All,
Got 2 questions in trying to get Fortran & C TYPES/typdefs working.
First, the typedefs in C;
typedef struct /* Polygon vertex structure */
double x; /* Vertex x component */
double y; /* vertex y component */
} gpc_vertex;
typedef struct /* Vertex list structure */
int num_vertices; /* Number of vertices in list */
gpc_vertex vertex; /* Vertex */
} gpc_vertex_list;
Now, the Fortran equivalent TYPES;
use, intrinsic :: ISO_C_BINDING
TYPE, BIND(C) :: F_GPC_VERTEX ! /* Polygon vertex structure */
REAL(8) (C_FLOAT) :: x ! /* Vertex x component */
REAL(8) (C_FLOAT) :: y ! /* vertex y component */
END TYPE
TYPE, BIND(C) :: F_GPC_VERTEX_LIST ! /* Vertex list structure */
INTEGER(C_INT) :: num_vertices ! /* Number of vertices in list */
TYPE (F_GPC_VERTEX) :: vertex ! /* Vertex */
END TYPE
Now, the compilation errors with the "REAL(8) (C_FLOAT) :: " x & y with
error #5082: Syntax error, found '(' when expecting one of: :: %FILL , INTEGER REAL COMPLEX TYPE BYTE CHARACTER CLASS DOUBLE DOUBLECOMPLEX ..."
but works with just "REAL (C_FLOAT) :: " ...but the C typdef is a double float. Why will it not allow the REAL(8)?
Two - is the "TYPE (F_GPC_VERTEX) :: vertex" an example of a Type Extension?
Thanks in advance,
Jeff
If you wrote up a little program to print out C_FLOAT:
USE ISO_C_BINDING PRINT *, C_FLOAT END
You would find that C_FLOAT = 8 . Thus REAL(8)(C_FLOAT) is going to look like REAL(8)(8) to the compiler. You want to get rid of one of those 8's and the one to eliminate is the first is you just have REAL(C_FLOAT) . That way if KIND([DOUBLE PRECISION::]) is not 8, as would be the case by default on Silverfrost's compiler, you would still be declaring a type equivalent to C double.
Your example has nested derived types, not type extension. Look up the EXTENDS attribute in your favorite Fortran documentation.
Actually, C_FLOAT is 4. C_DOUBLE is what is wanted here. But otherwise, RO is spot on (as usual).
OK Steve & RO - got it thanks. Along those lines, to pass a TYPE as an argument to a C routine, how would the interface be constructed? For example, I need to call the C routine "gpc_read_polygon( fpread, readholeflag, subject_polygon )". The C-side is like this:
void gpc_read_polygon(FILE *fp, int read_hole_flags, gpc_vertex_list *p)
"FILE *fp" is a pointer for the open file to be read, "read_hole_flags" is just a 1 or 0 but the "gpc_vertex_list *p" is the typedef struct (defined previously above) passed from the Fortran side. So, from what I can guess, the Fortran interface would look something like:
interface
SUBROUTINE gpc_read_polygon( fpread, readholeflag, subject_polygon ) &
BIND(C, name="gpc_read_polygon")
IMPORT :: c_int,c_float
implicit none
integer (C_INT), intent(inout) :: fpread
integer (C_INT), value :: readholeflag
* * * * * :: subject_polygon ! <<<<< what goes here???
end SUBROUTINE gpc_read_polygon
end interface
Thanks again,
Jeff
Please copy the dummy argument names from the C documentation verbatim unless they conflict with other names. This makes your interface much more self-documenting. You neglected to mention that the vertex member of struct gpc_vertex_list was a pointer, not directly a struct type. This makes a difference. Also that FILE* fp argument is a C file pointer not a Fortran unit number, so you need a little C helper function to get open that file and get the pointer for you. Maybe ifort has an extension that can do it, but likely that's more problematic. Also I don't know whether the struct pointed at by a FILE* is the same between C compilers, so you might have a problem if the C library used by the gpc library is different from the one used to compile my C example. Perhaps gpc also provides a function to open files and return a FILE* for you already; search for something llike that in the docs.
