Calling C++ from Fortran
Stephen_Painchaud
I have reada few related posts and have not found the answer I need.
I am using VS2005 and IVF10. I found an example in directory C:Program FilesIntelCompilerFortran10.0.025samplesMixedLanguageFortran_Calls_C. This example passes integers and strings from Fortran to C. I need to pass real arrays. I tried to modify this example without success. The numbers inside the C++ routine where incorrect.
In the spirit of theexample above, I provide my own test case. The C++ code is:
#include
"stdafx.h"
#include
using
namespace std;
extern
"C" void argtest_cpp(int ndata, float *mydata){
cout <<
"ndata = " << ndata << endl;
for (int i = 0; i < ndata; i++)
cout << i <<
" " << *(mydata+i) << endl;
The Fortran code is:
PROGRAM
argtest
IMPLICIT NONE
INTERFACE
SUBROUTINE argtest_cpp (ndata, mydata)
!DEC$ ATTRIBUTES C :: argtest_cpp
!DEC$ ATTRIBUTES REFERENCE :: mydata
INTEGER, INTENT(IN) :: ndata
REAL, INTENT(IN) :: mydata(:)
END SUBROUTINE argtest_cpp
END INTERFACE
REAL
mydata(10)
INTEGER
i, ndata
ndata = 10
DO
i = 1, ndata
mydata(i) =
log10(float(i+1))
print *, i, mydata(i)
ENDDO
CALL
argtest_cpp(ndata, mydata)
STOP
END
When I run this code I see that thereal numbers inside the C++ routine are incorrect, but the integer passes properly. I appreciate any help.&n bsp;
You want this instead:
REAL, INTENT(IN) :: mydata(*)
Stephen_Painchaud
It works great. Thank you very much.
