HDF5 1.8.12 test is segfaulting with ifort 14.0.1
valery_w_
Principiante
1.224 Vistas
Dear All
HDF5 1.8.12 segfault with ifort 14.0.1 (worked fine with 13.1.2). The tests fortranlib_test_F03 (segfault see bellow) and fortranlib_test (not shown) dont work properly.
The conf and compilation steps are:
ifort -V
Intel(R) Fortran Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.1.106 Build 20131008
Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
FOR NON-COMMERCIAL USE ONLY
wget http://www.hdfgroup.org/ftp/HDF5/current/src/hdf5-1.8.12.tar.gz
tar xvfz hdf5-1.8.12.tar.gz
mkdir tmp
cd tmp
../hdf5-1.8.12/configure --prefix=/home/vwe/libs/hdf5/1.8.12-intel-14.0.1 --enable-fortran --enable-fortran2003 --enable-static-execs=yes --enable-shared=no CC=icc FC='ifort -O0 -g -traceback'
make -j 4
cd fortran/test
./fortranlib_test_F03
                              FORTRAN 2003 tests
 FORTRANLIB_TEST is linked with HDF5 Library version 1.8 release  12
 Testing 1-D Array of Compound Datatypes Functionality                  PASSED
 Testing 1-D Array of Compound Array Datatypes Functionality            PASSED
 Testing 3-D array by dataset, using C_LOC                              PASSED
 Testing writing/reading enum dataset, using C_LOC                      PASSED
 Testing enumeration conversions                                        PASSED
 Testing writing/reading bitfield dataset, using C_LOC                  PASSED
 Testing writing/reading opaque datatypes, using C_LOC                  PASSED
 Testing writing/reading object references, using C_LOC                 PASSED
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
fortranlib_test_F  000000000071AED9  Unknown               Unknown  Unknown
fortranlib_test_F  0000000000719850  Unknown               Unknown  Unknown
fortranlib_test_F  00000000006D75C2  Unknown               Unknown  Unknown
fortranlib_test_F  00000000006A7FE3  Unknown               Unknown  Unknown
fortranlib_test_F  00000000006AB9AB  Unknown               Unknown  Unknown
libpthread.so.0    0000003FC900F000  Unknown               Unknown  Unknown
fortranlib_test_F  0000000000430A9C  Unknown               Unknown  Unknown
fortranlib_test_F  0000000000425A8D  h5s_mp_h5sselect_        1332  H5Sff.f90
fortranlib_test_F  0000000000419624  t_regref_                2028  tH5T_F03.f90
fortranlib_test_F  00000000004042BD  MAIN__                     96  fortranlib_test_F03.f90
fortranlib_test_F  0000000000403F76  Unknown               Unknown  Unknown
libc.so.6          0000003FC8C21A05  Unknown               Unknown  Unknown
fortranlib_test_F  0000000000403E69  Unknown               Unknown  Unknown
0 kudos
2 Respuestas
Casey
Principiante
1.224 Vistas
I have had nothing but problems with hdf5 1.8.x compile with the 14.x versions of ifort.  My problems vary from test-cases never finishing and exhausting memory to corrupt output in production code.  There is a thread a month or two old that goes into a bit more detail, but never received much attention.  I've gone back to gfortran until ifort can remember how to compile hdf5.
Michael_B_10
Principiante
1.224 Vistas
This was  probably caused by this bug in the Intel Fortran compiler:
https://software.intel.com/en-us/forums/topic/498698
which they fixed. But alas, Version 15.0 again breaks HDF5 when the --enable-fortran2003 option is specified...*sigh*.
I'll update the 15.0 situation in another thread.
Responder
