29486 Discussions
Fortran calling C unresolved external symbol _memcpy
Ken_C_1
Have seen lots of other posts that seem tantalizingly close, but am still missing something.
I'm converting an old mixed language CVF/VC 6.0 project  to IVF 11.1/VC 2005.  I let the dev environment separate the old combined project into the two separate C and F projects as requested, and both seem to compile fine.  The Fortran output is a DLL, and it calls a couple of C routines.  When the Fortran project attempts to link, the first errors I get are
1>libirc.lib(fastmemcpy.obj) : error LNK2001: unresolved external symbol _memcpy
1>libirc.lib(tbk_backtrace.obj) : error LNK2001: unresolved external symbol _memcpy
1>simrfio.obj : error LNK2019: unresolved external symbol _memcpy referenced in function _SETSIMOUT
SETSIMOUT is a Fortran subroutine that assigns common variables to members of a big structure for output.  The above errors go away if I comment out two lines that assign to members of an array.  There is nothing in this subroutine that explicitly calls any of my C routines, yet the assignment statement seems to be trying to use the C memcpy function.
I also get bunches of errors looking for __fltused, __chkstk, all from Fortran files, then start getting __RTC_Shutdown, __RTC_InitBase etc in the actual C files.
I've tried a couple of the library things mentioned in prior threads, to no avail. Probably something obvious in the settings, but any help would be appreciated.
Ken
mecej4
Check if you are using consistent RTL options in the two projects. In other words, use /MD for both, or /MT for both, but not a mix of the two. Failing this, attach the build logs.
TimP
I agree with mecej4.   You seem to have a problem linking the Microsoft C run-time libraries.  Are you using Microsoft C for that part of your project?  If your C is defaulting to cdecl ABI, you should permit ifort to do the same (don't use /iface:cvf). (and be sure to rebuild all .obj).
Ken_C_1
Thanks so much guys!  The C project Configuration Properties\C/C++\Code Generation\RuntimeLibrary was set to Multi-threaded Debug (/MTd), and the Fortran\Libraries\Runtime Library was set to  Debug Multithreaded (/libs:static /threads/dbglibs), which seemed right to me.  But setting the Fortran Library to Debug Multithread DLL (/libs:dll /threads /dbglibs), maybe because the output is a DLL, did the trick!
