Fortran License Problem
Roger
The system admin has installed the fortran license on a server and the INTEL_LICENSE_FILE variable on the clietis set to port@server.
Auseris able to use the compiler through Visual Studio 2005, but gets this error when using the ifort command in a command window:
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
G:>ifort
Intel Fortran Compiler for 32-bit applications, Version 9.1 Build 20061103
Z Package ID: W_FC_C_9.1.033
Copyright (C) 1985-2006 Intel Corporation. All rights reserved.
Error: A license for FCompW is not available now (-15,10,10061).
A connection to the license server could not be made. You should
make sure that your license daemon process is running: both an
lmgrd.intel.exe process and an INTEL.exe process should be running
if your license limits you to a specified number of licenses in use
at a time. Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
1. C:Program FilesCommon FilesIntelLicenses*.lic
2. port@server
3. C:PROGRA~1IntelCompilerFortran9.1IA32Bin*.lic
Please visit
http://support.intel.com/support/performancetools/support.htm if yo
u require technical assistance.
ifort: error: could not checkout FLEXlm license
Anyone know how to fix this?
There are many possible reasons for this, and I'd ask that you submit an issue to Intel Premier Support and attach the license file you are using. (Do not post license files here.)
Some possibilities that occur to me:
  • The license file is not a floating or node-locked license which means it is not meant to be served
  • The command prompt session is in a Terminal Server (Remote Desktop) window and the license does not include the TS_OK attribute (this is fixed by logging into the Intel Registration Center and asking that the license key be reissued.)
There are some additional diagnostics which can be enabled, and the wonderful folks at Intel Premier Support will be glad to assist you.
Roger
Thanks!! We will contact support.
