Fortran -> C Interop Struggle
Krob__Jeff
All,
Trying to bone-up on calling C routines from Fortran in IVF Parallel Studio XE 2015 Composer. I thought the code was fairly simple & straight forward but a persistent error is stumping me...
error #6634: The shape matching rules of actual arguments and dummy arguments have been violated.   [IX] [IY]
The error is at the call to C_routine - "call C_croutine (ix, iy, icountsin, icountsout)"
I thought everything pertaining to arrays ix & iy was in agreement but...IVF doesn't agree. I'm sure it is something simple.
Here is the code - Thanks in advance, Jeff
    program Fortran2C
    use, intrinsic :: ISO_C_BINDING
     interface
     SUBROUTINE C_croutine(ix, iy, icountsin, icountsout) BIND(C)
        IMPORT ! Use declarations from host
        implicit none
        integer (C_INT), value :: ix
        integer (C_INT), value :: iy
        integer (C_INT), value :: icountsin
        integer (C_INT), value :: icountsout
     end SUBROUTINE C_croutine
   end interface
!    implicit none
    ! Variables
    integer  :: ix(10)
    integer  :: iy(10)
    integer  :: icountsin
    integer  :: icountsout
    ! Body of Fortran2C
    OPEN(25,FILE='Fortran2C.txt',STATUS='UNKNOWN')
    icountsout = 0
    icountsin = 0
    do i=1,10
      ix(i) = i
      iy(i) = i
      icountsin = icountsin + 1
      write(25,*)'itestx/y in = ',i,ix(i),iy(i)
    enddo
    do i=1,icountsout
      write(25,*)'itestx/y out = ',i,ix(i),iy(i)
    enddo
    end program Fortran2C
void C_croutine (int ix[], int iy[], int icountsin, int icountsout)
int    ii;
    icountsout = 0;
    for ( ii = 1; ii < icountsin; ii++ )  {
    ix[ii] = ix[ii]+1;
    iy[ii] = iy[ii]+1;
    icountsout = icountsout+1;
    return;
FortranFan
See this thread: https://software.intel.com/en-us/forums/intel-visual-fortran-compiler-for-windows/topic/505505
Here's a modified version of your code you can review and evaluate: note the modification to the last dummy argument (parameter in C parlance) and the change to the interface on the Fortran side, given how arrays are passed in C (reference to a pointer address):
void C_routine(int ix[], int iy[], int icountsin, int *icountsout)
   int ii;
   *icountsout = 0;
   for ( ii = 0; ii < icountsin; ii++ )  {
      ix[ii] = ix[ii]+1;
      iy[ii] = iy[ii]+1;
      *icountsout = *icountsout+1;
   return;
program Fortran2C
   use, intrinsic :: iso_c_binding, only : c_int
   use, intrinsic :: iso_fortran_env, only : output_unit
   implicit none
   interface
      subroutine C_routine(ix, iy, icountsin, icountsout) bind(C, name="C_routine")
         import :: c_int
         implicit none
         integer(c_int), intent(inout) :: ix(*)
         integer(c_int), intent(inout) :: iy(*)
         integer(c_int), value         :: icountsin
         integer(c_int), intent(inout) :: icountsout
      end subroutine C_routine
   end interface
   ! Variables
   integer :: ix(10)
   integer :: iy(10)
   integer :: i
   icountsout = 0
   icountsin = 0
   do i=1,10
      ix(i) = i
      iy(i) = i
      write(output_unit,*)'itestx/y in  = ',i,ix(i),iy(i)
   end do
   call C_routine (ix, iy, icountsin, icountsout)
   do i=1,icountsout
      write(output_unit,*)'itestx/y out = ',i,ix(i),iy(i)
   end do
   stop
 itestx/y in  =  1 1 1
 itestx/y in  =  2 2 2
 itestx/y in  =  3 3 3
 itestx/y in  =  4 4 4
 itestx/y in  =  5 5 5
 itestx/y in  =  6 6 6
 itestx/y in  =  7 7 7
 itestx/y in  =  8 8 8
 itestx/y in  =  9 9 9
 itestx/y in  =  10 10 10
 itestx/y out =  1 2 2
 itestx/y out =  2 3 3
 itestx/y out =  3 4 4
 itestx/y out =  4 5 5
 itestx/y out =  5 6 6
 itestx/y out =  6 7 7
 itestx/y out =  7 8 8
 itestx/y out =  8 9 9
 itestx/y out =  9 10 10
 itestx/y out =  10 11 11
Press any key to continue . . .
Krob__Jeff
Thanks for the reply - I'm pretty sure I made all the changes you noted...but now I'm getting;
error LNK2019: unresolved external symbol _C_routine referenced in function _MAIN__    Fortran2C.obj
Are there some 'Properties' settings which need to be adjusted (Fortran or C)?
Also, as to passing "icountsout", if it is not used as a pointer within C_routine, does it still need to be passed as a pointer (I prefer to avoid pointer use)?
Thanks again,
Jeff
jimdempseyatthecove
That is a linker error. Either
a) you are not linking in C_routine.obj (or whatever name of the object file was when you built it)
or
b) You compiled the C_routine.cpp as a .CPP file type which uses name mangled entry points. If you do use CPP compiler then you must decorate your function with
extern "C"
Jim Dempsey
FortranFan
Thanks again,
Jeff
As Jim indicated, you need to make sure the object for your C routine is appropriately included in the link command.
Re: your other question on icountsout, you need to spend some time to learn how C works and what you need to do if you want a variable to be modified within a C function.  As you'd know, there are lots of resources online e.g., http://www.tutorialspoint.com/cprogramming/c_function_call_by_reference.htm.
Krob__Jeff
All,
OK - got it ironed out. The Build Order/Dependencies was backwards - C_routine was dependent to & built after Fortran2C instead of vice-versa. Now, time to start experimenting with passing different arguments/parameters to C_routine, modifying them & see what is returned.
OH JOY!! ;-)
Thanks again,
Jeff
