29635 Discussions
Function returning a pointer inside OpenMP loop
AndresMG
The following code does not compile with ifx -qopenmp (2023.0.0 20221201) but it does with ifort -qopenmp (2021.8.0 20221119):
module main_mod
    use iso_fortran_env, only: rp => real64
    implicit none
    type statevec_t
        real(rp), allocatable :: data(:, :)
    contains
        procedure :: dof => statevec_dof
    end type statevec_t
    interface statevec_t
        module procedure statevec_initialize
    end interface statevec_t
    contains
    function statevec_initialize(nvars, ndofs) result(sol)
        integer, intent(in) :: nvars
        integer, intent(in) :: ndofs
        type(statevec_t)    :: sol
        allocate(sol % data(nvars, ndofs))
    end function statevec_initialize
    function statevec_dof(this, idof) result(sol)
        class(statevec_t), target, intent(in) :: this
        integer,                   intent(in) :: idof
        real(rp),          pointer            :: sol(:)
        sol => this % data(:, idof)
    end function statevec_dof
end module main_mod
program main
    use main_mod, only: rp, statevec_t
    implicit none
    integer :: nv = 4
    integer :: ndof = 6000000
    type(statevec_t) :: solution
    real(rp), pointer :: Qi(:)
!   Initialization
    solution = statevec_t(nv, ndof)
    call random_number(solution % data)
!   Associate
    do concurrent (integer :: i = 1 : ndof) shared(solution)
        associate(Qi => solution % dof(i))  !< Compiler error
            Qi = 3.0_rp * Qi
        end associate
    end do
!   Pointer
    do concurrent (integer :: i = 1 : ndof) shared(solution) local(Qi)
        Qi => solution % dof(i)  !< Compiler error
        Qi = 3.0_rp * Qi
    end do
!   Direct assignment
        solution % dof(i) = 3.0_rp * solution % dof(i)  !< Compiler error
    end do
end program main
Any of the three options in lines 65, 73 and 80 returns a compiler error. Note that the issue is related to the -qopenmp flag. Both compilers work fine without it.
I have read through the list in https://www.intel.com/content/www/us/en/developer/articles/technical/fortran-language-and-openmp-features-in-ifx.html and I could not find any reference to this issue (although it was implemented for sequential compilations at some point during 2022).
Labels (3)
Barbara_P_Intel
This issue is fixed in oneAPI 2023.2.0 that was released this week.
Please download the new release and check it out!
Barbara_P_Intel
Thanks for reporting this. I filed a bug, CMPLRLLVM-44595.
Barbara_P_Intel
AndresMG
I confirm it is fixed, at least with my setup. It also seems that the compiler is able to inline the function call in this simple case.
Thank you for the bug report and the quick response from the developers.
