What order do I install Intel fortran and VS in to get VS to see the intel Fortran?
VS is installed first. The integration phase of ifort installation doesn't work when VS is not present. It should be possible to repeat the integration after a qualifying version of VS is installed.
I installed a 90 trial version of Visual Studio 2008 Professional Edition. Next I installed Intel Visual Fortran 10.1.001.ia32 and it said that it could not a sutable version of visual studio?? Is there something I can check with VS 2008 to see if it is compatible with intel fortan 10.1?
It is. See Release notes. I'm using it in that combination (the trial of VS should (?) have nothing to that, probably something with installation went wrong).
A.
A.
If you mean 10.1.010, that version does not support VS2008. You need 10.1.019 or later. You can get that from the Intel Registration Center after you register your serial number.
