament that the C program is "slow", or take a position somewhere in between.
Your quoting "real" time/simulation times is misleading, because it suggests that the ratio is of some significance. In solving a heat diffusion problem, for example, one may change "real" time by changing the diffusion coefficient, without causing any change to the run time of the simulation. Similarly, simple models of climate change can run a simulation of the entire (known) life of the Earth in a few hours.
manh_nguyen
 In fact, the case im working on is involving mathemathical optimization, and there is iterative call to the simulation model, so the simulation speed is really something that matters. I dont know much about numerical modeling, so can not tell if  in my case i can change any coefficient to change "real" time as in the example that you mentionned.
My last comment was to ask why only by changing the runtime library option from MD to MT, the simulation speed of my fortran code decreased two times? which would (i think) answer the initial question
manh_nguyen
hi, I solved the problem
it turned out that the problem comes from a line in fortran code: IMPLICIT INTEGER(i-n)
i changed it to: IMPLICIT INTEGER*2(i-n) and this anwser to initial question. I hope this will help someone who might have the same problem as mine
thx
rase
I can only repeat the advice to use IMPLICIT NONE and to declare every variable explicitly instead of using the automatic declaration feature of ancient Fortran. I made the experience the hard way some years ago with a similar error.
mecej4
I do not understand what you mean by "initial question", but if adding IMPLICIT INTEGER*2(..) "answered" the question, your code has serious problems. If this change was required for the program to run correctly, the speed comparisons that you started out with are invalid because you were comparing a correctly running program with an incorrectly running one.
The Fortran program was probably developed to work on a 16-bit CPU, and code with INTEGER*2 is going to run more slowly on today's 64-bit CPUs than code with default INTEGER for the platform.
manh_nguyen
mecej, you're right, there is a bug when i add IMPLICIT INTEGER*2(i-n), the code gives NAN results. :(
mecej4
I'd have used the emoticon ":)", instead, since the NaNs in the result give a strong warning that there is something definitely wrong. Bugs are harder to track down and fix when they do not affect the results so much that questions of plausibility arise. There have been cases where such bugs stayed hidden for decades in highly used and well-reputed software.
manh_nguyen
how can i find out if the code was develpped for 16-bit CPU or not?
mecej4
The usage of 2-byte integers is a good indication. Such half- (or quarter-) word integers make sense in new code only if either (i) interfacing Fortran to hardware that needs to exchange 16-bit integers, or (ii) to pack more integers into memory than if natural size integers were used.
TimP
I stopped programming for 8-bit CPUs over 20 years ago, yet someone decided to invest in 16-bit floating point data types for the  Intel architectures which are currently being released. presumably on the basis of demand from influential customers.
The 16-bit data types involve use of 32-bit registers, using the same arithmetic instruction set as for 32-bit data types.  As mecej4 says, their use could be justified only if a compensating benefit can be demonstrated in reduced memory usage.  Even the benefit from using approximate divide and sqrt is reduced in the Ivy Bridge CPU.
