29407 Discussions
Fortran regression in 21.5 to 21.7 with submodules
Juergen_R_R
Valued Contributor II
The following code does not compile anymore with Intel 21.7, while it is compiling with all versions of Intel 19, Intel 20 and Intel <=21.5.
Could you please report this to the Intel development team. This is pretty bad for our code.
module ifiles
  implicit none
  private
  public :: ifile_t
  public :: ifile_clear
  public :: ifile_final
  public :: ifile_read
  public :: ifile_write
  public :: ifile_get_length
  public :: line_p
  public :: line_init
  public :: line_final
  public :: line_advance
  public :: line_backspace
  public :: line_is_associated
  public :: line_get_index
  public :: line_get_length
  type :: line_entry_t
     private
     type(line_entry_t), pointer :: previous => null ()
     type(line_entry_t), pointer :: next => null ()
     integer :: index
  end type line_entry_t
  type :: ifile_t
     private
     type(line_entry_t), pointer :: first => null ()
     type(line_entry_t), pointer :: last => null ()
     integer :: n_lines = 0
   contains
     procedure :: final => ifile_clear
  end type ifile_t
  type :: line_p
     private
     type(line_entry_t), pointer :: p => null ()
  end type line_p
  interface ifile_final
     module procedure ifile_clear
  end interface
  interface ifile_read
     module procedure ifile_read_from_char
     module procedure ifile_read_from_unit
     module procedure ifile_read_from_char_array
     module procedure ifile_read_from_ifile
  end interface
  interface
    module subroutine ifile_clear (ifile)
      class(ifile_t), intent(inout) :: ifile
    end subroutine ifile_clear
    module subroutine ifile_read_from_char (ifile, char)
      type(ifile_t), intent(inout) :: ifile
      character(*), intent(in) :: char
    end subroutine ifile_read_from_char
    module subroutine ifile_read_from_char_array (ifile, char)
      character(*), dimension(:), intent(in) :: char
    end subroutine ifile_read_from_char_array
    module subroutine ifile_read_from_unit (ifile, unit, iostat)
      integer, intent(in) :: unit
      integer, intent(out), optional :: iostat
    end subroutine ifile_read_from_unit
    module subroutine ifile_read_from_ifile (ifile, ifile_in)
      type(ifile_t), intent(in) :: ifile_in
    end subroutine ifile_read_from_ifile
    module subroutine ifile_write (ifile, unit, iostat)
      integer, intent(in), optional :: unit
    end subroutine ifile_write
    module function ifile_get_length (ifile) result (length)
      integer :: length
    end function ifile_get_length
    module subroutine line_init (line, ifile, back)
      type(line_p), intent(inout) :: line
      logical, intent(in), optional :: back
    end subroutine line_init
    module subroutine line_final (line)
    end subroutine line_final
    module subroutine line_advance (line)
    end subroutine line_advance
    module subroutine line_backspace (line)
    end subroutine line_backspace
    module function line_is_associated (line) result (ok)
      logical :: ok
      type(line_p), intent(in) :: line
    end function line_is_associated
    module function line_get_index (line) result (index)
      integer :: index
    end function line_get_index
    module function line_get_length (line) result (length)
      integer :: length
    end function line_get_length
  end interface
end module ifiles
module lexers
  use ifiles, only: ifile_t
  use ifiles, only: line_p
  implicit none
  private
  public :: stream_t
  public :: stream_init
  public :: stream_final
  public :: keyword_list_t
  public :: keyword_list_write
  public :: keyword_list_final
  public :: T_KEYWORD, T_IDENTIFIER, T_QUOTED, T_NUMERIC
  public :: lexeme_t
  public :: lexeme_write
  public :: lexeme_get_type
  public :: lexeme_is_break
  public :: lexeme_is_eof
  public :: lexer_t
  public :: lexer_init
  public :: lexer_clear
  public :: lexer_final
  public :: lexer_assign_stream
  public :: lex
  public :: lexer_put_back
  public :: lexer_write_setup
  public :: lexer_show_location
  integer, parameter :: T_KEYWORD = 1
  integer, parameter :: T_IDENTIFIER = 2, T_QUOTED = 3, T_NUMERIC = 4
  integer, parameter :: EMPTY = 0, WHITESPACE = 10
  integer, parameter :: NO_MATCH = 11, IO_ERROR = 12, OVERFLOW = 13
  integer, parameter :: UNMATCHED_QUOTE = 14
  integer, parameter :: CASE_KEEP = 0, CASE_UP = 1, CASE_DOWN = 2
  type :: stream_t
     integer, pointer :: unit => null ()
     type(ifile_t), pointer :: ifile => null ()
     type(line_p), pointer :: line => null ()
     integer :: record = 0
     logical :: eof = .false.
