I have a mixing (fortran main and c static lib) project. I have no problem for Linux. But I need to compile this project for Windows. Im trying to use Intel Visual Fortran for MVS 2010 (Windows 7 (64 Pro)).
I selected the next options:
Fortran/Preprocessor/Preprocessor Source File: Yes(/fpp)
Fortran/Compatibility/Enable F77 Run-time Compatibility: Yes(/f77rtl)
Fortran/Compatibility/Use F77 Integer Constants: Yes(/inconstant)
Fortran/ Diagnostics /Check Routine Interface/: No
For this options compile give me:
remark #5169: Misplaced conditional compilation directive or nesting too deep
error #6437: A subroutine or function is calling itself recursively.
If I setup the last item to
Fortran/ Diagnostics /Check Routine Interface/: ->Yes
there are additional errors:
error #7836: If the actual argument is scalar, the corresponding dummy argument shall be scalar unless the actual argument is an element of an array that is not an assumed-shape or pointer array, or a substring of such an element.
error #7983: The storage extent of the dummy argument exceeds that of the actual argument.
For Linux I use both gfortran and ifort and all ok!
What should I change for Windows?
Thanks!!!
You have two problems, both of them on the C side.
The conditional code in sources such as memalloc.c and creapdb.c has a part like this:
#elif defined(PC)
#define creapdb (_stdcall CREAPDB)
It is evident that the writer of this code assumed that you would be using CVF or perhaps Microsoft Fortran PowerStation, hence the _stdcall. Take that out so that the line reads:
#define creapdb (CREAPDB)
The second problem is that the PC preprocessor variable is not defined for this project. Add it under C/C++ > Preprocessor > Preprocessor definitions.
Or do what you did in memalloc.c and just add the appropriate define directly (remove the _stdcall there,) If you fix this in both of those sources, and then build, it will succeed.
6437: this should be self-explanatory. Add the RECURSIVE keyword before the FUNCTION or SUBROUTINE if that is intended
7836 and 7983 indicate coding errors detected by generated interface checking. You evidently did not use that on Linux. Fix the coding errors.
That some other compiler did not detect these errors is not surprising.
Supplying a scalar argument to a dummy array usually works on Intel platforms, but violates Fortran syntax.
Functions which are recursive should have the RECURSIVE keyword throughout the call stack to make them safe for such usage.
Thanks to all for fast answers. Really Im absolutely newbie in Fortran.
I think my cod has problem with preprocessing. The first warning from compile is
for line CDEC$ END IF in code:
subroutine datime(day)
character*24 day
#ifdef PC
cDEC$ IF DEFINED (PC)
character*24 fdate
external fdate
day=fdate()
cDEC$ ELSE
#elif (AIX)
external fdate_
call fdate_(day)
#else
character*24 fdate
day=fdate()
#endif
CDEC$ END IF
end
Error with recursion happens here
#ifdef PC
recursive subroutine objvertices(nacc,nobject,xmin,xmax,side,h
& ,natom,lookmol)
cDEC$ ELSE
#elif (IFC) || (AIX)
& ,natom,lookmol)
#else
& ,natom,lookmol)
#endif
I see in some lines you have the # not in column 1, or at least that's what it looks like here. They should be in column 1.
Where is the recursive call the compiler complains about? Do you perhaps need to add PC as a preprocessor definition? It is not clear to me why all this conditional code is being used.
Thanks again!
I removed all CDEC$ IF and #if. Compiler is ok. But I received many errors from link:
error LNK2001: unresolved external symbol _MEMALLOC
What is it?
I did not suggest removing both the CDEC$ if and #if. It's evident you need the #if lines at least.
The _MEMALLOC error is because your program, at least in the form you have it now, calls a routine named MEMALLOC. This is not standard Fortran and is not a routine provided by Intel Fortran.
Thank you very much!
I work with solution. Solution has a 2 projects one project in Fortran other in C . Project in C has function memalloc.c. Should I to setup a special options for link?
Make sure that the memalloc routine in C is actually named MEMALLOC in upper case.
Right click on the C project and select Properties > C++ > Code Generation. Make sure that the Runtime Library setting matches the one in the Fortran project under Libraries.
Steve,
Thanks you for help!
I will check all items again.
Because, the last error remains.
If I cannot fix this error I try to ask you again.
Maxim
I created my project again.
I setup next properties:
Fortran/Libraries/ Runtime Library: Multithreaded
C/C++/Code Generation/Runtime Library: Multi-threaded (/MT)
Fortran set as Startup Project. Fortran project dependencies form C project.
