- Als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Stummschalten
- RSS-Feed abonnieren
- Kennzeichnen
- Anstößigen Inhalt melden
Hi, I'm working on optimizing my codes written in Fortran.
In my working field, there is famous python package, 'SimPEG'.
(https://docs.simpeg.xyz/index.html -- main homepage)
(https://github.com/simpeg/simpeg -- github)
The following code is possible in python with SimPEG
dmis_grav = data_misfit.L2DataMisfit(data=data_object_grav, simulation=simulation_grav)
dmis_mag = data_misfit.L2DataMisfit(data=data_object_mag, simulation=simulation_mag)
dmis = dmis_grav + dmis_mag
inv_prob = inverse_problem.BaseInvProblem(dmis, reg, opt)
inv = inversion.BaseInversion(inv_prob, directives_list)
In the upper code, Inversion is optimization process (i.e. Gauss-Newton), and iteratively calls 'dmis' to calculate data misfit for different models.
The main point is we can make new function (or class?) by simple statement:
dmis = dmis_grav + dmis_mag.
(Everytime we call 'dmis', the program calls 'dmis_grav' and 'dmis_mag', and add them)
So, I thinking about:
Is there any coding techniques which can make this possible in Fortran?
The simple code of my idea is:
module mdata
implicit none
type :: tdat
real, dimension(2) :: d
end type tdata
end module mdata
module mmodel
implicit none
type :: tmodel
real, dimension(2) :: m
end type tmodel
end module mmodel
module msimulation1
use mdata
use mmodel
implicit none
type :: tsimulation1
type(tmodel) :: model
contains
procedure :: init_simulation1
procedure :: simulation1
end type tsimulation1
contains
subroutine init_simulation1(this, inmodel)
class(tsimulation1) :: this
type(tmodel), intent(in) :: inmodel
this%model = inmodel
end subroutine init_simulation1
subroutine simulation1(this, outdata)
class(tsimulation1), intent(in) :: this
type(tdata), intent(out) :: outdata
outdata%d(:) = this%model%m(:)*2.
end subroutine simulation1
end module msimulation1
module msimulation2
use mdata
use mmodel
implicit none
type :: tsimulation2
contains
procedure :: init_simulation2
procedure :: simulation2
end type tsimulation2
contains
subroutine init_simulation2(this, inmodel)
class(tsimulation2) :: this
end subroutine init_simulation2
subroutine simulation2(this, outdata)
outdata%d(:) = this%model%m(:)/2.
end subroutine simulation2
end module msimulation2
for the initial setting,
and need to make misfit module such as:
module mMisfit
use mdata
implicit none
type :: tL2
type(tdata) :: d
real, external :: s
contains
procedure :: init_L2
procedure :: L2DataMisfit
end type tL2
contains
subroutine init_L2(this, indata, insimulation)
class(tL2) :: this
type(tdata), intent(in) :: indata
real, external :: insimulation
this%d = indata
this%s = insimulation
end subroutine init_L2
real function L2DataMisfit(this)
class(tL2) :: this
type(tdata) :: tmpd
real :: sdot
call this%s(tmpd)
L2DataMisfit = sdot(2,this%d%d-tmpd%d,1)
end function L2DataMisfit
end module mMisfit
The upper module is impossible because of the
'real, external :: s' in 'type :: tL2'.
However, this kind of procedure-variable (?) or procedure-passing (?) is necessary to make the 'L2DataMisfit' function run for both 'simulation1' and 'simulation2' without changing module code, and only dependent on main program.
Is there any good idea to make this possible in Fortran...?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Use a procedure pointer.
The example given in the link above is not complete.
The first example should have declared the interface to (or of) QUARK.
Note, the interface can be declared as an ABSTRACE INTERFACE should you not have declared a specific actual interface.
Jim Dempsey
Link kopiert
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Jim Dempsey
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Thank you for your reply.
I haven't known about 'ABSTRACT' or 'procedure pointer' in Fortran and I studied about them.
