29578 토론
GDB does not step into subroutine (ifx)
Cook__Gordon
초급자
4,273 조회수
When debugging application compiled with ifx, GDB steps over subroutine calls when issued a "step" command. If the code is compiled with ifort, GDB correctly steps into subroutine calls.
ifx:
$ ifx --version
ifx (IFORT) 2022.1.0 20220316
Copyright (C) 1985-2022 Intel Corporation. All rights reserved.
$ ifx -g -O0 -c hello.f90 -o hello.o
$ ifx -g -O0 test.f90 -o test hello.o
$ gdb -ex 'break 2' -ex 'run' -ex 'step' ./test
GNU gdb (GDB) Red Hat Enterprise Linux 8.2-16.el8
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Type "show copying" and "show warranty" for details.
This GDB was configured as "x86_64-redhat-linux-gnu".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
    <http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from ./test...done.
Breakpoint 1 at 0x403cd2: file test.f90, line 2.
Starting program: /home/kenche03/code/test
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib64/libthread_db.so.1".
Breakpoint 1, test () at test.f90:2
2       call print_hello
 hello from subroutine
3       print *,"finished test"
ifort:
$ ifort --version
ifort (IFORT) 2021.6.0 20220226
$ ifort -g -O0 -c hello.f90 -o hello.o
$ ifort -g -O0 test.f90 -o test hello.o
Breakpoint 1 at 0x402d99: file test.f90, line 2.
2       call print_hello
print_hello () at hello.f90:2
2       print *,"hello from subroutine"
It's possible to eventually step into the subroutine with code compiled with ifx, e.g. with multiple "stepi" or "set step-mode on", but ideally a single "step" command would do it.
Source code:
$ cat test.f90
program test
call print_hello
end program test
$ cat hello.f90
subroutine print_hello
end subroutine print_hello
레이블 (1)
0 포인트
1 솔루션
Ron_Green
중재자
3,742 조회수
Ah, I see what you are looking for.  Perhaps there is something we can do to get the functionality you are seeking.  To make this example behave like ifort or gfortran.  I'll open a bug report and see what if anything we can do.  It takes cooperation between the debugger and the compiler binaries.  We hope the gdb developers test with ifx - but I rather doubt it.  It's hard enough to get gfortran support.  it could be that we had to enhance our object and debugger info to work with our GPU offload functionality in ifx.  If that is the case, then gdb will need a fix to work with our debug info.  But if it's our issue and we can fix it, we'll do that.
 But I found a workaround for you
You can use gdb-oneapi.  it's Intel's enhanced gdb to work with our new binary formats needed for oneapi.  We have some extensions for Fortran as well.  It works with your example and ifx as you expect.
$ ifx -g -O0 -what -V -c hello.f90
Intel(R) Fortran Compiler for applications running on Intel(R) 64, Version 2024.1.0 Build 20240308
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
 Intel(R) Fortran 24.0-1472.3
$ ifx -g -O0 -what -V -o test test.f90  hello.o
GNU ld version 2.40-14.fc39
$ gdb-oneapi -ex 'break 2' -ex 'run' -ex 'step' ./test
GNU gdb (Intel(R) Distribution for GDB* 2024.1.0) 14.1
Copyright (C) 2024 Free Software Foundation, Inc.; (C) 2024 Intel Corp.
This GDB was configured as "x86_64-pc-linux-gnu".
For information about how to find Technical Support, Product Updates,
User Forums, FAQs, tips and tricks, and other support information, please visit:
<http://www.intel.com/software/products/support/>.
Breakpoint 1 at 0x4051d2: file test.f90, line 2.
Starting program: /nfs/pdx/disks/cts1/quad/rwgreen/monday20240429/test
2	call print_hello
(gdb) step
3	end subroutine print_hello
(gdb) step
test () at test.f90:3
(gdb) step
 finished test
4	end program test
(gdb) step
0x00000000004051ad in main ()
(gdb) quit
A debugging session is active.
	Inferior 1 [process 3844808] will be killed.
Quit anyway? (y or n) y
원본 게시물의 솔루션 보기
5 응답
Louise-Linaro
초급자
3,823 조회수
Hi -
Has there been any update on this issue?
0 포인트
Ron_Green
중재자
3,793 조회수
I had a quick look.
First, do not use 2022.x ifx.  it's buggy.
Next, ifx is not ifort.  The objects and inlining is different.
print_hello is an external procedure (old F77 style).
with ifx, use the -flto to get the linker to pull in debug info for these externals.  You only need it on the final compile/link for test
ifx -g -O0 -what -V -o test test.f90 hello.o -flto
rwgreen@orcsle153:~/quad/monday20240429$ gdb -ex 'break 2' -ex 'run' -ex 'step' ./test
GNU gdb (Fedora Linux) 14.2-1.fc39
Copyright (C) 2023 Free Software Foundation, Inc.
<https://www.gnu.org/software/gdb/bugs/>.
This GDB supports auto-downloading debuginfo from the following URLs:
  <https://debuginfod.fedoraproject.org/>
Enable debuginfod for this session? (y or [n]) n
Debuginfod has been disabled.
To make this setting permanent, add 'set debuginfod enabled off' to .gdbinit.
2	call print_hello
0 포인트
Louise-Linaro
초급자
3,770 조회수
Hi @Ron_Green
Thanks for taking a look - however, looking at your code snippet, the step just stepped over the call to `print_hello` it didn't stop in it.
It is on line 3 of test.f90 not on line 2 of hello.f90 as expected.
0 포인트
Ron_Green
중재자
3,743 조회수
2	call print_hello
(gdb) step
(gdb) step
(gdb) step
 finished test
4	end program test
(gdb) step
(gdb) quit
Louise-Linaro
초급자
3,566 조회수
Hi @Ron_Green
Yes running under gdb-oneapi fixes the issue.
Is there plans to upstream the fix for this issue or do you know the patch that fixes it?
Louise
0 포인트
응답
