GetFileInfoQQ
Stephen_Sutcliffe
New Contributor III
I am trying to use the GetFileInfoQQ function to get the information relating the files including the size. Unfortunately if the files are large the file size is returned as -1. This seems to occur when the number of bytes in the file is greater than the integer(4) variable component limit is exceeded. Is there a work round for this? It would be great if the file size units could be specified. These days MB or even GB would seem more appropriate than bytes. Alternatively integer(8) components could be an option in a similar function GetFileInfoQQEx.
Steve
mecej4
Current Fortran provides a standard way of finding the file size: INQUIRE(..., SIZE = myFileSize, ...).
Steve_Lionel
I suggest that you read the documentation for GETFILEINFOQQ. The functionality you request is already there.
Stephen_Sutcliffe
New Contributor III
So it is,
FILE$INFOI8 is what I need.
I might have found this if F1 help was still working.
Thanks Steve