Here is my translation of your module so far:
module gpc use, intrinsic :: ISO_C_BINDING implicit none TYPE, BIND(C) :: F_GPC_VERTEX REAL(C_DOUBLE) :: x ! Stop programming in my blind spot! REAL(C_DOUBLE) :: y END TYPE F_GPC_VERTEX TYPE, BIND(C) :: F_GPC_VERTEX_LIST INTEGER(C_INT) :: num_vertices TYPE(C_PTR) :: vertex END TYPE F_GPC_VERTEX_LIST interface SUBROUTINE gpc_read_polygon(fp, read_hole_flags, p) & BIND(C,name='gpc_read_polygon') IMPORT :: C_PTR, C_INT, F_GPC_VERTEX_LIST ! Enough with C_FLOAT! implicit none TYPE(C_PTR), value :: fp integer(C_INT), value :: read_hole_flags TYPE(F_GPC_VERTEX_LIST) p end SUBROUTINE gpc_read_polygon end interface end module gpc
As mentioned you will need a C helper function or, better, use a helper function from the gpc package to open the file for reading:
#include <stdio.h>
FILE* IOhelper(char * filename)
return fopen(filename,"r");
Example of usage:
subroutine sub use gpc implicit none type(C_PTR) :: fp interface function IOhelper(filename) bind(C,name='IOhelper') import implicit none character(KIND=C_CHAR), intent(in) :: filename(*) type(C_PTR) IOhelper end function IOhelper end interface character(80) filename TYPE(F_GPC_VERTEX_LIST) p integer(C_INT) read_hole_flags filename = 'whatever'//C_NULL_CHAR ! Null termination required for fopen fp = IOhelper(filename) read_hole_flags = 1 ! Or maybe 0 call gpc_read_polygon(fp, read_hole_flags, p) ! I assume you don't need to look at the contents of that gpc_vertex_list. ! Also I assume that the package manages the memory it points at. end subroutine sub
All untested :)
OK...thanks for the info. 1) so a file to be read or written in a C routine can only be opened & closed within C & not within Fortran? 2) if the same C routine is called within a Fortran routine but with different arguments, each call to the C routine must have it's own interface definition?
1) I'm not saying that it's impossible, I can't find any documentation on how you would obtain the FILE* pointer from Fortran. Furthermore, I don't even know whether a FILE* obtained with code compiled on one C compiler can be used with code compiled with another C compiler.
2) Not at all. Normally you want to define just one interface, put its interface block in a module, and USE that module in any scoping unit that will call the C routine. I rewrote your TYPE(F_GPC_VERTEX_LIST) and interface to gpc_read_polygon() from scratch because there were enough errors present already that I thought it best to have a reference point for further discussion in one place rather than keeping track of the edits across the thread.
RO - thanks for all the info...and your patience however, I need some clarification on some code you wrote above. In the definition of the TYPES, you wrote:
REAL(C_DOUBLE) :: x
REAL(C_DOUBLE) :: y
END TYPE
TYPE(C_PTR) :: vertex ! <<<< THIS!!!
END TYPE
in changing the "vertex" from a "TYPE (F_GPC_VERTEX) :: " to a "TYPE(C_PTR) ::" it looks like it lost it's association to F_GPC_VERTEX ...which is required. There is code like this:
*npoly = contour->num_vertices;
for ( ii = 0; ii < *npoly; ii++ ) {
px[ii] = contour->vertex[ii].x;
py[ii] = contour->vertex[ii].y;
I understand how the structure works in C & it's Fortran equiv...but I don't understand how what you wrote works to support what is needed in the gpc library. Also, to make it work in a 'traditional' (non-pointer) way, the "vertex" needs to be an ALLOCATABLE array because it is dynamic in operation as polygon vertex point are added or removed by the operations. Now, I understand allocatable arrays are not allowed with derived types with the BIND attribute...but neither are pointers!!! Does that mean I'm at a dead-end in this project?
