29618 Discussions
Fortran-Dynamic C Interface - PLEASE HELP!
bwilt
I have c libraries that unpack GRIB2 data that I receive from NCEP/NWS. The data looks correct INSIDE my c routines, but I am at a loss to accessing the c structure from fortran. The c library creates and dynamically allocates the a structure called 'gribfield' as follows:
struct
gribfield {
g2int version,discipline;
g2int *idsect;
g2int idsectlen;
unsigned char *local;
g2int locallen;
g2int ifldnum;
g2int griddef,ngrdpts;
g2int numoct_opt,interp_opt,num_opt;
g2int *list_opt;
g2int igdtnum,igdtlen;
g2int *igdtmpl;
g2int ipdtnum,ipdtlen;
g2int *ipdtmpl;
g2int num_coord;
g2float *coord_list;
g2int ndpts,idrtnum,idrtlen;
g2int *idrtmpl;
g2int unpacked;
g2int expanded;
g2int ibmap;
g2int *bmap;
g2float *fld;
typedef
struct gribfield gribfield;
The C routine I call simply returns a pointer to this structure as follows:
g2int g2_getfld(
unsigned char *cgrib,g2int ifldnum,g2int unpack,g2int expand,
gribfield **gfld)
I have tried everything trying to access this data from IVF 10.025 with no luck. My interface code is as follows:
interface
function g2_getfld (mgrib,ifldnum,unpack,expand,gfld)
!DEC$ ATTRIBUTES C, DECORATE, ALIAS:'g2_getfld' :: g2_getfld
integer (kind=int_ptr_kind()) gfld
type gribfield
sequence
integer*4 version
integer*4 discipline
integer*4, allocatable :: idsect(:)
integer*4 idsectlen
character, allocatable :: local(:)
integer*4 locallen
integer*4 ifldnum
integer*4 griddef,ngrdpts
integer*4 numoct_opt,interp_opt,num_opt
integer*4, allocatable :: list_opt(:)
integer*4 igdtnum,igdtlen
integer*4, allocatable :: igdtmpl(:)
integer*4 ipdtnum,ipdtlen
integer*4, allocatable :: ipdtmpl(:)
integer*4 num_coord
real, allocatable :: coord_list(:)
integer*4 ndpts,idrtnum,idrtlen
integer*4, allocatable :: idrtmpl(:)
integer*4 unpacked
integer*4 expanded
integer*4 ibmap
integer*4, allocatable :: bmap(:)
real, allocatable :: fld2(:)
end type
pointer (gfld, version)
character*1 mgrib(131040)
integer*4 ifldnum,unpack,expand
end function g2_getfld
end interface
How can I access the data from the gribfield structure in Fortran? For example, I want to print the parameter 'version'?
Thanks for any help you can provide!
Brett A. Wilt
Jugoslav_Dujic
Valued Contributor II
No, you cannot map a Fortran POINTER or ALLOCATABLE array to a C pointer. What you can do is use one of the following:
* Integer (or Cray) pointers on Fortran side, or, better
* ISO_C_BINDING module
The former is a non-standard (but common) extension. The latter is the new standard, so I recommend its use:
In short, each g2int* member will map to a TYPE(C_PTR) in Fortran. To dereference it into an array, you have to use a temporary POINTER array:
integer, pointer:: pidsect(:)
call C_F_POINTER(gfld%idsect, pidsect, (/idsectlen/) )
write(*,*) pidsect(1)
In the spirit of ISO_C_BINDING, you may also want to change !DEC$ATTRIBUTES into BIND(C, NAME="g2_getfld"). Don't forget to USE, INTRINSIC:: ISO_C_BINDING on the relevant places.
bwilt
Thanks for the reply!
Do I use the type structure 'gribfield' in my fortran INTERFACE code to match the c structure? Is my code correct for this or do I not use the TYPE structure along with the allocatable array declarations?
Jugoslav_Dujic
Ah, I missed that.
