Fortran compiler in docker image
Stainer__Thomas
Is it possible to have a version of the ifort compiler inside a docker image which then hosted on Docker Hub?
Would there be any issues with having the compiler on Docker Hub (public) even if no license was in the image?
Does this require a special license?
This would specifically be for Docker images with ubuntu and other linux derivations.
Kind regards,
Tom
Eugene_E_Intel
Hi Tom,
This is being discussed internally.  The current licensing mechanism is not friendly to Docker containers.
I will post an update, once I know more information.
Thank you,
Eugene
Eugene_E_Intel
If anyone else would like to have this capability, please reply to this thread.  It'll help us to gauge the demand.
Thank you,
Eugene
René_M_
My research group would very much like this too
michael_b_21
We haven't heard back.  Is there any progress on this?
In our use case, I was not planning on installing the intel compiler in the Docker container, but rather do a virtual mount of the directory into the docker container (i.e. docker -v /opt/intel:/opt/intel ...), but the license that is valid on the host does not seem to be valid in the Docker container.
Do you have any advise on this?  Is this approach possible?  I would like to use the license of the host operating system where this container is running.
This is for an academic research project comparing GCC, Clang and Intel for performance and computational reproducibility.
CSlat2
We are still interested in this ... likely a MSVS and Intel container. As part of a continuous integration server i.e. Jenkins
Stainer__Thomas
Hi Eugene,
Has there been any progress made on this? It has been over 8 months since my first post!
We are really in need of this!
Kind regards,
Tom
heuer__michael
We are also strongly interested in this as well!
Please support this as soon as possible.
DUDYALA__VENKATA_SAT
Hi All,
Does anyone have done distributed intel libraries inside a different docker containers ?
We are planning to create very less size of docker image. If i do full installation of intel then the size of image is becoming too big. So, to reduce image size we need help to understand is it possible to setup intel libraries in distributed mode
If anyone have idea. Please share your inputs.
Karthick
James_S_9
We are interested in having docker images of the intel toolchain available.
Karel_vd_Plassche
Our group and partners would also be very interested in this.
Matías_M_
We are also very much interested in this. Also just having Linux runtime in Docker would be great.
Carr__Ian
Are there any updates on this? We’d like to be able to compile fortran code in a container as well.
zhang__rui
I am interested in this too. Then, if possible, which day?