Well, I thought I might have had a solution, but there is a problem. I started with an input file, stuff.dat:
3.14159265 2.99792458 0.30103 6.62559 1.38054 1.008
I modified the gpc module file a little:
module gpc use, intrinsic :: ISO_C_BINDING implicit none private public F_GPC_VERTEX, F_GPC_VERTEX_LIST, F_GPC_POLYGON, gpc_read_polygon TYPE, BIND(C) :: F_GPC_VERTEX REAL(C_DOUBLE) :: x REAL(C_DOUBLE) :: y END TYPE F_GPC_VERTEX TYPE, BIND(C) :: F_GPC_VERTEX_LIST INTEGER(C_INT) :: num_vertices TYPE(C_PTR) :: vertex END TYPE F_GPC_VERTEX_LIST TYPE, BIND(C) :: F_GPC_POLYGON integer(C_INT) num_contours type(C_PTR) hole type(C_PTR) contour END TYPE F_GPC_POLYGON interface SUBROUTINE gpc_read_polygon(infile_ptr, read_hole_flags, polygon) & BIND(C,name='gpc_read_polygon') IMPORT :: C_PTR, C_INT, F_GPC_VERTEX_LIST ! Enough with C_FLOAT! implicit none TYPE(C_PTR), value :: infile_ptr integer(C_INT), value :: read_hole_flags TYPE(F_GPC_VERTEX_LIST) polygon end SUBROUTINE gpc_read_polygon end interface end module gpc
Then I wrote up some interfaces for C library functions:
module MSVCRT use ISO_C_BINDING implicit none private public fopen, fclose, malloc, free ! Delete fscanf in actual use public fscanf interface function fopen(filename, mode) bind(C,name='fopen') import implicit none type(C_PTR) fopen character(KIND=C_CHAR), intent(IN) :: filename(*) character(KIND=C_CHAR), intent(IN) :: mode(*) end function fopen function fclose(stream) bind(C,name='fclose') import implicit none integer(C_INT) fclose type(C_PTR), value :: stream end function fclose ! fscanf is only used for the purposes of completing this example ! delete this interface to a variadic function in real use function fscanf(stream, format, result) bind(C,name='fscanf') import implicit none integer(C_INT) fscanf type(C_PTR),value :: stream character(KIND=C_CHAR), intent(IN) :: format(*) real(C_DOUBLE) result end function fscanf function malloc(size) bind(C,name='malloc') import implicit none type(C_PTR) malloc integer(C_SIZE_T), value :: size end function malloc subroutine free(ptr) bind(C,name='free') import implicit none type(C_PTR), value :: ptr end subroutine free end interface end module MSVCRT
And a test program:
program P use MSVCRT use ISO_C_BINDING use gpc implicit none character(KIND=C_CHAR) filename(20) character(KIND=C_CHAR) mode(20) character(KIND=C_CHAR) C_format(20) type(C_PTR) fp type(F_GPC_POLYGON) polygon integer(C_INT) num_contours type(F_GPC_VERTEX_LIST), pointer :: vertex_list(:) integer npts type(F_GPC_VERTEX), pointer :: vertices(:) integer(C_INT) res character(20) fmt integer i, j filename = 'stuff.dat' // C_NULL_CHAR ! NUL-termination required mode = 'r' // C_NULL_CHAR fp = fopen(filename,mode) write(*,'(z0)') transfer(fp,0_C_INTPTR_T) num_contours = 1 polygon%num_contours = num_contours polygon%hole = C_NULL_PTR ! Not used in my example ! polygon%contour = malloc(num_contours*C_SIZEOF(vertex_list)) polygon%contour = malloc(num_contours*C_SIZEOF(F_GPC_VERTEX_LIST(0,C_NULL_PTR))) write(*,'(z0)') transfer(polygon%contour,0_C_INTPTR_T) call C_F_POINTER(polygon%contour,vertex_list,[num_contours]) do i = 1, num_contours npts = 3 ! Or whatever is in your file vertex_list(i)%num_vertices = npts vertex_list(i)%vertex = malloc(npts*C_SIZEOF(F_GPC_VERTEX(0,0))) write(*,'(i0,1x,z0)') i,transfer(vertex_list(i)%vertex,0_C_INTPTR_T) call C_F_POINTER(vertex_list(i)%vertex,vertices,[npts]) C_format = '%lf' // C_NULL_CHAR do j = 1, npts res = fscanf(fp, C_format, vertices(j)%x) res = fscanf(fp, C_format, vertices(j)%y) write(*,'(i0,1x,i0,1x,g0,1x,g0)') i, j, vertices(i)%x,vertices(i)%y end do end do res = fclose(fp) fmt = '(2(f8.6))' do i = 1, num_contours call C_F_POINTER(vertex_list(i)%vertex,vertices,[vertex_list(i)%num_vertices]) do j = 1, size(vertices) write(*,fmt) vertices(j) end do end do do i = 1, polygon%num_contours call free(vertex_list(i)%vertex) end do call free(polygon%contour) end program P
Unfortunately ifort blew up on that first invocation of fopen(), and gfortran returned NULL, so someone with better knowledge of C is going to have to figure out how to fix that situation.