Below is the fixed version of my code
module mdata
implicit none
type :: tdat
end type tdata
end module mdata
module mmodel
implicit none
type :: tmodel
end type tmodel
end module mmodel
module msimulation
use mdata
use mmodel
implicit none
type :: tsimulation
contains
procedure(init_simulation), deferred :: init
procedure(simulation), deferred :: run
abstract interface
subroutine init_simulation(this, inmodel)
import tsimulation, tmodel
class(tsimulation) :: this
type(tmodel) :: inmodel
subroutine simulation(this, outdata)
import tsimulation, tdata
type(tdata) :: outdata
end interface
module msimulation1
use msimulation
implicit none
type, extends(simulation) :: tsimulation1
contains
procedure :: init => init_simulation1
procedure :: run => simulation1
contains
module msimulation2
use msimulation
implicit none
type, extends(simulation) :: tsimulation2
contains
procedure :: init => init_simulation2
procedure :: run => simulation2
contains
class(tsimulation2), intent(in) :: this
end module msimulation2and misfit is
module mMisfit
use mdata
use msimulation
implicit none
type :: tL2
type(tdata) :: d
class(tsimulation), pointer :: s => null()
contains
end type tL2
contains
class(tL2) :: this
class(tsimulation), target :: insimulation
this%d = indata
this%s => insimulation
class(tL2) :: this
type(tdata) :: tmpd
real :: sdot
call this%s%run(tmpd)
end module mMisfitI used pointer for derived data type 'tL2' because in my future work, the 'simulation' class does not need to be copied (and it might require large memories).
And it works fine as:
program Main
use mdata
use mmodel
use mMisfit
use msimulation1
implicit none
type(tdata) :: d0
type(tmodel) :: m0
type(tsimulation1) :: s1
type(tL2) :: dmis
d0%d(:) = [10., 10.]
m0%m(:) = [2., 3.]
call s1%init(m0)
call dmis%init_L2(d0, s1)
print*, dmis%L2DataMisfit()
end program Main
Now, to the original question,
In python, we can make new class(?) simply by:
dmis = dmis_grav + dmis_magwhich can be used like:
inv_prob1 = inverse_problem.BaseInvProblem(dmis_mag, reg, opt)
inv_prob2 = inverse_problem.BaseInvProblem(dmis_grav, reg, opt)
inv_prob3 = inverse_problem.BaseInvProblem(dmis, reg, opt)
I think it is impossible in fortran...
The only way is defining new derived data type by extension something like:
type, abstract :: tmisfit
contains
procedure(init_misfit), deferred :: init
procedure(DataMisfit), deferred :: misfit
end type tmisfit
type, extends(tmisfit) :: tL2
type(tdata) :: d
contains
procedure :: init => init_L2
procedure :: misfit => L2DataMisfit
end type tL2
type, extends(tmisfit) :: tL2plusL2
type(tL2) :: L2_1, L2_2
contains
procedure :: init => init_L2plusL2
procedure :: misfit => L2plusL2DataMisfit
end type tL2plusL2
Do you have any better ideas...?
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
Perhaps you can look at using a generic interface.
module YourModule
type tObject_grav
real :: zzz
end type tObject_grav
type tObject_mag
real :: zzz
end type tObject_mag
type tObject_dmis
real :: zzz
end type tObject_dmis
! Provide a generic name to the interface
interface BaseInvProblem
! Specify the calling signatured procedures
procedure :: BaseInvProblem_grav, BaseInvProblem_mag, BaseInvProblem_dmis
end interface BaseInvProblem
contains
! Then called procedures with unique calling signatures
function BaseInvProblem_grav(dmis, reg, opt) result(ret)
type(tObject_grav) :: dmis
real :: reg
integer :: opt
! (code)
ret = 0 ! return value
end function BaseInvProblem_grav
function BaseInvProblem_mag(dmis, reg, opt) result(ret)
type(tObject_mag) :: dmis
real :: reg
integer :: opt
! (code)
end function BaseInvProblem_mag
function BaseInvProblem_dmis(dmis, reg, opt) result(ret)
type(tObject_dmis) :: dmis
real :: reg
integer :: opt
! (code)
end function BaseInvProblem_dmis
end module YourModule
program Console20
use YourModule
implicit none
type(tObject_grav), allocatable :: dmis_mag(:)
type(tObject_mag), allocatable :: dmis_grav(:)
type(tObject_dmis), allocatable :: dmis(:)
real :: reg
integer :: I, what, opt
do I=1, size(dmis_grav)
what = BaseInvProblem(dmis_grav(I), reg, opt) + BaseInvProblem(dmis_mag(I), reg, opt) + BaseInvProblem(dmis(i), reg, opt)
end do
end program Console20Something along the above sketch.
There are other ways to do this too.
Jim Dempsey
- Lesezeichen
- Abonnieren
- Stummschalten
- Kennzeichnen
I caution you that for large numbers of like data with high iteration counts (e.g. simulation models), that using OOP-style programming suffers with performance. With OOP-style (Array of Structures) the code may be traversing levels of code to get to the necessary operations on scalar variables. Using "traditional" Fortran (Structure of Arrays), the code generally has (relatively) immediate access to vectors of data suitable for SIMD operations (Single Instructions on Multiple Data). SoA typically has much better cache utilization as well.
Jim Dempsey
- Thema als neu kennzeichnen
- Lesezeichen
- Abonnieren
- Drucker-Anzeigeseite
