29429 Discussions
GETCHARWIDTH GETCHARWIDTH32 GetCharWidthFloat in VISTA
steve_konarski
I do not sem to get the functions
to work in VISTA - are ther compatible functions in the latest Visual fortan which would work in VISTA
Those are Win32 API routines, not part of Intel Visual Fortran. I think we'll need some more information as to what "doesn't work", and perhaps a small example.
steve_konarski
I have the program
USE DFWIN
USE DFLIB
IMPLICIT NONE
CHARACTER*15 TYPEFACE
INTEGER HFONT,HDC,RET
INTEGER NCHARS,I, NHGG,NW,ABCD(0:255)
REAL ABCD1(0:255)
TYPE (T_ABC) AB(0:255)
NCHARS=255
TYPEFACE="Arial"//char(0)
HDC = GETDC(NULL)
NHGG=-10000
NW=0
HFONT = CREATEFONT(-NHGG, NW, 0, 0, 0, 0, 0, 0, &
DEFAULT_CHARSET, OUT_TT_PRECIS, CLIP_DEFAULT_PRECIS, &
PROOF_QUALITY,INT(DEFAULT_PITCH) ,TYPEFACE)
RET=SELECTOBJECT(HDC,HFONT)
RET=GETCHARWIDTH32 (HDC,1,NCHARS,LOC(ABCD(1)))
RET=GETCHARWIDTHFLOAT (HDC,1,NCHARS,LOC(ABCD1(1)))
RET=GETCHARABCWIDTHS(HDC,1,255,AB(1))
DO I=65,90
WRITE(*,*)I,' ',CHAR(I),ABCD(I),ABCD1(I),AB(I)%ABCA,AB(I)%ABCB,AB(I)%ABCC
ENDDO
STOP
END
In windows XP it lists the widths of characters between A and Z and all three functions
GETCHARWIDTH32 , GETCHARWIDTHFLOAT, GETCHARABCWIDTHS
give values, however under Vista I just get zeros, I am using Visual Fortran Vers 6.0
if I upgrade will the problem be resolved
This is not a compiler problem - while there are many reasons to upgrade, this is not one of them.
I don't have immediate access to a Vista system to try your program. Perhaps another reader can comment.
steve_konarski
I compile and obtain the exe on an xp machine and transfer the exe to a vista machine where it does not produce the desired results
steve
steve_konarski
Any body got any ideas why the program does not work on Vista ?
garylscott1
These APIs are not applicable to Truetype fonts. It could be that Vista has different defaults or the particular font isn't available. There is a different API for Truetype fonts. See the MSDN description http://msdn.microsoft.com/en-us/library/ms534215(VS.85).aspx
steve_konarski
I checked and the font is available , and accoding to the MSDN site these should work in VISTA - but they do not
garylscott1
Sorry, I don't have Vista on anything, how about running the below and reporting theresults
USE DFWIN
USE DFLIB
IMPLICIT NONE
REAL ABCD1(0:255)
NCHARS=255
TYPEFACE="dingers"//char(0)
HDC = GETDC(NULL)
NHGG=-10000
NW=0
write(*,*)'hfont=',hfont,getlasterror()
write(*,*)'selobjret=',ret,getlasterror()
write(*,*)'cw32ret=',ret,getlasterror()
write(*,*)'cwfret=',ret,getlasterror()
write(*,*)'abcwret=',ret,getlasterror()
DO I=65,90
ENDDO
END
garylscott1
I'm just slightly suspicious that Vista believes that the passed buffers are too small to hold the data from the query since you pass the address of a single element rather than of the whole array. Maybe one of the security updates for Vista was to add checks for the correct size of argument buffers. (just a wild theory)
steve_konarski
this is result from windows XP
hfont= 1208633627 0
selobjret= 25821217 0
cw32ret= 1 0
cwfret= 1 0
abcwret= 1 0
65 A 5970 373.1250 -13 5996 -13
66 B 5970 373.1250 656 4838 476
67 C 6464 404.0000 446 5664 354
68 D 6464 404.0000 691 5297 476
and from Vista
hfont= 1376391332 0
selobjret= 25821253 0
cw32ret= 0 0
cwfret= 0 0
abcwret= 0 0
65 A 0 0.0000000E+00 0 0 0
66 B 0 0.0000000E+00 0 0 0
67 C 0 0.0000000E+00&nb sp; 0 0 0
68 D 0 0.0000000E+00 0 0 0
Call GetLastError after the function returns zero and see what the extended error code is.
steve_konarski
Have I not done that already ? the result form getlasterror is zero
Sorry, yes, you did.
Jugoslav_Dujic
Valued Contributor II
I suspect (although I don't have a Vista around so I can't check either) that GetDC(NULL) might be the culprit. Google search on "Vista getdc null" hints at the possibility that Vista has an entirely different screen model... see e.g. here. Try with a "real" DC perhaps?
steve_konarski
Hi Jugoslav those links do point to a possible problem - not sure what you mean by
a "real" DC
steve
Jugoslav_Dujic
I mean, pretty much any DC other than the desktop one...
For the start, try GetDC(GetDesktopWindow()). Alternatively, you can try creating (and destroying later!) a memory DC, using
hDC = GetDC(GetDesktopWindow())
hMemDC = CreateCompatibleDC(hDC)
ret = CreateCompatibleBitmap(hDC , 100, 100)
iSt = SelectObject(hMemDC, hBmp)
!do stuff here
ret = DeleteObject(GetCurrentObject(hMemDC, OBJ_BITMAP)
ret = DeleteDC(hMemDC)
Note that a) I admit this is an overkill for such a simple task and b) I'm stabbing in the dark... smiley [:-)]
steve_konarski
Hi jugoslav thanks - that did dont work either - but i will try anything to get it to work
steve
garylscott1
The specific msdn description for GETDC indicates that GETDC(null) should behave the same on Vista asI read it. But I would suggest adding a write of the return code and getlasterror after GETDC(null) as well and see if the extended error code is nonzero there. It is quite odd for the return code for the other functions to retun false but for there to then be a zero GETLASTERROR() result as well. The indicates to me some major Vista error reporting anomaly or some unknown error within this application that messes up the GETLASTERROR() return value (stack corruption, out of bounds access not reported, etc.)
ggveldkamp2
I tried the program on Vista and could get it to work by changing the value of NHGG. I used NHGG=-16. It looks to me it has something to do with the fontsize.
Guido
steve_konarski
Thankks Guido i tried -16 but no luck BUT -100 and -1000 worked. I originally had a value of 10000 and used getcharwidth to get the resolution , but will now try getcharwidth32.
