Graceful shutdown and ctl-C
Richard_Kerr
I would like to gracefully shutdown a program using ctl-C in terms of making sure all intermedium results are saved to a file. I do not wish to 'interrupt' a program during writing to file.
The following program seems to do the trick. However I could only get it to work by inserting a line
call sleep(0)
before the if statement that checks if the is_killed variable is ==1.
Ctl-c doesn't interrupt the program if the call sleep(0) is removed.
Why is this so?
If anyone has a better way of gracefully interrupting a program with ctl-C then I would be most grateful
RIchard
module global
integer :: is_killed
end module global
program test
use ifport
use global
implicit none
external :: warning_sigint
integer :: warning_sigint
integer :: result1, i
character(len=12) :: string
is_killed=0
i = signal(SIGINT, warning_sigint, -1)
do
   open(22,file='stuff',status='unknown')
   do i = 1,1000000
      write(22,*) i
   enddo
   close(22)
   print *, 'printed stuff'
   call sleep(0)
   if(is_killed == 1) stop
enddo
end program test
function warning_sigint (SIG_NUM)
use global
integer :: SIG_NUM
print *, 'Process interupted by CTL-C '
warning_sigint = 1
is_killed = 1
end function warning_sigint
