I'm using GETENVQQ to retrieve PATH environment value on a Win 2K box. My problem is if there is a white space in the string, e.g. "...program files..." the string will be truncated to "...program". Does anyone know a work around to this problem?
-Mohammad
-Mohammad
Which version of CVF and do you have example code? This appears to function properly in the current version.
James
James