Where is the interface to fopen declared?
Jim Dempsey
@jimdempseyatthecove: First interface body in module MSVCRT above.
GOT IT!!
The problem was that I declared all my character variables as LEN=1, DIMENSION(20), rather than LEN=20. Fixing that,
program P use MSVCRT use ISO_C_BINDING use gpc implicit none character(LEN=20,KIND=C_CHAR) filename character(LEN=20,KIND=C_CHAR) mode character(LEN=20,KIND=C_CHAR) C_format type(C_PTR) fp type(F_GPC_POLYGON) polygon integer(C_INT) num_contours type(F_GPC_VERTEX_LIST), pointer :: vertex_list(:) integer npts type(F_GPC_VERTEX), pointer :: vertices(:) integer(C_INT) res character(20) fmt integer i, j filename = 'stuff.dat' // C_NULL_CHAR ! NUL-termination required mode = 'r' // C_NULL_CHAR fp = fopen(filename,mode) write(*,'(z0)') transfer(fp,0_C_INTPTR_T) num_contours = 1 polygon%num_contours = num_contours polygon%hole = C_NULL_PTR ! Not used in my example ! polygon%contour = malloc(num_contours*C_SIZEOF(vertex_list)) polygon%contour = malloc(num_contours*C_SIZEOF(F_GPC_VERTEX_LIST(0,C_NULL_PTR))) write(*,'(z0)') transfer(polygon%contour,0_C_INTPTR_T) call C_F_POINTER(polygon%contour,vertex_list,[num_contours]) do i = 1, num_contours npts = 3 ! Or whatever is in your file vertex_list(i)%num_vertices = npts vertex_list(i)%vertex = malloc(npts*C_SIZEOF(F_GPC_VERTEX(0,0))) write(*,'(i0,1x,z0)') i,transfer(vertex_list(i)%vertex,0_C_INTPTR_T) call C_F_POINTER(vertex_list(i)%vertex,vertices,[npts]) C_format = '%lf' // C_NULL_CHAR do j = 1, npts res = fscanf(fp, C_format, vertices(j)%x) res = fscanf(fp, C_format, vertices(j)%y) write(*,'(i0,1x,i0,1x,g0,1x,g0)') i, j, vertices(i)%x,vertices(i)%y end do end do res = fclose(fp) fmt = '(2(f8.6))' do i = 1, num_contours call C_F_POINTER(vertex_list(i)%vertex,vertices,[vertex_list(i)%num_vertices]) do j = 1, size(vertices) write(*,fmt) vertices(j) end do end do do i = 1, polygon%num_contours call free(vertex_list(i)%vertex) end do call free(polygon%contour) end program P
Led to good output:
7FF7A6F3E2A0 6D1F15BBA0 1 6D1F15DEE0 1 1 3.141592650000000 2.997924580000000 1 2 3.141592650000000 2.997924580000000 1 3 3.141592650000000 2.997924580000000 3.1415932.997925 0.3010306.625590 1.3805401.008000
What an ugly bug :(
RO - THANKS!! I deeply appreciate that! I was concerned that the file pointers were being mangled going back & forth btwn C & Fortran. Now, the next test is to use this as a template but read in two polygon files (Subject & Clip), populate the two created F_GPC_POLYGON polygon structures, feed them through the gpc_polygon_clip routine...and see what comes out the other end.
