Fortran_WinPrint on Windows 2000
hhurwitz
I have used Steve Lionel's Fortran_winPrint under Windows 98SE with no problems, but, when using the same code on Windows 2000, I get a "StartDoc failed, code=6" error and the program hangs.
Before I start troubleshooting, I'd like to know whether Fortran_WinPrint has any problems with Windows 2000.
I developed it on Windows 2000. That should tell you something...
Steve
Jugoslav_Dujic
Valued Contributor II
Don't have Winprint.f90 at hand, but FYI, error 6 is "invalid handle", suggesting that printer DC was not created, which probably means that the printer wasn't connected or some similar problem.
Jugoslav
Make sure your printer is set to allow spooling. I recall a customer who had a similar problem - turned out he had disabled print spooling for the printer, and apparently that caused this symptom.
Steve
