Fortran compiler oneApi 2024
cachot
Hi!
Is it possible to use the fortran compiler oneApi 2024 with MSC Marc 2020 to use subroutines or do I need an older version of the compiler ?
Thank you,
Ugo
andrew_4619
That version is setup for the 2019 Intel  which is a paid for version now superseded by the free oneapi versions.  There is no reason why you can't use the latest software however some the the build scripts will need to be changed to reflect different file paths etc for compile and link. You might be better on a Marc  forum for that  as it is unlikely anyone here will know the answers.
andrew_4619
