29375 Discussions
Getting error #5623 when declaring character length creating an array with array syntax
ur
New Contributor II
Getting an error in several codes after upgrading to the latest ifort/ifx version, and do not see
this one in a search.  Is this one reported yet?
ifx (IFORT) 2023.0.0 20221201
Copyright (C) 1985-2022 Intel Corporation. All rights reserved.
subroutine sub1()
character(len=:),allocatable :: string
string='abcd'
write(*,'("[",a,"]")')[character(len=10) :: string]
end subroutine sub1
ifx -c sub1.f90
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1f563ca]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1bef70e]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1c55e52]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1c55e26]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b69946]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b6f2d1]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1b73215]
/lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3)[0x14c43b213083]
/opt/intel/oneapi/compiler/2023.0.0/linux/bin-llvm/xfortcom[0x1982da9]
a.f90(4): error #5623: **Internal compiler error: internal abort** Please
report this error along with the circumstances in which it occurred in a
Software Problem Report. Note: File and line given may not be explicit
cause of this error.
compilation aborted for a.f90 (code 3)
Ron_Green
I will start a bug report for IFX.  thanks for bringing this example to us.
ron
jimdempseyatthecove
ICE is bad regardless of coding error.
Two experiments for you to do (and report back).
Replace your write with
write(*,'("[",a,"]")')(character(len=10) :: string) ! larger than len(string)
and
write(*,'("[",a,"]")')(character(len=2) :: string) ! smaller than len(string)
Note ()'s replacing []'s in both changes
Jim Dempsey
ur
New Contributor II
Not sure what you mean about the () characters, as that is non-standard and causes an error with all compilers.
Runs fine with ifort and gfortran, anything specifying the LEN= parameter fails with ifx.  The actual codes (occurs in
a lot of existing code) has worked for years with ifort; gfortran; ... . Not sure about ifx.  The only thing that works with
ifx in the 2023 is the one with no LEN specified.  There are also, in the real codes, the same error with ifort, but not
in the same places, which is interesting.  This test runs fine with ifort, but gives the llvm traceback; so I guess ifort has moved
to the llvm.  To make room for the new 2023 install I had to delete the previous versions so do not have a previous ifx (or ifort) to
do any tests with, only have 2023 handy on my personal machine. The real codes do not involve WRITE statements; but when
trying to create a reproducer I found that the assignments and function calls were not required to reproduce the problem; just
using the syntax on a WRITE sufficed. If it was just ifx and not ifort producing the problems I could work around this, but it appears
in a lot of code and the new ifort is failing as well, as mentioned.
program testit
call sub1()
contains
subroutine sub1()
string='abcd'
#ifndef ifx
write(*,'("[",a,"]")')[character(len=10) :: string] ! larger than len(string)
write(*,'("[",a,"]")')[character(len=2) :: string] ! smaller than len(string)
write(*,'("[",a,"]")')[character(len=4) :: string] ! same len(string)
#endif
write(*,'("[",a,"]")')[string]
end subroutine sub1
end program testit
! gfortran output:
![abcd ]
![ab]
![abcd]
![abcd]
! ifort output:
![abcd ]
![ab]
![abcd]
![abcd]
Ron_Green
ron
Ron_Green
bug ID CMPLRLLVM-42916
ur
New Contributor II
Thanks.  I want to start migrating to ifx; and this version comes close so far to compiling a large collection of code that runs with ifort; but this was a show-stopper for me.
Ron_Green
This bug is fixed in the latest 2023.1.0 compiler.
Ron_Green
this bug is fixed in the 2023.1.0 compiler
ur
New Contributor II
Thanks once again!  Will be putting the new version to use immediately. Looks like a good number of issues have been resolved.
