Here is a screen shot ofwhat I see when I open a thread. I am pretty sure I am missing several bells and whistles. I would appreciate it if Intel would post here a similar picture showing what I should see, so we can both see what is not working as a start. A screenshot showing what I should see when I am replying would also be useful.
I just tried 'Add Files'...a window opened with 'Close' in the top right corner and 5 'progess' squares (?) in top left corner of the window. A blue square cycled through them, showing 'progress', but nothing happened after a minute, so I closed it. I will try it again, but then I will give up....
Well, this time I got a response. The window showed me a title 'ALL FOLDERS' top left, a 'Create/delete folder edit box below it anda Search folder edit box top right, and nothing else. I was expecting to be able to browse to a folder.Is it possible that browser settings are compromising it? I am using IE7 as I have posted before.
On this showing, this forum software is not up to much for me, which is putting it mildly.
I can't see your picture.
I don't know if this is your problem, but I've found this forum doesn't work properly if javascript is turned off.