   contains
     generic :: init => &
          stream_init_filename, &
          stream_init_unit, &
          stream_init_ifile, &
          stream_init_line
     procedure, private :: stream_init_filename
     procedure, private :: stream_init_unit
     procedure, private :: stream_init_ifile
     procedure, private :: stream_init_line
     procedure :: final => stream_final
  end type stream_t
  type :: keyword_entry_t
     private
     type(keyword_entry_t), pointer :: next => null ()
  end type keyword_entry_t
  type :: keyword_list_t
     private
     type(keyword_entry_t), pointer :: first => null ()
     type(keyword_entry_t), pointer :: last => null ()
  end type keyword_list_t
  type :: template_t
     !!! !!! Compiler bug in ifort 20/21/22: no structure constants for
     !!! !!! types with private components in submodules possible
     !!! private
     integer :: type
     character(256) :: charset1, charset2
     integer :: len1, len2
  end type template_t
  type :: lexer_setup_t
     private
     type(template_t), dimension(:), allocatable :: tt
     integer, dimension(:), allocatable :: type
     integer :: keyword_case = CASE_KEEP
     type(keyword_list_t), pointer :: keyword_list => null ()
  end type lexer_setup_t
  type :: lexeme_t
     private
     integer :: type = EMPTY
     integer :: b = 0, e = 0
  end type lexeme_t
  type :: lexer_t
     private
     type(lexer_setup_t) :: setup
     type(stream_t), pointer :: stream => null ()
     type(lexeme_t) :: lexeme
     integer :: lines_read = 0
     integer :: current_column = 0
     integer :: previous_column = 0
     type(lexer_t), pointer :: parent => null ()
   contains
     procedure :: init => lexer_init
     procedure :: clear => lexer_clear
     procedure :: final => lexer_final
     procedure :: assign_stream => lexer_assign_stream
  end type lexer_t
  interface stream_init
     module procedure stream_init_filename
     module procedure stream_init_unit
     module procedure stream_init_ifile
     module procedure stream_init_line
  end interface
  interface keyword_list_write
     module procedure keyword_list_write_unit
  end interface
  interface
    module subroutine stream_init_filename (stream, filename)
      class(stream_t), intent(out) :: stream
      character(*), intent(in) :: filename
    end subroutine stream_init_filename
    module subroutine stream_init_unit (stream, unit)
    end subroutine stream_init_unit
    module subroutine stream_init_ifile (stream, ifile)
    end subroutine stream_init_ifile
    module subroutine stream_init_line (stream, line)
    end subroutine stream_init_line
    module subroutine stream_final (stream)
      class(stream_t), intent(inout) :: stream
    end subroutine stream_final
    module subroutine keyword_list_write_unit (keylist, unit)
      type(keyword_list_t), intent(in) :: keylist
    end subroutine keyword_list_write_unit
    module subroutine keyword_list_final (keylist)
      type(keyword_list_t), intent(inout) :: keylist
    end subroutine keyword_list_final