Ya gots to do what ya gots to do!
Thanks again, Jeff
Yes, but there are still questions about why the call to fopen with bad inputs caused a crash when it's supposed to just set fp to C_NULL_PTR and set errno to some nonzero value. If you just set mode = 'xyz' // C_NULL_CHAR above it reproduces the crash, here is a minimal example:
module M use ISO_C_BINDING implicit none interface function fopen(filename, mode) bind(C,name='fopen') import implicit none type(C_PTR) fopen character(KIND=C_CHAR), intent(IN) :: filename character(KIND=C_CHAR), intent(IN) :: mode end function fopen end interface end module M program P use M implicit none character(LEN=20,KIND=C_CHAR) filename character(LEN=20,KIND=C_CHAR) mode type(C_PTR) fp filename = 'nonexistent' // C_NULL_CHAR mode = 'xyz' // C_NULL_CHAR fp = fopen(filename,mode) write(*,'(z0)') transfer(fp,0_C_INTPTR_T) end program P
The above crashes at the fopen invocation. Am I doing something wrong or is ifot corrupting the data structures used by the C runtime library somehow?
Oh, and what about errno? The above doesn't survive long enough to print out errno, but the IFPORT function IERRNO doesn't seem to agree with what the C library considers to be errno:
module M use ISO_C_BINDING implicit none interface function errno_address() bind(C,name='_errno') import implicit none type(C_PTR) errno_address end function errno_address end interface end module M program P use M use IFPORT implicit none type(C_PTR) address integer(C_INT), pointer :: errno integer(4) errval1, errval2 address = errno_address() call C_F_POINTER(address, errno) errval1 = errno errval2 = ierrno() write(*,*) 'errno = ', errval1 write(*,*) 'ierrno() = ', errval2 errno = 22 errval1 = errno errval2 = ierrno() write(*,*) 'errno = ', errval1 write(*,*) 'ierrno() = ', errval2 end program P
Prints out:
errno = 0 ierrno() = 0 errno = 22 ierrno() = 0
Repeat Offender wrote:
.. If you just set mode = 'xyz' // C_NULL_CHAR above it reproduces the crash, ..
In this case, the culprit is the companion C processor (in this case, the one authored by the behemoth in Redmond, WA?) The crash is reproducible with the simple C example:
#include <stdio.h>
int main()
FILE *fp;
fp = fopen("file.txt", "xyz");
if (fp != NULL) {
printf("fopen returned fp = %p.\n", fp);
else {
printf("fopen failed.\n");
fclose(fp);
return(0);
whereas with GCC, a NULL pointer is returned in fp and code stops gracefully.
When only the first parameter is bogus (e.g., it corresponds to a non-existent file), no crash is noticed, either with C-only code (whether with GCC or Microsoft C/C++ compiler) or with Fortran invoking fopen function interfaced as above using standard interoperability features and compiled with either gfortran or Intel Fortran.
RO - if I may get back to the original subject for a quick clarification, I noticed you went above & beyond the call by translating gpc_polygon_read to fortran instead of just interfacing to it as was my intention. This raises a question concerning the Fortran TYPE structutres (F_GPC_POLYGON) & C typedef struct (gpc_polygon) interactions. Since the gpc_polygon struct is initialized & populated within gpc_polygon_read, when the result is passed back to the fortran routine, will F_GPC_POLYGON automatically aquire the shape & contents of what was passed from the C routine or does it need to be initialized (memory allocated, etc.) separately and, if so, does that need to be done before gpc_polygon_read is called or just before the F_GPC_POLYGON structure is used in Fortran code?