INTERFACE is somewhat peculiar in Fortran, as the declaration of TYPE gribfiled will not be "visible" outside the INTERFACE (unless there's IMPORT statement supported in IVF10 -- I didn't check -- or the SEQUENCE attribute in both type definitions). Instead, it's best that you write it like this:
MODULE m_gribfield
INTEGER, PARAMETER:: g2int =4
TYPE gribfield
 INTEGER(g2int):: version, discipline
 TYPE(C_PTR):: idsect
 INTEGER(g2int):: idsectlen
END TYPE gribfield
END MODULE m_gribfield
INTERFACE
 function g2_getfld (mgrib,ifldnum,unpack,expand,gfld) bind(C, NAME="g2_getfld")
 USE m_gribfield
 INTEGER(g2int):: g2_getfld
 INTEGER(g2int), VALUE:: ifldnum
 INTEGER(g2int), VALUE:: unpack
 INTEGER(g2int), VALUE:: expand
 TYPE(C_PTR):: gfld
 END FUNCTION
END INTERFACE
TYPE(g2_getfld), POINTER:: gfld
TYPE(C_PTR):: p_gfld
iret = g2_getfld(...p_gfld)
CALL C_F_POINTER(p_gfld, gfld)
I'm not positive what is mgrib/cgrib, so I left it untranslated -- you may wish to retain the character, or do it through type(C_PTR) as well.
IMPORT is supported.
bwilt
Ireally appreciate your time and help with this. I am notextensively familiar with c, so this is learning for me. Here is where I am now:
module m_gribfield
use, intrinsic:: iso_c_binding
integer, parameter:: g2int=4
type gribfield
integer(g2int):: version
integer(g2int):: discipline
type(c_ptr):: idsect
integer(g2int):: idsectlen
type(c_ptr):: local
integer(g2int):: locallen
integer(g2int):: ifldnum
integer(g2int):: griddef
integer(g2int):: ngrdpts
integer(g2int):: numoct_opt
integer(g2int):: interp_opt
integer(g2int):: num_opt
type(c_ptr):: list_opt
integer(g2int):: igdtnum
integer(g2int):: igdtlen
type(c_ptr):: igdtmpl
integer(g2int):: ipdtnum
integer(g 2int):: ipdtlen
type(c_ptr):: ipdtmpl
integer(g2int):: num_coord
type(c_ptr):: coord_list
integer(g2int):: ndpts
integer(g2int):: idrtnum
integer(g2int):: idrtlen
type(c_ptr):: idrtmpl
integer(g2int):: unpacked
integer(g2int):: expanded
integer(g2int):: ibmap
type(c_ptr):: bmap
type(c_ptr):: fld2
end type gribfield
end module m_gribfield
subroutine readgrib
use m_gribfield
type
(g2_getfld), pointer:: gfld
type
(c_ptr):: p_gfld
interface
!dec$ attributes c, decorate, alias:'g2_getfld' :: g2_getfld
use m_gribfield
integer(g2int):: g2_getfld
integer(g2int), value:: ifldnum
integer(g2int), value:: unpack
integer(g2int), value:: expand
type(c_ptr):: gfld
end interface
ierr=g2_getfld(%ref(mgrib),1,1,0,%ref(gfld))
call c_f_pointer(p_gfld, gfld)
print*,gfld%version
return
end
Here are my compiler error messages:
Error1 Error: This is not a derived type name. [G2_GETFLD]C:DevelopmentModel_x32_VS2005Sourcegribread.f1370
This occurs when the line
type(g2_getfld), pointer:: gfld
is added to the subroutione as indicated above.
Error2 Error: This variable or component must be of a derived or structure type [GFLD]C:DevelopmentModel_x32_VS2005Sourcegribread.f1476
Error3 Error: This is not a field name that is defined in the encompassing structure. [VERSION]C:DevelopmentModel_x32_VS2005Sourcegribread.f1476
These occur when I try and print the value of version with:
print*,gfld%version
Can you show me how to print the value of version? Is it incorrect above?
g_f_thomas
What if you BIND(C,NAME="g2_getfld" )? but keep the !DEC$ meta command as it acts as a workaround for the compiler's failure to prepend a _ to the symbol.
Gerry
Don't use that ATTRIBUTES line at the same time as BIND(C). At best you may get odd results, at worst a compile-time error (a future update will complain).
First problem - the type you declared is gribfield, not m2_getfield. The other errors derive from that.
Your ATTRIBUTES line looks fine to me as it is.
g_f_thomas
He could throw out the Alias and retain the Decorate and all would be fine unless Decorate's behavior changes in the future. Now you know why the HP guy suggestedthat one needs to experiment from release to release.
Gerry
Gerry, you keep bringing up that HP article which was wrong. It is also not relevant here.