    module subroutine lexeme_write (t, unit)
      type(lexeme_t), intent(in) :: t
    end subroutine lexeme_write
    module function lexeme_get_type (t) result (type)
      integer :: type
    end function lexeme_get_type
    module function lexeme_is_break (t) result (break)
      logical :: break
    end function lexeme_is_break
    module function lexeme_is_eof (t) result (ok)
      logical :: ok
    end function lexeme_is_eof
    module subroutine lexer_init (lexer, &
         comment_chars, quote_chars, quote_match, &
         single_chars, special_class, &
         keyword_list, upper_case_keywords, &
         parent)
      class(lexer_t), intent(inout) :: lexer
      character(*), intent(in) :: comment_chars
      character(*), intent(in) :: quote_chars, quote_match
      character(*), intent(in) :: single_chars
      character(*), dimension(:), intent(in) :: special_class
      logical, intent(in), optional :: upper_case_keywords
      type(lexer_t), target, intent(in), optional :: parent
    end subroutine lexer_init
    module subroutine lexer_clear (lexer)
    end subroutine lexer_clear
    module subroutine lexer_final (lexer)
    end subroutine lexer_final
    module subroutine lexer_assign_stream (lexer, stream)
      type(stream_t), intent(in), target :: stream
    end subroutine lexer_assign_stream
    module subroutine lex (lexeme, lexer)
      type(lexeme_t), intent(out) :: lexeme
      type(lexer_t), intent(inout) :: lexer
    end subroutine lex
    module subroutine lexer_put_back (lexer, lexeme)
      type(lexeme_t), intent(in) :: lexeme
    end subroutine lexer_put_back
    module subroutine lexer_write_setup (lexer, unit)
      type(lexer_t), intent(in) :: lexer
    end subroutine lexer_write_setup
    module subroutine lexer_show_location (lexer)
    end subroutine lexer_show_location
  end interface
end module lexers
module syntax_rules
  use lexers
  implicit none
  private
  public :: S_UNKNOWN
  public :: S_LOGICAL, S_INTEGER, S_REAL, S_COMPLEX, S_QUOTED
  public :: S_IDENTIFIER, S_KEYWORD
  public :: S_SEQUENCE, S_LIST, S_GROUP, S_ARGS
  public :: S_ALTERNATIVE
  public :: S_IGNORE
  public :: syntax_rule_get_type
  public :: syntax_rule_get_n_sub
  public :: syntax_rule_get_sub_ptr
  public :: syntax_rule_last_optional
  public :: syntax_rule_last_repetitive
  public :: syntax_rule_is_atomic
  public :: syntax_rule_write
  public :: syntax_t
  public :: syntax_init
  integer, parameter :: &
       S_UNKNOWN = 0, &
       S_LOGICAL = 1, S_INTEGER = 2, S_REAL = 3, S_COMPLEX = 4, &
       S_QUOTED = 5, S_IDENTIFIER = 6, S_KEYWORD = 7, &
       S_SEQUENCE = 8, S_LIST = 9, S_GROUP = 10, S_ARGS = 11, &
       S_ALTERNATIVE = 12, &
       S_IGNORE = 99
  type :: rule_p
     private
     type(syntax_rule_t), pointer :: p => null ()
  end type rule_p
  public :: syntax_rule_t
  type :: syntax_rule_t
     private
     integer :: type = S_UNKNOWN
     logical :: used = .false.
     type(rule_p), dimension(:), allocatable :: child
     character(1) :: modifier = ""
     logical :: opt = .false., rep = .false.