Thanks again for all your help, Jeff
@FortranFan -- Thanks for testing this with MSVC++. I tried a further test with gfortran:
module M use ISO_C_BINDING implicit none interface function fopen(filename, mode) bind(C,name='fopen') import implicit none type(C_PTR) fopen character(KIND=C_CHAR), intent(IN) :: filename character(KIND=C_CHAR), intent(IN) :: mode end function fopen function errno_address() bind(C,name='_errno') import implicit none type(C_PTR) errno_address end function errno_address end interface end module M program P use M implicit none character(LEN=20,KIND=C_CHAR) filename character(LEN=20,KIND=C_CHAR) mode type(C_PTR) fp type(C_PTR) address integer(C_INT), pointer :: errno integer(4) errval1, errval2 address = errno_address() call C_F_POINTER(address, errno) errval1 = errno errval2 = ierrno() write(*,*) 'errno = ', errval1 write(*,*) 'ierrno() = ', errval2 filename = 'nonexistent' // C_NULL_CHAR mode = 'xyz' // C_NULL_CHAR fp = fopen(filename,mode) errval1 = errno errval2 = ierrno() write(*,'(a,z0)') 'fp = ',transfer(fp,0_C_INTPTR_T) write(*,*) 'errno = ', errval1 write(*,*) 'ierrno() = ', errval2 end program P
with output:
errno = 2 ierrno() = 2 fp = 0 errno = 22 ierrno() = 22
Showing once again that the gcc fopen() behaves as documented and that gfortran's ierrno() extension is synchronized with the C errno, unlike what was the case with the ierrno() from IFPORT. Indeed, if the mode variable above is modified to something valid so the code doesn't crash with ifort, and USE IFPORT is added, the output we get with ifort is:
errno = 0
ierrno() = 0
fp = 0
errno = 2
ierrno() = 0
Which shows that IFPORT's ierrno() extension is not synchronized with the C errno. I have been using C interoperability throughout, and seem to be justified in that IFPORT has to a certain extent been obsoleted by this f2003 feature.
Maybe you could find a C forum you could post your C code to and figure out if there is some way to get MSVCRT not to crash when it sees an invalid mode= actual argument. Searching the web I found a few posts about this phenomenon in stackoverflow, but the only cure proposed was to pass a valid mode= argument, which sort of makes fopen() into a loaded gun that could crash your program unexpectedly.
@Jeff K. -- There are several ways to manage memory for these data structures. One way might have been to create parallel Fortran data structures and then use the C_LOC function from the ISO_C_BINDING module and the intrinsic SIZE inquiry function to see how to populate the desired C data structures with data counts and C-style pointers. While this would have made it easier to read and write the data on the Fortran side, it would have necessitated keeping that parallel Fortran data structure in scope as long as the C data structure was active. Also C wouldn't have been able to allocate and deallocate memory within its data structures if this scheme were used.
I showed how Fortran can simply call malloc() and free() from the C standard library to allocate and deallocate memory and then use C_F_POINTER to get good Fortran array pointers that you can use to read and write the arrays. I did this because I didn't want to have to install the whole topical package just to answer this question.
Obviously if gpc_read_polygon() can do the allocation for you and the FILE* pointer that was obtained in my examples above works, that, along with gpc_free_polygon() would be the preferred method of managing memory for you.
The question about whether F_GPC_POLYGON automatically acquires the shape & contents of what was passed from the C routine is kind of thinking about the problem at the wrong level of indirection in my opinion. The structure that you see is exactly what C wrote, with naked pointers, containing only an address, unlike the fat pointers that Fortran provides. To read the arrays pointed at by these naked pointers, you have to get a fat Fortran pointer from them with C_F_POINTER, but the good news is that I showed how to perform exactly that task in my example in Quote #12, so careful study of that example and the ifort documentation and you should be good to go.
IERRNO in IFPORT does not claim to be the same as C errno.
Returns the number of the last detected error from any routines in the IFPORT module that return error codes.
