HDF5 with ifort
Manfredo_d_1
I just completed a fresh installation of ifort-icc compilers and installed the HDF5 package with the intel compilers. The installation seemed ok and the correct mod files have been produced. Then when I try to use the HDF5 I get the usual different compiler error:
/Users/manfredo/Desktop/ED2/ED/src/include
 /usr/local/hdf5_mio/include
 /usr/bin/ifort-14.0-base/compiler/include/intel64
 /usr/local/include
 /usr/include
End of search list.
hdf5_coms.F90(3): error #7013: This module file was not generated by any release of this compiler.   [HDF5]
   use hdf5
compilation aborted for hdf5_coms.F90 (code 1)
make[1]: *** [hdf5_coms.o] Error 1
make: *** [all] Error 2
MacBook-Air-di-Manfredo:bin manfredo$ icc -v
icc version 14.0.4 (gcc version 4.8.1 compatibility)
Before installing the HDF5 with intel compilers I had a version compiled with gfortran. However before reinstalling it with ifort I cleaned all the files and now the only hdf5.mod file I have is the one produced during the intel compilation. Working on Mac OSX.
Thanks for any suggestions. Manfredo
Kevin_D_Intel
I don't know whether the information is still available, but if so, can you scan your configure output to see whether there is any reference to gfortran?
Also can you scan your HDF build area and find the hdf5.mod file and then attach it in a reply. That will help us determine whether it was produced by gfortran or ifort.
TimP
You can't use the .mod files generated by gfortran; in fact, gfortran .mod files work only across a narrow range of gfortran releases.  You may have forgotten to force the .mod files to rebuild with ifort.
Kevin_D_Intel
As Tim indicates, it appears an incompatible module file is being found.
You may already be aware of the article Building HDF5* with Intel® compilers; however, noting your use of the 14.0 compiler, once you overcome this module issue you may experience the issue outlined in the Resolving problem when building HDF5* with Intel® compiler 14.0 listed in the Known Issues and Limitations section in that article.
Manfredo_d_1
As I said I compiled the HDF5 by specifying the intel compilers exactly as it described in the page Kevin suggests.
Manfredo_d_1
By the way, I had already checked the make and didn't found that error. My file H5Sff.f90 is indeed already correct.
Manfredo_d_1
The set of instructions I used is:
export CC=icc
export F9X=ifort
export CCX=icpc
tar -zxvf hdf5-1.8.15.tar.gz
  cd hdf5-1.8.15
  ./configure --prefix=/usr/local/hdf5_mio --enable-fortran
  make
  make check
  sudo make install prefix=/usr/local/hdf5_mio
I also checked with a locate that no hdf5 file from the old versions were present so there should be nothing but the files compiled with intel compilers.
TimP
If you didn't set a value for CXX, I suppose it may use g++.   The logs ought to show it.
Kevin_D_Intel
Manfredo_d_1
@Tim: Good suggestion, I didn't realize the mistake. I am trying again. Meanwhile the result of the ./configure has some unexpected lines:
Compiling Options:
               Compilation Mode: production
                     C Compiler: /usr/bin/clang ( Apple LLVM version 6.0 )
                         CFLAGS:
                      H5_CFLAGS:  -O3
                      AM_CFLAGS:
                       CPPFLAGS:
                    H5_CPPFLAGS:   -DNDEBUG -UH5_DEBUG_API
                    AM_CPPFLAGS:
               Shared C Library: yes
               Static C Library: yes
  Statically Linked Executables: no
                        LDFLAGS:
                     H5_LDFLAGS:
                     AM_LDFLAGS:
          Extra libraries: -lz -ldl -lm
                Archiver: ar
               Ranlib: ranlib
           Debugged Packages:
            API Tracing: no
Languages:
                        Fortran: yes
               Fortran Compiler: /usr/local/bin/gfortran ( GNU Fortran (GCC) 4.9.0)
          Fortran 2003 Compiler:
                  Fortran Flags:
               H5 Fortran Flags:  -pedantic -Wall -Wconversion -Wunderflow -Wimplicit-interface -W -O2 -s
               AM Fortran Flags:
         Shared Fortran Library: no
         Static Fortran Library: yes
                            C++: no
I am pretty sure here to have correctly typed the compilers to export. May it be not enough to specify export CC=icc to set the C compiler?
TimP
If your Intel compilers aren't made visible by sourceing the compilervars or ipsevars script, the configure also would fall back to other compilers.
The Intel article referred to above suggests compiler FLAGS settings to go with Intel compilers/
Manfredo_d_1
Solved by switching export........  to
sudo CC=icc F9X=ifort CXX=icpc ./configure .........
@Tim @Kevin Thank you so much for you support, I appreciated it.
Kevin_D_Intel
Interesting. I guess that suggests something in your current shell leads to the use of gfortran despite the exports. Anyway, glad you found a usable solution.
I will make note of your experiences to the article's author just to double check nothing has changed on the more current OS X* releases.
