I am attempting to create a .dll with a batch file. Everything else with batch file works except for this part. I keep getting this error:
Error: A license for FCompW is not available now (-15,10,10061).
A connection to the license server could not be made. You should
make sure that your license daemon process is running: both an
lmgrd.exe process and an INTEL.exe process should be running
if your license limits you to a specified number of licenses in use
at a time. Also, check to see if the wrong port@host or the wrong
license file is being used, or if the port or hostname in the license
file has changed.
License file(s) used were (in this order):
1. Trusted Storage
2. C:\Program Files (x86)\Common Files\Intel\Licenses\w_HJTBRLFR.lic
3. C:\Program Files\Common Files\Intel\Licenses
4. c:\PROGRA~2\intel\COMPOS~1\bin\ia32\*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
ifort: error #10052: could not checkout FLEXlm license
I checked out services and it seems FLEX keeps stopping itself. In event viewer, you can see where the process of the making the .dll crashed.
Thanks in advanced!
All licensing issues need to be submitted at https://supporttickets.intel.com/?lang=en-US - licensing experts don't hang out here.