That's the problem with "portability routines" in that they don't always mean the same thing across implementations. And by the way, in Intel Fortran for Windows, there is no connection whatsoever between Fortran units and C files.
Continuing the saga...building up to properly interface to the General Polygon Clipper C library, I find I can open a polygon text file in my C routine C_fopen.c but the file pointer is not being returned to the main program to be passed to gpc_read_polygon later. I thought I had all my definitions & interfaces correct...but I guess not ;-).
PROGRAM F2CTest
USE GPC2
interface
subroutine C_fopen(ifp, filename, mode, ier) &
bind(C,name='C_fopen')
import
implicit none
type(C_PTR),value :: ifp
integer(C_int), intent(inout) :: ier
end subroutine C_fopen
end interface
character (len=40,KIND=C_CHAR) :: filename
character (len=4,KIND=C_CHAR) :: mode
character (len=20,KIND=C_CHAR) :: C_format
integer :: ier,readholeflag
real(8) :: result
type(C_PTR) :: ifp
type(C_GPC_POLYGON) C_subject_polygon, C_clip_polygon, C_result_polygon
integer(C_INT) C_num_contours
type(C_GPC_VERTEX_LIST), pointer :: C_contour(:)
integer C_npts
type(C_GPC_VERTEX), pointer :: C_vertex(:)
OPEN(25,FILE='TESTGPC.TXT',STATUS='UNKNOWN')
WRITE (25,*)'START TESTGPC'
C_subject_polygon%num_contours = 0
C_subject_polygon%hole = C_NULL_PTR
C_clip_polygon%num_contours = 0
C_result_polygon%num_contours = 0
C_contour%num_vertices = 0
mode = 'r'// C_NULL_CHAR
readholeflag = 0
ier = 0
write(25,*)'mode = ',mode
write(25,*)'filename = ',filename
Call C_fopen (ifp, filename, mode, ier)
iifp = transfer(ifp,0_C_INTPTR_T)
write(25,*)'C_fopen ier = ',ier,iifp
! coming later...
!CALL gpc_read_polygon( ifp, readholeflag, C_subject_polygon )
end
/* fopen example */
#include <stdio.h>
void C_fopen (FILE *pFile, char *newname, char *mode, int ier)
ier = 0;
printf ("C_fopen: fopen mode = %s \n",mode);
pFile = fopen (newname,mode);
if (pFile==NULL)
printf ("C_fopen: fopen error = %p \n",pFile);
ier = 9999;
if (pFile!=NULL)
printf ("C_fopen: pFile good = %p \n",pFile);
The screen prints show the file is being opened properly w/ a good pointer created & no errors.
> C_fopen: fopen mode = r
> C_fopen: pFile good = 1035F4F8
but the print after the call to C_fopen to show the Fortran version of the pointer says;
C_fopen ier = 0 0
iifp should not be '0' so I can only guess the "type(C_PTR) :: ifp" is not being returned...why?
Thanks in advance,
Jeff
You are not being careful about the level of indirection in your C interface. You could have just followed the example I posted in Quote #17, which invoked fopen() and got errno directly from Fortran, but instead you had to make it harder on yourself by using a C function to do it.
In your Fortran interface to C_fopen, you are passing ifp by value, which means that it won't be changed upon return. Thus you need to pass ifp by reference, just get rid of that ",value" stuff in that interface body. Also that means you don't get a pointer to a FILE structure (FILE*) in the actual C_fopen function, but a pointer to a pointer (FILE**), thus you should change your declaration there to FILE **pFile. Also the 5 places pFile is referenced in the body of C_fopen() will have to be changed from "pFile" to "*pFile" to dereference that pointer that you received from the Fortran caller.
Also, the Fortran program is correct to pass ier by reference as it does so that it can receive a result through that argument, but that means that ier should be declared as a pointer to int , i.e. int *ier in your C function and the two places where it is referenced you must change "ier" to "*ier" to dereference that pointer. Getting this level of indirection right is tricky until you have traced through function calls in machine language a few times, after that it all makes sense.
