29657 Discussions
Fortran vs Visual C++ returns diffent values from pow function
Pugliesi__Raphael
Dear all,
We faced off a problem with pow function between Fortran and Visual C++. You can find attached an image about this issue. We want to achievi the same result from Fortran to C++.
Any help could be good.
Best regards.
Eugene_E_Intel
I believe that float (and Fortran default real) has 6 digits of precision, so the "a" assignment already loses information.  "b" has similar limitation.  You notice that the outputs up to 6 digits are pretty close.  I recommend you also print "a", to see, if there's a difference even before the power is computed.
Thank you,
--Eugene
Steve_Lionel
Do you understand that you are doing this computation in single precision, good to only about six decimal places? All those extra digits in the constant are wasted. When I try this in double precision, the Fortran answer you get is closer to the double-precision result than the C answer.
While I might at first suggest that it's the C result that is worse, I think your expectations are unrealistic considering the use of single precision.
TimP
If you use the pow() function and constants without suffix f in C, those are typed double.  For C float, powf() may be available, but you have no assurance that it doesn't use pow().  As you saw, exponentiation for large or small magnitude arguments may be inaccurate in the low order 4 bits, although the scalar one in ifort may be a little better.
For the case x**.25d0, sqrt(sqrt(x)) should be faster (at least in the non-vectorized case) and more accurate.
Pugliesi__Raphael
Dear all,
Thank you for all answers.
I know the limits about single precision calculation, but i must to performe the same results in C as i found in Fortran program.
Eugene, when i print out the variable "a" i got the same constante value already informed (you can find in attachments).
Steve and Tim, when i change the fortran code constants to double
program main
    real*4 a
    real*4 b
    a = 0.0000311759686155710369348526000976562500
	b =(a / .0002d0)**.25d0
    write(*,'(F50.40)') b
    end program main
i got the same result as C, but i need in C the same result as Fortran (knowing about the numerical problems). I did  the changes in C code to float type but i got the same results as double type.
Best regards.
Eugene_E_Intel
I believe "real*4" is still equivalent to "float".
You need "real*8" for "double".
Also, you need to add suffix "_8" to your literal constant, otherwise it would still be treated as single precision:
a = 0.0000311759686155710369348526000976562500_8
You would need to add the suffix to all literal floating point constants you use in the code.
(Before I get beaten up for using non-standard way to specify precision, I'd like to point you to this article that describes a standard way to specify precision in Fortran: https://software.intel.com/en-us/blogs/2017/03/27/doctor-fortran-in-it-takes-all-kinds )
FortranFan
Pugliesi, Raphael wrote:
.. but i need in C the same result as Fortran (knowing about the numerical problems). I did  the changes in C code to float type but i got the same results as double type. ..
@Pugliesi, Raphael,
Given the differences between C and Fortran re: how literal constants are treated and consequent potential for mixed-mode arithmetic, can you not employ consistent use of floating-point "double" in both sides of your mixed-language code?  You can then achieve the "same" result.  See below:
module kinds_m
   use, intrinsic :: iso_c_binding, only : WP => c_double
end module
module m
   ! Work with defined kinds in Fortran
   use kinds_m, only : WP
   use, intrinsic :: iso_fortran_env, only : output_unit
   implicit none
contains
   subroutine Fsub() bind(C, name="Fsub")
      real(WP) :: a
      real(WP) :: b
      real(WP), parameter :: D = 0.0002_wp
      real(WP), parameter :: E = 0.25_wp
      a = 0.0000311759686155710369348526000976562500_wp;
      b = (a/D)**E;
      write( output_unit, fmt="(g0,g60.40)" ) "b (Fortran): ", b
      return
   end subroutine Fsub
end module
#include <iostream>
#include <cmath>
using namespace std;
extern "C" {
   // Prototype for a Fortran subprogram
   void Fsub(void);
int main( )
  double a;
  double b;
  const double D = 0.0002;
  const double E = 0.25;
  a = 0.0000311759686155710369348526000976562500;
  b = std::pow((a/D), E);
  cout.precision(40);
  cout << "b (C++): " << fixed << b << endl;
  Fsub();
  return 0;
With the use of Intel Fortran as well as Microsoft C/C++ compiler, the above yields upon execution:
b (C++): 0.6283440254388115153716398708638735115528
b (Fortran):               0.6283440254388115153716398708638735115530
Johannes_Rieke
New Contributor III
Hi, if you want single precision in C/C++ (i.e. float), Tim P. gave the important hint in #4. Default precision in C/C++ is double precision, isn't it. You can modify FortranFan's C/C++ example by swapping to float and adding suffix "f" (without underscore, e.g. http://en.cppreference.com/w/cpp/language/floating_literal). I don't know how C/C++ handles implicit type casting, so one should be careful by using functions as pow().
