29277 Discussions
Fortran compiler doesn't create an exe file
Erez_K_1
I installed the Intel Fortran Compiler and Microsoft Visual Studio, both in their latest version. I am having an issue with building my test program. The builder runs and says it has been successful but no .exe file was created and I am unable to run the program (I get a message saying that no .exe file can be found)
I feel like there is something simple I am not doing.
Any advice?
Erez
See if https://software.intel.com/en-us/articles/problem-fortran-source-files-not-compiled-when-building-in-visual-studio helps. If not, please create a ZIP of the buildlog.htm from the project's Debug (or Release) folder and attach that to a reply here.
Erez_K_1
I tried what the page suggested and non of the "Reset to default" buttons were enabled.
Here is the log.
Erez
Lorri_M_Intel
This log shows that no files were built.
Is your test file listed as a member of the project "HW1"?   What is the name of your test file?
                  --Lorri
Erez_K_1
The name of my test file is also HW1, and I believe it is a member of the HW1 project.
Please zip your project directory (including .vfproj file) and attach it here.
Erez_K_1
Steve,
Here is the project directory.
Thanks for the help!
Erez
There are no source files in your project. There are also no source files in the ZIP. In Visual Studio, right click on the HW1 project (with the purple and white Fo icon), select Add... Existing Item, browse to your .f90 or .f source files and add them to the project.
Erez_K_1
Steve,
I think that did fix my issue. Now I can start learning the language.
Thanks for the help! I am sure I will be asking for more of it along the way.
I was looking into your blog "Dr. Fortran" and I was wondering if you have a post about Fortran for starters.
I am a senior in college and I have done work on MATLAB. I  am rewriting my code in Fortran. Any advice?
Erez
Erez,
Glad to help. I don't have a "Fortran for starters" post but do have a post on some books you might find helpful.
I have no advice on rewriting MATLAB code. Do you know any procedural programming languages? (For example, C.)
Erez_K_1
Steve,
Unfortunately  I do not.
I will look into that post.
Thanks!
Erez
Erez_K_1
Steve,
Thanks!
Erez
