29646 Discussions
Getting an error popup after loading Fortran solution
ferrad1
I am upgrading to IVF 2021 with VS 2019 Community.
Every time I open my SLN file, I get an error popup about a missing directory \bin32 (see attached).  If I click OK, the 2nd popup comes warning about Intel Advisor XE 2013.  The project correctly loads after clicking Yes, and appears to run fine, however I'd really like to get rid of these popups, mainly the first, as I can suppress the 2nd it seems.
Any idea how I fix the first popup?
IVF version is:  Intel(R) 64, Version 2021.5.0 Build 20211109_000000
ferrad1
I managed to suppress this popup by Manage Extensions -> All -> Intel Advisor -> Disable
Although I have no idea whether I need it or not.
Steve_Lionel
If you don't know, then you don't!  Intel Advisor is a tool that analyzes your running program and makes suggestions that may improve performance. It's part of the oneAPI Base Toolkit, but it seems you have an ancient version still installed. I would first look to see if Advisor XE 2013 is installed and uninstall it if needed. Then, in the Windows app list, select the oneAPI Base Toolkit, Change/Modify, and deselect Advisor if you don't plan on using it.
