29641 Discussions
Fortran interface for Raw Input Windows functions
R_K
I am attempting to create Fortran interfaces for windows raw input functions that are missing in the supplied user32.f90. However, can not make GetRawInputDeviceList work. Checked out many different options but always get error ERROR_INVALID_PARAMETER. Here one of the tested interfaces:
MODULE RawInputStructures
USE ifwinty
TYPE, PUBLIC:: RAWINPUTDEVICELIST
SEQUENCE
INTEGER(HANDLE):: hDevice
INTEGER(DWORD):: dwType
END TYPE RAWINPUTDEVICELIST
END MODULE RawInputStructures
MODULE RawInputFunctions
USE ifwinty
INTERFACE
FUNCTION GetRawInputDeviceList(pRawInputDeviceList, puiNumDevices, cbSize)
USE ifwinty
USE RawInputStructures
INTEGER(UINT):: GetRawInputDeviceList
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'GetRawInputDeviceList' :: GetRawInputDeviceList
!DEC$ ATTRIBUTES REFERENCE :: pRawInputDeviceList
TYPE(RAWINPUTDEVICELIST), INTENT(OUT), DIMENSION(:):: pRawInputDeviceList
!DEC$ ATTRIBUTES REFERENCE :: puiNumDevices
INTEGER(PUINT), INTENT(INOUT):: puiNumDevices
!DEC$ ATTRIBUTES REFERENCE:: cbSize
INTEGER(UINT), INTENT(IN):: cbSize
END FUNCTION GetRawInputDeviceList
END INTERFACE
END MODULE RawInputFunctions
PROGRAM WindowsRawInput
USE USER32
USE KERNEL32
USE ifwinty
USE RawInputFunctions
IMPLICIT NONE
INTEGER(UINT):: ret
INTEGER(PUINT):: NumDevices
INTEGER(UINT):: cbSize
TYPE(RAWINPUTDEVICELIST), DIMENSION(1:4):: DeviceList
NumDevices = SIZE(DeviceList)
cbSize = SIZEOF(DeviceList)
ret = GetRawInputDeviceList(DeviceList, NumDevices, cbSize)
WRITE(*,*) 'GetRawInputDeviceList = ', ret
IF (ret .LT. 0) WRITE(*,*) 'GetLastError = ', GetLastError()
WRITE(*,*) 'NumDevices = ', NumDevices
READ(*,*)
STOP
END PROGRAM WindowsRawInput
Please advise what is wrong here.
jimdempseyatthecove
cbSize is the size of a RAWINPUTDEVICELIST, not the size of the array of RAWINPUTDEVICELISTs
Try
cbSize = SIZEOF(RAWINPUTDEVICELIST)
Also, cbSize is to be passed by value, not reference.
Hint, also, if you continue to have issues, write a C callable shell function (that works) and call that from Fortran.
You can look at the disassembly code to check the values of the arguments.
Jim Dempsey
jimdempseyatthecove
Try
Jim Dempsey
andrew_4619
This works, notice th
module RawInputStructures
    use ifwinty
    type, bind(c) :: rawinputdevicelist
        integer(handle):: hdevice
        integer(dword) :: dwtype
    end type rawinputdevicelist
    interface
        function GetRawInputDeviceList(pRawInputDeviceList, puiNumDevices, cbSize) BIND(C,NAME="GetRawInputDeviceList")
            import
            !DIR$ ATTRIBUTES STDCALL :: GetRawInputDeviceList
            !GCC$ ATTRIBUTES STDCALL :: GetRawInputDeviceList
            INTEGER(UINT)          :: GetRawInputDeviceList
            integer(handle), value    :: pRawInputDeviceList
            INTEGER(handle), value :: puiNumDevices
            INTEGER(UINT), value   :: cbSize
    end interface
end module RawInputStructures
Program WindowsRawInput
    USE USER32
    USE KERNEL32, only: GetLastError
    USE ifwinty
    USE RawInputStructures, only: RAWINPUTDEVICELIST, GetRawInputDeviceList
    use, intrinsic :: iso_c_binding, only: c_loc
    IMPLICIT NONE
    INTEGER(UINT):: ret
    INTEGER(PUINT), target:: NumDevices
    TYPE(RAWINPUTDEVICELIST), target:: DeviceList(50)
    NumDevices = 0
    cbSize     = SIZEOF(DeviceList(1))
    ret = GetRawInputDeviceList(  0_handle, transfer( c_loc(NumDevices), 0_handle), cbSize )
    write(*,*) 'GetRawInputDeviceList = ', ret
    if (ret .lt. 0) write(*,*) 'GetLastError = ', GetLastError()
    write(*,*) 'NumDevices = ', NumDevices
    ret = GetRawInputDeviceList( transfer( c_loc(DeviceList), 0_handle),&
    read(*,*)
    stop
end program Windowsrawinput
e first call to get the number of devices which on my system was 15!
R_K
Dear Andrew,
thank you for code. It is very instructive much more than solution of specific problem.
RK
