Hi all ?
I am looking for a code (FORTRAN will be fine) that can extract the HDD serial number (manufacture's number).
Is there any one who knew well about this?
Quoting - portoon
Hi all ?
Accidentaly, I've read a recent comp.os.ms-windows.programmer.win32 thread about the subject yesterday.
Basically, you need to call DeviceIOControl API with IOCTL_STORAGE_QUERY_PROPERTY and read the string from STORAGE_DEVICE_DESCRIPTOR.SerialNumberOffset. Here's a sample, in C; (googling for keywords above will give you a variety of similar codes, of varying degree of complexity):
http://www.askmehelpdesk.com/advice/t-6466.html
However, there seems to be a catch, because not all disk vendors store that serial number, and in that case you must go through hoops to get the information.
See the freeware diskid32 application, and its source code .
Quoting - portoon
Hi all ?
Here is a program to obtain HDD serial number.
The site I referenced is here.
http://www.usefullcode.net/2007/02/hdd.html
With Vista, you have to run the executable file as admin (right click exe-file, chose run as admin).
I hope this will help you.
Yamajun
[cpp]PROGRAM disk
USE kernel32
IMPLICIT NONE
INTEGER(HANDLE) :: hDevice
INTEGER(LPDWORD):: lpBytesReturned = 0
INTEGER(BOOL) :: iret
TYPE :: t_IDENTIFY_DEVICE_OUTDATA
SEQUENCE
TYPE (t_SENDCMDOUTPARAMS):: snd_cmd_out
CHARACTER(511):: DriverStatus ! typedefs DRIVERSTATUS
END TYPE
TYPE (t_SENDCMDINPARAMS) :: snd_cmd
TYPE (t_IDENTIFY_DEVICE_OUTDATA) :: out_data
INTEGER, PARAMETER :: DFP_RECEIVE_DRIVE_DATA = Z'0007c088'
INTEGER, PARAMETER :: ATAPI_IDENTIFY_DEVICE = Z'EC'
INTEGER :: i, ndrive
CHARACTER(19) :: fn
ndrive = 0 ! First drive 0, Second Drive 1 ...
WRITE(fn, '(a, i1, a)') '.PhysicalDrive', ndrive, CHAR(0) !C string
hDevice = CreateFile(fn, IOR(GENERIC_READ, GENERIC_WRITE),IOR(FILE_SHARE_READ, FILE_SHARE_WRITE), &
NULL, OPEN_EXISTING, FILE_ATTRIBUTE_NORMAL, NULL)
IF (hDevice == INVALID_HANDLE_VALUE) THEN
PRINT *, GetLastError()
iret = CloseHandle(hDevice)
STOP 'error CreateFile'
END IF
snd_cmd%irDriveRegs%bCommandReg = Z'EC' !ATAPI_IDENTIFY_DEVICE
snd_cmd%irDriveRegs%bDriveHeadReg = IOR(Z'A0', ISHFT(IAND(ndrive, 1), 4))
snd_cmd%cBufferSize = sizeof(out_data) ! 511?
snd_cmd%bDriveNumber = ndrive
iret = DeviceIoControl(hDevice, DFP_RECEIVE_DRIVE_DATA, LOC(snd_cmd), sizeof(snd_cmd), LOC(out_data), sizeof(out_data), LOC(lpBytesReturned), NULL)
IF (iret == 0) THEN
STOP 'error DeviceIoControl'
END IF
! the order of "out_data%DriverStatus" is 2byte little endian
! http://www.usefullcode.net/2007/02/hdd.html
WRITE(*, '(a)', ADVANCE='NO') 'Serial Number = '
DO i = 21, 40, 2 ! ?
WRITE(*, '(2a1)', ADVANCE='NO') out_data%DriverStatus(i:i), out_data%DriverStatus(i - 1:i - 1)
END DO
WRITE(*, *)
WRITE(*, '(a)', ADVANCE='NO') 'Model = '
DO i = 55, 93, 2 ! ?
END DO
WRITE(*, *)
PAUSE
STOP
END PROGRAM disk[/cpp]
