GetFullPathName
Nick2
I am trying to get a full path where the executable is located at run-time. So here's what I'm trying:
program main
use KERNEL32
CHARACTER*500 path
integer(LPSTR) path1
CHARACTER*200 filename
integer(DWORD) dum
path1=0
filename='WideString.exe'
dum = GetFullPathName(filename, 500, path, path1)
if(dum .eq. 0)then
dum=GetLastError()
print *, dum
endif
print *, path
end
'WideString.exe' is the name of the executable. Similar code works well in C++, but not in Fortran.
Any idea what I'm doing wrong or a better way to accomplish this?
I forgot the mention...GetFullPathName and GetLastError both return 0, and the variable path ends up being a blank string.
Steven_L_Intel1
You want:
filename='WideString.exe'C
You also need to either search for the trailing NUL in the return value or use the function return value for the length.
Nick2
Ah, thank you!
Only GetFullPathName returned the current path, rather than executable's path. Any better functions to accomplish this?
Paul_Curtis
Valued Contributor I
The routine you want is
INTEGER :: nc
CHARACTER(LEN=255) :: fpname
nc = GetModuleFileName(GetModuleHandle('MYPROG.EXE'C), fpname, LEN(fpname))
where you supply the name of your running executable and fpname is returned with the full UNC path.
Steven_L_Intel1
Even better, pass NULL to GetModuleHandle to get the handle to the running EXE, whatever its name is.
Nick2
Awesome! I love it how the function returns the number of characters in the path too!