But I have errors from linker:
error LNK2019: unresolved external symbol _MEMALLOC referenced in function _SETCRG
file memalloc.c is:
#define memalloc (_stdcall MEMALLOC)
void *memalloc( void **ptr,int *entry_size, int *new_size )
{ void *newptr;
/* printf("\n Entry_size: %d, new_size: %d\n",*entry_size, *new_size);*/
if(!*new_size)
if(*ptr) free(*ptr);
return NULL;
if(!*ptr) {
newptr=calloc((size_t)(*new_size),(size_t)(*entry_size));
/*printf("\n *ptr: %p, newptr: %p, newptr int : %ld\n",*ptr,newptr,newptr);*/
else { newptr=realloc(*ptr, (size_t)((*new_size)*(*entry_size)));
/*printf("\n realloc: newptr: %p, newptr int : %d\n",*ptr,newptr);*/ }
if (newptr == 0 && *new_size != 0)
#ifdef PC
perror("memalloc");
#else
perror("memalloc");
#endif
exit(EXIT_FAILURE);
return newptr;
And from function setcrg.f I call memalloc like next:
i_cgbp=memalloc(i_cgbp,realsiz,5*ibcmax).
Compile for Linux is OK!
| Build Log |
| Output |
Deleting intermediate files and output files for project 'DelphiFortran', configuration 'Debug|Win32'.
Compiling with Intel Visual Fortran Compiler XE 12.0.1.127 [IA-32]...
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\setbc4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\relfac4b.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\indver.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\cfind4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\wrtsit4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\watput.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\radass4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\extrmobjects.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\elb.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\srfestim.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\omalt.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\mkvtl.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\crgarr.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\scaler4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\react2.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\ichash4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\cent4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\wrtprm.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\watpte.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:F /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\qinttot.F"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\extrm.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\distrTOpoint.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\setrc4d.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\off4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\mkdbsf.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\cputime.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\scale.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\rdlog4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\grdatm.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\assrad.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\wrtphi.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\vwtms2.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\expand4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:F /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\distobj.F"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\setout.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:F /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\objvertices.F"
D:\Clemson\DELPHI\DELPHI_VS2010\src\objvertices.F(181): warning #6371: A jump into a block from outside the block may have occurred. [350]
& go to 350
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\itit4j.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\conplt.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\sas.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\rdiv.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\getatm2.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\epsmak.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\asscrg.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\wrtgcrg.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\up.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\phintp4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\nitit.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\ex.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\dbsfd.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\setfcrg.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\rfind4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\nlener.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\irhash4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\clb.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\anasurf.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\wrtvisual.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\wrtatd.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\rforce.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\rdhrad.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\fxhl.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\encalc4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\wrteps4b.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\ts.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\phierg.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\namlen3.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\cube.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\setcrg.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\rent4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\inewt.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\chkcrg.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\anagrd4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\wrtsurf.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\wrt4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\rdhcrg.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\form2.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\encalc_qnifft.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:F /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\timef.F"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\phicon.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\msrf.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:f /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\crgass4.f"