   contains
     procedure :: write => syntax_rule_write
  end type syntax_rule_t
  type :: syntax_t
     private
     type(syntax_rule_t), dimension(:), allocatable :: rule
     type(keyword_list_t) :: keyword_list
  end type syntax_t
  interface syntax_init
     module procedure syntax_init_from_ifile
  end interface
  interface
    module function syntax_rule_get_type (rule) result (type)
      integer :: type
      type(syntax_rule_t), intent(in) :: rule
    end function syntax_rule_get_type
    module function syntax_rule_get_sub_ptr (rule, i) result (sub)
      type(syntax_rule_t), pointer :: sub
      type(syntax_rule_t), intent(in), target :: rule
      integer, intent(in) :: i
    end function syntax_rule_get_sub_ptr
    module function syntax_rule_get_n_sub (rule) result (n)
      integer :: n
    end function syntax_rule_get_n_sub
    module function syntax_rule_last_optional (rule) result (opt)
      logical :: opt
    end function syntax_rule_last_optional
    module function syntax_rule_last_repetitive (rule) result (rep)
      logical :: rep
    end function syntax_rule_last_repetitive
    module function syntax_rule_is_atomic (rule) result (atomic)
      logical :: atomic
    end function syntax_rule_is_atomic
    module subroutine syntax_rule_write (rule, unit, short, key_only, advance)
      class(syntax_rule_t), intent(in) :: rule
      logical, intent(in), optional :: short, key_only, advance
    end subroutine syntax_rule_write
    module subroutine syntax_init_from_ifile (syntax, ifile)
      type(syntax_t), intent(out), target :: syntax
    end subroutine syntax_init_from_ifile
  end interface
end module syntax_rules
submodule (syntax_rules) syntax_rules_s
  use ifiles, only: ifile_get_length
  use ifiles, only: line_p, line_init, line_final
  implicit none
contains
  elemental function rule_is_associated (rp) result (ok)
    logical :: ok
    type (rule_p), intent(in) :: rp
  end function rule_is_associated
    integer :: type
    integer :: n
  subroutine syntax_rule_set_sub (rule, i, sub)
    type(syntax_rule_t), intent(inout) :: rule
    type(syntax_rule_t), intent(in), target :: sub
  end subroutine syntax_rule_set_sub
    logical :: opt
    logical :: rep
    logical :: atomic
  subroutine syntax_rule_check (rule)
  end subroutine syntax_rule_check
  !!! Intel 21.7 Regression
end submodule syntax_rules_s
Igor_V_Intel
This is the regression in the latest ifort 2021.7 and ifx 2022.2. There is no error with 2021.6 and 2022.1 compiler versions. It is escalated to the developers and should be corrected in the upcoming compiler versions. Thank you for reporting it.
Juergen_R_R
Sorry for not providing a shorter version earlier, but here is a reproducer of only 72 lines:
module ifiles
  implicit none
  private
  public :: ifile_t
  public :: line_p
  type :: ifile_t
  end type ifile_t
  type :: line_p
  end type line_p
end module ifiles
module lexers
  implicit none
  private
  public :: stream_t
  type :: stream_t
  end type stream_t
     private
end module lexers
module syntax_rules
  use lexers
  implicit none
  private
  public :: syntax_t
  type :: rule_p
     private
  end type rule_p
     private
  type :: syntax_t
     private
  end type syntax_t
  end interface
  interface
  end interface
  implicit none
contains
Juergen_R_R
The workaround would be to insert also in the submodule the use statement:
  use ifile, only: ifile_t
FortranFan
@Juergen_R_R ,
Thank you for reporting issue and the nice reproducers.  Hopefully the regression will be resolved soon in an upcoming release.
FortranFan
Hello Intel Support Team members,
Please consider the following additional case also, if you can either as a separate issue or as an addendum to the incident you may file to follow up on the original post.
Ostensibly it's just a further stripped down version of the smaller reproducer from OP but it may be a separate issue, Intel teams will know best on that.  Please note the following:
  1. Comment out the lines marked A and B in this reduced case and the compiler does not raise any errors.  Intel team(s) may perhaps then want to look into how compiler handles the semantics with the PRIVATE statements?
  2. IFX raises the same errors as IFORT, so perhaps this is a front-end issue?
module m
   type :: a_t
   end type
   type :: b_t
   end type
end module
module n
   use m, only : a_t, b_t
   private                 !<-- note this statement, call it A
   type, public :: n_t
      type(a_t), pointer :: a
      type(b_t), pointer :: b
   end type
end module
module o
   use m, only : a_t
   use n
   private                 !<-- note this statement, call it B
   interface
      module subroutine sub( a )
         type(a_t), intent(in) :: a
      end subroutine
   end interface
end module
submodule(o) so
   use m, only : b_t
contains
   end subroutine
end submodule
C:\temp>ifort /c /standard-semantics m.f90
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.7.0 Build 20220726_000000
Copyright (C) 1985-2022 Intel Corporation.  All rights reserved.
m.f90(29): error #6457: This derived type name has not been declared.   [A_T]
m.f90(28): error #7257: The characteristics of the procedure argument differ from those specified in the separate interface body.   [A]
compilation aborted for m.f90 (code 1)
Igor_V_Intel
Juergen_R_R
Thanks for escalating it to the development team. I marked it as solution (though, of course, it is solved only when the regression is fixed.