ifort /nologo /debug:full /Od /fpp /f77rtl /intconstant /module:"Debug\" /object:"Debug\" /Fd"Debug\vc100.pdb" /traceback /check:bounds /libs:static /threads /c /extfor:F /Qvc10 /Qlocation,link,"C:\Program Files (x86)\Microsoft Visual Studio 10.0\VC\\bin" "D:\Clemson\DELPHI\DELPHI_VS2010\src\qdiff4v.F"
Linking...
Creating temporary file "RSP1.rsp" with contents
/OUT:"Debug\DelphiFortran.exe" /INCREMENTAL:NO /NOLOGO /LIBPATH:"D:\Clemson\DELPHI\DELPHI_VS2010\DelphiC\DelphiC\Debug" /MANIFEST /MANIFESTFILE:"D:\Clemson\DELPHI\DELPHI_VS2010\DelphiFortran\Debug\DelphiFortran.exe.intermediate.manifest" /MANIFESTUAC:"level='asInvoker' uiAccess='false'" /DEBUG /PDB:"D:\Clemson\DELPHI\DELPHI_VS2010\DelphiFortran\Debug\DelphiFortran.pdb" /SUBSYSTEM:CONSOLE /IMPLIB:"D:\Clemson\DELPHI\DELPHI_VS2010\DelphiFortran\Debug\DelphiFortran.lib" "Debug\setbc4.obj" "Debug\relfac4b.obj" "Debug\indver.obj" "Debug\cfind4.obj" "Debug\wrtsit4.obj" "Debug\watput.obj" "Debug\radass4.obj" "Debug\extrmobjects.obj" "Debug\elb.obj" "Debug\srfestim.obj" "Debug\omalt.obj" "Debug\mkvtl.obj" "Debug\crgarr.obj" "Debug\scaler4.obj" "Debug\react2.obj" "Debug\ichash4.obj" "Debug\cent4.obj" "Debug\wrtprm.obj" "Debug\watpte.obj" "Debug\qinttot.obj" "Debug\extrm.obj" "Debug\distrTOpoint.obj" "Debug\setrc4d.obj" "Debug\off4.obj" "Debug\mkdbsf.obj" "Debug\cputime.obj" "Debug\scale.obj" "Debug\rdlog4.obj" "Debug\grdatm.obj" "Debug\assrad.obj" "Debug\wrtphi.obj" "Debug\vwtms2.obj" "Debug\expand4.obj" "Debug\distobj.obj" "Debug\setout.obj" "Debug\objvertices.obj" "Debug\itit4j.obj" "Debug\conplt.obj" "Debug\sas.obj" "Debug\rdiv.obj" "Debug\getatm2.obj" "Debug\epsmak.obj" "Debug\asscrg.obj" "Debug\wrtgcrg.obj" "Debug\up.obj" "Debug\phintp4.obj" "Debug\nitit.obj" "Debug\ex.obj" "Debug\dbsfd.obj" "Debug\setfcrg.obj" "Debug\rfind4.obj" "Debug\nlener.obj" "Debug\irhash4.obj" "Debug\clb.obj" "Debug\anasurf.obj" "Debug\wrtvisual.obj" "Debug\wrtatd.obj" "Debug\rforce.obj" "Debug\rdhrad.obj" "Debug\fxhl.obj" "Debug\encalc4.obj" "Debug\wrteps4b.obj" "Debug\ts.obj" "Debug\phierg.obj" "Debug\namlen3.obj" "Debug\cube.obj" "Debug\setcrg.obj" "Debug\rent4.obj" "Debug\inewt.obj" "Debug\chkcrg.obj" "Debug\anagrd4.obj" "Debug\wrtsurf.obj" "Debug\wrt4.obj" "Debug\rdhcrg.obj" "Debug\form2.obj" "Debug\encalc_qnifft.obj" "Debug\timef.obj" "Debug\phicon.obj" "Debug\msrf.obj" "Debug\crgass4.obj" "Debug\qdiff4v.obj" "D:\Clemson\DELPHI\DELPHI_VS2010\DelphiC\Debug\DelphiC.lib"
Creating command line "Link @"D:\Clemson\DELPHI\DELPHI_VS2010\DelphiFortran\Debug\RSP1.rsp""
Link: executing 'link'
setcrg.obj : error LNK2019: unresolved external symbol _MEMALLOC referenced in function _SETCRG
msrf.obj : error LNK2001: unresolved external symbol _MEMALLOC
qdiff4v.obj : error LNK2001: unresolved external symbol _MEMALLOC
setfcrg.obj : error LNK2001: unresolved external symbol _MEMALLOC
nlener.obj : error LNK2001: unresolved external symbol _MEMALLOC
clb.obj : error LNK2001: unresolved external symbol _MEMALLOC
cube.obj : error LNK2001: unresolved external symbol _MEMALLOC
setout.obj : error LNK2001: unresolved external symbol _MEMALLOC
sas.obj : error LNK2001: unresolved external symbol _MEMALLOC
getatm2.obj : error LNK2001: unresolved external symbol _MEMALLOC
epsmak.obj : error LNK2001: unresolved external symbol _MEMALLOC
mkdbsf.obj : error LNK2001: unresolved external symbol _MEMALLOC
scale.obj : error LNK2001: unresolved external symbol _MEMALLOC
wrtphi.obj : error LNK2001: unresolved external symbol _MEMALLOC
vwtms2.obj : error LNK2001: unresolved external symbol _MEMALLOC
indver.obj : error LNK2001: unresolved external symbol _MEMALLOC
wrtsit4.obj : error LNK2001: unresolved external symbol _MEMALLOC
crgarr.obj : error LNK2001: unresolved external symbol _MEMALLOC
react2.obj : error LNK2001: unresolved external symbol _MEMALLOC
qdiff4v.obj : error LNK2019: unresolved external symbol _CREAPDB referenced in function _MAIN__
Debug\DelphiFortran.exe : fatal error LNK1120: 2 unresolved externals
DelphiFortran - 21 error(s), 1 warning(s)
I do not think so. Getting code to compile and link when the code has mismatched calls is no feat, since Fortran has separate compilation and implicit interfaces.
Just as not reading a newspapers does not prevent bad things from happening around the world, not using the diagnostic capabilities of the compiler does not make your code bug free.
Bugs of the type that are relevant to the error messages shown have been recognized as being particularly bad because they can go unnoticed for several years and then come to life when least unexpected.
(If not, the compiler has no idea what it is or where it might look for it.)
With an INTERFACE block included, the compiler will know to look for an external function called 'MEMALLOC' having three integer arguments when it tries to satisfy all external links to the .OBJ files created and used by your project, including the .OBJ file created by compiling MEMALLOC.C with your C-compiler (you must of course add the C-compiled .OBJ file to your project if you want it to be searched for external links along with your FORTRAN .OBJ files).
You may have to find out EXACTLY what symbol the C-compiler creates for MEMALLOC in the .OBJ file in which it resides and get the FORTRAN compiler to match it using a compiler directive ATTRIBUTE involving STDCALL,REFERENCE and maybe ALIAS, and so on.
Im sorry for my stupid questions. But if we have simple programs like follow:
Fortran:
PROGRAM HelloWorld
CALL f
END PROGRAM HelloWorld
C:
#include
void f_()
printf("Hi! \n");
What should I add for compilation?
However, writing to stdout from C in a Fortran program raises portability issues no matter how you do it, on both Windows and linux.
I did it in the beginning.
Now project in Fortran depends on project in C.
